Temp spike on 246GT | Page 2 | FerrariChat
Temp spike on 246GT
Discussion in 'Technical Q&A' started by dm_n_stuff, May 26, 2004.
  1. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Well, if it cools when revved at idle, it could indicate a waterpump problem as it needs the speed to circulate. But if it cools only when driving I'd guess the radiator itself.
    Dumb question: are you sure the hoses aren't connected backwards? It happens!
    Ken
  2. dm_n_stuff
    Dec 10, 2003
    43,935
    26.806311,-81.755805
    Dave M.
    Hoses are a-ok.
    Can ran fine for the 1st 800 miles after the rebuild.
    Mechanic suspects that crap worked up to radiator from around the cooling system, and that may be the problem.
    Gonna tear out the radiator, get it fixed, and see what is what.
  3. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    One other thought...head gasket. I'll bet 10-1 it's the radiator itself but I do seem to remember someone once saying a blown head gasket can cause heat spikes. I bet you already know it's not because you've seen the coolant and there's no oil in it, but check if you haven't already.
    Ken
  4. dm_n_stuff
    Dec 10, 2003
    43,935
    Dave M.
    No oil in the coolant. So, head gasket is ok, too.
    Gonna yank out the radiator, get it cleaned, then see what happens.
    Can buy a better than original Ron Davis for about $900, or go original for about $1500. hmmm.......... looks like Ron Davis if I have to go that way.
  5. dm_n_stuff
    Dec 10, 2003
    43,935
    Dave M.
    Slow leak at the water pump, caused a bubble of massive proportion. When I bled the cooling system, I didn't have enough persistance. If I had bled it for 15 minutes, I might have started to see the problem.
    Mechanic is fixing the water pump now, car will be road worthy tomorrow!!!
    So, all's well that ends well.
