Technology is scary. | FerrariChat
Discussion in 'General Automotive Discussion' started by etomcat, May 10, 2005.
  1. etomcat
    etomcat Karting
    Jul 6, 2004
    245
    Hungary
    Tamas Feher
  2. Etcetera
    Etcetera Two Time F1 World Champ
    23,991
    C6H14O5
  3. Malfoy
    Malfoy Formula 3
    Mar 22, 2004
    1,960
    Hampton, VA
    Hungarians who hate America are scary....sort of...
  4. Ershank
    Ershank Formula Junior
    Aug 26, 2004
    376
    Philadelphia
    Jason Z
    House spiders in showers are scary... sort of.
  5. CMY
    CMY F1 World Champ
    Oct 15, 2004
    10,142
    Redondo Beach, CA
    Chris
  6. etomcat
    etomcat Karting
    Jul 6, 2004
    245
    Hungary
    Tamas Feher
    The battery was depleted because of many hours of excess use of electronics (GSM phone system) on-board. Suprisingly, the main automotive battery pack in the belly of the the Prius hybrid car is not interconnected with the small traditional car battery under the hood.
    I don't know if this engineering decision was sound or stupid.
    Airplanes have multiple fuel tanks and they are interconnected, so the left wing tank can crossfeed the right-wing engine(s) and vica versa. This is a safety measure, but also a hazard.
    An atlantic Airbus A330 flight very nearly crashed and people almost got eaten by sharks when one engine developed a fuel leak and the flight computer kept feeding it from both tanks and the plane soon ran dry. The only reason they made it to an airstrip at Canaries was a route detour which put them near enough to soar in. It was pure chance, extreme luck and some gliding skill by the pilots.
    The Prius situation is not nearly that dramatic, but resource interconnect should still be provided. Maybe a brain-dead turnknob under the dash secured with tripwire, which the user can manually activate if he/she really badly needs to connect the batteries.
  7. MarkPDX
    MarkPDX F1 World Champ
    Apr 21, 2003
    15,111
    Gulf Coast
    #7 MarkPDX, May 11, 2005
    Observation 1.... If you run out of gas in your Prius while cruising at .80 mach and 40K feet you have bigger things to worry about than being eaten by sharks upon ditching.
    Observation 2.... Is the Prius like the Starship Enterpise? Should it have apparently unlimited ability to transfer power at the touch of a button? I understand this is important if the Klingons are attacking and you must transfer power energy from the warp drive to the deflector shields. Unfortunately the Prius does not come equipped with deflector shields so if the Klingons attack while you are busy trying to infect your car with a bluetooth virus and your battery is dead then you are just plain screwed.
    Observation 3.... Hungarian taxis are scary
  8. 1975gt4don
    1975gt4don Formula Junior
    Nov 5, 2003
    665
    Peoples Rep of CA
    Smog Exempt
    CTRL-ALT-DEL
