Technical Question on 348 cylinder head. Please advise | FerrariChat
Discussion in 'Technical Q&A' started by errico, Nov 1, 2012.
  1. errico
    errico Karting
    Sep 16, 2012
    142
    Hello
    Thinking of buying a 348 which had this issue..
    at 22000 km it had a Cylinder head joint changed. I received this information from the Ferrari Tech in Europe but because of the language differences i did not understand what he meant. The car is a European Import. The car now has 36000km. Imported at 36000. last major in europe , same garage at 36000km.
    The repair on this was 22000$ .
    1. Is this a motor job ? show i be concerned if done well? are the chances high that this same issue can happen again.
    2. stay away .
    If anyone is a Ferrari Tech please PM me
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,739
    For $22K the negine would have been removed from the ar, both heads would have been removed and disassembled, new valve guids put in, poosible some valves replaced, the valve seats refaced, the heads cleaned, reinstalled. The motor would have been pressure tested, put back in the car, and driven to confirm the power and reliability of the motor ongoing.
    This is genrally called something like a "top end rebuild".
    When performed by a competent shop, this rebuild puts the motor in a state where one should expect a nice long life from the motor. So, if you are the first owner after such work, you should follow the manufactures break in for the first 500-1000 miles--and then the motor will be ready to run the snot out of it, like any good Ferrari motor!
  3. errico
    errico Karting
    Sep 16, 2012
    142
    that was done at 22000 km in 2005. in 2008 it had 36000 km. so it did 14000 km.
    this top end rebuild just makes me ask myself, was it a defect or abuse..
    Thank You!
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I'm anxious to hear how you know what work was done and why from the vague information provided by errico.
  5. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    For "cylinder head joint" I would surmise the head gaskets. Says nothing about any other work there. I have done a couple of valve jobs when I had wierd leakage results during a major service. If the dealer was an official dealer, back in the heyday, just head gaskets could well have been gouged out that much!
  6. Mitch Alsup
    Nov 4, 2003
    9,739
    A major service with new head gaskets would have been a lot closer to $12-15K than $22K. This is why I suspect that the head was rebuit in some way.
  7. errico
    errico Karting
    Sep 16, 2012
    142
    Hello Guys
    I called the dealer for explaination and it they confirmed that it was indeed the head gaskets only. The labour is 270 $ an hour :) in Europe in 2005.
    Is changing head gaskets complicated on this car and is it something i should be worried about in my purchase.
    Hopefully its a defect in material and not abuse. Thank you for all the responses, it was a head gasket change thats all.
  8. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    WOW !!
    On what planet is "Europe" located, now ?!
    (assuming you mean US dollars) $270 / hr labor rate is extraordinarily high in 2005 dollars. Heck, it is high even in 2012 dollars ! What country was this ?
    .....did the mechanic have a "JD" or an "MD" listed after his name ??
  9. errico
    errico Karting
    Sep 16, 2012
    142
    Switzerland.
    that is what the ferrari mechanic said. tomorrow i get the work order .
    head gaskets a major repair ?
  10. finnerty
    May 18, 2004
    10,406
    You know it is really hard (and kind of silly) for anyone to speculate on what was done. You really should get a hold of a copy of the invoice and confirm what was actually done to know anything for sure ---- and to give you peace of mind.
    Just taking the heads off to replace the head gaskets is a fairly big job by itself, but so many other things could have also been done (many of which you would just do because everything else is apart and you want to be thorough and preventative).
    I would certainly assume that (at a minimum) the timing belts would have been changed during re-assembly (as they are off to get the heads off), and the belts themselves are rather inexpensive --- so only a penny-pinching fool would put the old ones back on.
    If this were my car, I would want to know EXACTLY why the heads had to come off in the first place. As this is not a "normal" procedure for a 360 with such low mileage, so something "out of the ordinary" must have happened ----- and, it may have been serious ---- and, you would really want to ensure that everything that needed to be done got done and got done correctly.
    And, if the labor rate really was billed at $270/hr........well you can hit a big bill pretty quickly, even with only replacing a few parts of moderate expense.
  11. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,569
    Calgary, Canada
    if they knew the work was done and cost, then they should have reciepts of the work done ....if they are serious to sell to you the car, then they should (or you should insist) to see those, which will tell exactly what was (or wasn't) done on the car
  12. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Don't forget the statutory minimum employment leave of at least 20 work days per year, plus 12–16 public holidays.
    When their (Euro) problems hit US shores - keep that in mind as we bail 'em out.
    Apologies for the digression.
    Rgds,
    Vincenzo
  13. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Good job they're not in the eurozone then........
  14. errico
    errico Karting
    Sep 16, 2012
    142
    thank you guys, waiting for the copy via email. the moment i get it i would need a german translator :)
  15. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
  16. finnerty
    May 18, 2004
    10,406
    I don't speak German, but I am sure several here do. So, feel free to please post it up if you want, translated or untranslated, as I am sure many here would be very curious to see it. Also, then some of the pros like Tim (2NA) might be willing to offer their assessment and insights into the work that was done?
    Considering that you can buy a good used 348 engine complete for about $10-12K here in the States, I would love to know what one gets when they spend twice that on a repair :)
  17. errico
    errico Karting
    Sep 16, 2012
    142
    here is finally what happened. translated from german step by step. please let me know how bad this is !
    motor has no compression both cylinder heads
    valves - guide valves
    TIMING BELT BROKE !
    55 hours of labor total 10000$
    REPAIR
    emissions test
    outlet valve 1300 $ 8 valves 162.57 each
    sealing end cap
    valve guides inlet valve guides 895$
    cylinder head gasket 495 $
    chain adjuster
    timing belt
    FAN BELT
    FAN BELT ALTERNATOR
    gear 886 $ ???
    the rest is all seals.
    Does it get any worse than this ?
    this happened at 21000km, car now has 36000km. What are your opinions on this car ?
  18. finnerty
    May 18, 2004
    10,406
    I'll defer to the experts here who do these sorts of things (on Ferraris) for a living.
  19. 335s
    335s Formula Junior
    Jan 17, 2007
    870
    SF Bay Area
    T. Monma
    in take guides-what about exhaust?
    probabably all new valves and seals
    head gaskets were cheap...IMO...
    This repair is what happens when the outer limits of belt shelf life is pushed to squeeze the last penny out of this interval!
    When it snaps-and snap they clearly do-means big money...fixed these before, it is an expensive and time intensive as well as dollar intensive...that aside, its not a big deal as far as I am concerned...just make sure you change belt every 3-4 years or 30K miles...it is a single belt so famage will be more severe-thus more expensive....this can be seen in the biill...no?
  20. errico
    errico Karting
    Sep 16, 2012
    142
    what i see from the invoice is that the major componets are valves and guides, if its not a major deal i will consider this car . Pistons are not indicated as impacted.
    How can i verify if all is ok, compression tests ?
  21. Sunracer
    Sunracer Formula Junior
    May 18, 2005
    661
    Makati City
    Pierre Beniston
    Seems as though it has done enough miles that the work has been tested, don't see why you wouldn't buy it. PB
  22. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    There are three test you can do to verify the work is okay. They are:
    1) Cooling system pressure test.
    This will make sure that the head gasket does not have any leaks, especially NGO the combustion chamber.
    2) Compression test.
    This will check the health of the bottom end. In particular how well the piston rings are keeping compression, and in some part how well the heads are sealing.
    3) Leak down test.
    This test will really pin point any weakness in the engine. If your valves aren't sealing well it will show what valves are leaking, same deal with the piston rings.
  23. errico
    errico Karting
    Sep 16, 2012
    142
    Thank you guys. This will be done this week. I hope it goes good.
  24. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Some times I just hate autocorrect.
    Sorry that SHOULD have read:
    "This will make sure that the head gasket does not have any leaks, especially GOING INTO the combustion chamber."
    How in the hell the autocorrect got NGO out of that is beyond me??????
  25. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    I don't believe that report. People on ferrarichat have told me that timing belts never break, and it's a waste of money having them renewed.....
