Technical engine information | FerrariChat
Discussion in '456/550/575' started by 928s, Apr 27, 2023.
  1. 928s
    928s Rookie
    Mar 30, 2006
    20
    Greg Gray
    Hi all,
    I rarely post here but have always found this site and the cars interesting, I have a technical automotive background so I am looking for some details that are not often discussed. I am from the Porsche world and they have or had official technical booklets for the older models that came out in the 80s and 90s. It gave details like camshaft specifications, somewhat limited but it would give duration and lift, I would also detail items conrod length, wrist pin diameter, valve diameters, bearing diameters etc. I haven’t found anything like this on the 456 or later related series? Have I missed some low hanging fruit? Or aren’t these details commonly available?
    I have always loved the 456 GT and might be getting close to buying one, I only like the early cars and I like in regards to older cars I love applying modern technology to them. I am currently rebuilding and modifying a Porsche 928 engine and have removed around 8 kilos or rotating and reciprocating weight by using essentially NASCAR parts. I am also building a full inconel exhaust.
    I have always wondered if the bore can be increased in the 456? Standard it’s 88 mm why not like the 812 Superfast? Which is 94mm. The 928 started out at 95 mm and a friend in the US has one that was taken out to 109 mm, with the stroke improvement, he has 7.0 litres but 7.5 litres is possible baring in mind the engine started out at 4.5 litres in 1978. That is a fair amount of increase. For the record the amount of stroke chosen can depend on the amount of revs desired at the top end.
    Just from what I could glean from photos the 456 engine seems to be designed to somewhat restrict ultimate power and allow future development. Any further information would be appreciated.
    Cheers GG.
  2. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,217
    Georgia
    Wade Williams
    The Ferrari work shop manual has all of that information. It would be a great engine to modify.
  3. Vilhuer
    Vilhuer Karting
    Aug 3, 2008
    164
    Helsinki, Finland
    This area starts to look more and more like Rennlist 928 forum. Just go away Greg or soon Ake, Greg B. etc. will all be here endlessly fighting over silly details. :)
    There is nothing like 928 document pdf collection available for any other model including other Porsche's. Ferrari WSM are ok but that's just a start.
  4. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    For example the Ferrari electrical diagram is more like ideas and guidelines than an actual chart with lines and colors. They give you just enough info to draw your own diagram.
    The 456 is a great car. Get a 3 pedal, you won't kick yourself later.
