Temporary 348 Fog light signals mounting | Page 3 | FerrariChat
Discussion in '348/355' started by mj_duell, Dec 3, 2009.
  1. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,187
    Huntsville, AL., USA
    Andrew
    #51 NeuroBeaker, Dec 10, 2009
    Excellent, Mike! Once you colour it black, are you thinking of remounting the Cavallino Rampante in the stock location? :)
    All the best,
    Andrew.
    PS:
    Is it a requirement for 348 ownership that one be called or change your name to Mike? There seem to be a lot of you! :D
  2. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    Ordering a Cavallino Rampante from scaledetails today just for that purpose!
    --Mike
  3. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,187
    Andrew
    :D
    Did it certainly require a new one? I had just assumed the one off the stock grill would detach and could be moved over, or was it permanently mounted?
    All the best,
    Andrew.
  4. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    New part, new badge :D.
    Oh, by the way the first of the 348 Fog/Signal/Driving lens replacements are done:
    http://www.ferrarichat.com/forum/showthread.php?p=139188560#post139188560
    --Mike
  5. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    wow this is fantastic!!! I know what I'm doing if I ever break my lenses again.
    -Eric
  6. BLUROAD
    BLUROAD F1 Veteran
    Feb 3, 2006
    6,081
    Tustin Ranch, Cali
    Enrico Pollini
    #56 BLUROAD, Dec 10, 2009
    Outstanding work Mike...
    Mike I will have to fly you in for a weekend of Garage fun sometime... I need this type of help with my little Fiat race cars.....I will show you some pics of what I am trying to accomplish...
    The first two pics are my car. The third pic is a Ferrari with the fog lights in the corners how I want it to look on my car... the last pic is an example of how I want the car to look when complete.. accept with mine having the cool fog light set up..I would need your expertise to make some type of Fog Light cradle and surround...I am also open for suggestions. Ok sorry for the hijack back to our regularly scheduled program....
  7. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    Absolutely! PM me with your phone number, I would be happy to help.
    --Mike
  8. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    #58 mj_duell, Dec 12, 2009
  9. TexFerrari
    TexFerrari Formula 3
    Sep 11, 2004
    1,194
    Texas of course!
    nice, keep up the good work. I think I will do scoops to the brembo big brake kit plus lights behind them :)
  10. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    #60 mj_duell, Dec 13, 2009
    Outdoor shot I got today. Still need to paint the center section.
    --Mike
  11. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,187
    Andrew
    Very nice! :D
    It'll look particularly brilliant when that central section is painted. :)
    How is it you're painting them? Are you using spray cans or some sort of powdering system?
    All the best,
    Andrew.
  12. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    At the moment I'm using Plasti-Dip. Sprays on even and it dries even as well. It gives good stone protection to a point. I thought about powder coating, but I am not sure what the baking heat will do to the aluminum. The Plasti-Dip seems to work good and looks very OEM.
    --Mike
  13. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    #63 mj_duell, Dec 15, 2009
  14. Night life
    Night life F1 Veteran
    7,311
    The city that rhymes with fun in Canada
    Roberto
    Very cool mate, continue on you have something here.
  15. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    After the holidays I will get at it again. :D
    --Mike
  16. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,187
    Andrew
    Ah, I've heard of Plasti-Dip... some of the MINI guys use it to black out headlight rings and such. :)
    :D Very cool! That looks aggressive yet OEM - very, very nicely done. :cool:
    All the best,
    Andrew.
  17. marcov
    marcov Karting
    Dec 8, 2007
    110
    Ottawa Canada
    Marco V
    Nice Work! Those would look good with Challenge flush mounded headlights.
  18. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    #68 mj_duell, Dec 16, 2009
    I don't have those, might be a good next project, but I did finally find lights for behind the grills I like. They will have driving, fog and maker/signals. They are made by PIAA and I think will do the job nicely. I have to manually convert the marker to a signal, but that is not hard.
  19. TexFerrari
    Sep 11, 2004
    1,194
    Texas of course!
    PIAA makes a good usable light, had them before for several projects and a truck.
    For the center grill section, you should paint the two brackets you made to help support it black also. With these lights you picked out behind the grill, should look great and they are the right shape. I would try to mount these along the bottom. How much of the space would they fill? If 50-60%, I would use the space above them attach the brake duct scoop. \\\
  20. PAP 348
    Dec 10, 2005
    100,232
    Mount Isa, Australia
    Pap
    Very cool! :D:D
  21. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    #71 mj_duell, Dec 17, 2009
    I thought about painting the brackets, but there is just too much black and I like the contrast. I did the opposite with the rear engine cover and it looks great (see below). You need to see it in person, flash pictures don't do it justice. The PIAA's are about 6 inches long and the screens measure about 11.5 inches. I will place them on the bottom to the inside I think, will have to see. The brake duct would fit in back of the cavity behind everything. There will be a good amount of air pressure to the back.
    --Mike
  22. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,187
    Andrew
    I agree. :cool:
    I'm looking forward to the further updates after the holidays. :D
    All the best,
    Andrew.
  23. mj_duell
    mj_duell Formula 3
    Nov 20, 2004
    1,421
    S. Glastonbury, CT.
    #73 mj_duell, Dec 22, 2009
    I know I said I was done for now, but the PIAA's showed up over the weekend. Friday I received my 600 piece weather pack kit as well, so I guess the project was still on. After a couple cold days in the garage I am very happy with the result. The PIAA's have everything I need in one light, driving lamps, parking/markers and a modified fog for a turn signal (looks and works way better than OEM). I still have to aim the driving lights and do a few small touches but I think this screen/light project is a wrap. I am thinking about actaully doing the brake ducts now. Start that in a few weeks. The front end looks great!
    --Mike
  24. NeuroBeaker
    Moderator
    Oct 1, 2008
    40,187
    Andrew
    Woohoo - surprise updates!! It's like Christmas has come early... :D
    Looking good, Mike! :cool:
    All the best,
    Andrew.
  25. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Gives the car more of a competition look. As an alternative to the OEM lights, these look great, Mike!
