Technical info on F1 transmission | FerrariChat
Discussion in '360/430' started by enzob, Apr 18, 2009.
  1. enzob
    enzob Rookie
    Jan 31, 2004
    39
    San Diego, Ca
    Enzo Bertaggia
    Does anyone know what the cylinder diameter that is used to shift gears on the F1 transmission? What is the hydraulic pressure used?
    Thanks,
    Enzo
  2. Rifledriver
    37,099
    #2 Rifledriver, Apr 18, 2009
    The pressure has a range of, if I recall correctly, about 500 to 900 lbs. It will operate down to about 300 but the system will shut down before it gets that low. It has an accumulator and a pump. The pump is controlled by pressure switches to maintain that pressure range in the accumulator.
    The cylinder diameter is quite small. I do not believe it is given in any technical information but something on the order of half inch. It has been some time since I have seen one far enough apart to see.
