Temp gauge and Tpms error same time | FerrariChat
Discussion in 'Technical Q&A' started by DAVID SIEGEL, Jun 12, 2019.
  1. DAVID SIEGEL
    DAVID SIEGEL Karting
    Jun 12, 2019
    72
    I know this is a Ferrari forum and you guys always were able to answer tech questions on my F-car
    I have an Aston Martin Rapide which did somehting very strange the engine temp gauge went to full hot temp and at the same time the TPMS light came on.
    The engine was not overheating. Every time we put the key in accessory position the guage went right to hot with TPMS on even when the engine was cool
    We then saw the gauge go from Hot to normal temp and the TPMS light went out at the same time.
    The dealer changed the coolant temp switch but could not explain why the TPMS was on when the gauge was showing hot and went off when the gauge dropped to the correct temp.
    Any thoughts on this.
  2. Steve Magnusson
    25,112
    Yeah, there's too much damn electronics in modern cars! (Just mashin' your taters ;))
  3. Qavion
    Qavion F1 World Champ
    11,521
    Ian Riddell
    Unrelated systems often share common (indication) power sources, wiring harness plugs and earths. Disconnecting the plugs on certain types of temperature indication systems makes the gauge read full scale (open circuit = very high resistance). Sorry to say this, but I wouldn't be surprised if your problem returns (unless part of the indication faultfinding procedure included cleaning the earths).
