Teflon tape on fuel line connectors? | FerrariChat
Discussion in 'Technical Q&A' started by troy_wood, Feb 13, 2009.
  1. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    Do you guys tape your fuel line connection points? I know mine has not had it in the past but I am wondering if it is a good practice? Thanks.
  2. Eagle1
    Eagle1 Rookie
    48
    Wisconsin
    Mark Poulter
    Troy,
    If you have the Banjo style fittings sometimes if you install new crush washers the leaks will stop. Wouldn't recommend Teflon as I'm not sure of its tolerance to fuel/petroleum products.
    Have a good day
  3. 350HPMondial
    350HPMondial F1 Veteran
    5,192
    Edwardo
    #3 350HPMondial, Feb 13, 2009
  4. troy_wood
    troy_wood Formula 3
    Apr 28, 2007
    1,457
    Nova Scotia, Canada
    Troy Wood
    hehe - i guess its a big no... I read somewhere on this board that guys were doing it...
  5. Rifledriver
    34,031
    Austin TX
    People do all kinds of things.
    That one is not a good idea.
  6. CarbBoxer
    CarbBoxer Formula Junior
    Oct 7, 2008
    841
    Houston
    PW
    no. use Loctite 569 which is great for this application.
  7. gidge348
    gidge348 Formula Junior
    Dec 12, 2008
    343
    Perth West Australia
    Ian Wood
    As long as the fittings are undamaged and have clean mating surfaces they should not need PTFE tape.
    If they leak, look for damage and replace as required.
  8. 50hdmc
    50hdmc Formula 3
    Oct 10, 2006
    1,211
    Michigan
    mark s
    I saw it here somewhere too Troy....as a matter of fact they recommended "yellow" tape....
  9. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,214
    Twin Cities
    Tim Keseluk
    Teflon tape (or pipe "dope") is used as a sealant on tapered pipe threads. These fittings seal by a wedging action as the tapered male thread is screwed into the likewise tapered female. Any other use is incorrect and probably more trouble than it's worth.
