Tensioner bearing plate's torque amount on 308?? | FerrariChat
Discussion in '308/328' started by chairpilot, May 15, 2011.
  1. chairpilot
    chairpilot Formula 3
    Mar 3, 2007
    1,547
    LA, CA & Olympia, WA
    PlateClipGuys
    On Birdman's site the belt change procedure indicates 41 ft-lbs on the center bolt holding the bearing's final position. But, what torque is advised on the 3 small nuts holding each assembly against the block?
    Thanks,
    Bob R.
    BTW - belt changes are easy on this car. It's moving all the sh-- out of the way that's a bit__h! Especially some of those 14 small bolts holding the back side cover against the cam belt covers on my QV. I had to heat bend one of my nice 8mm wrenches to get the really tight accessed ones! So now now I have another "special" Ferrari tool in my box (LOL!).
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,324
    They are standard M8 (13mm wrench) nuts so 18/19 lbft
  3. chairpilot
    Mar 3, 2007
    1,547
    PlateClipGuys
    Thanks Iain.
  4. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    There is no static fixed torque setting for a nut of a certain size. It depends on the composition of the metals (the nut and the stud), the locking mechanism (various mechanical or chemical), dry/lubed, tpi/thread, the conditions (high vibration, etc.), it goes on an on. You can certainly start at a baseline and adjust up or down from there based on these, and many other, conditions however.
  5. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,324
    All true - but nonetheless, 18/19lbft & some Nylocs will do the job ;-)
    (At least it better had because that's what I just used on mine ! )
  6. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,876
    Mike 996
    As Cliff noted, you have to be a bit careful with this - a standard torque setting for a steel nut/stud will rip that stud out of aluminum. A torque setting applied to dry fittings produces 30% LESS tension on the fittings than that same torque applied to a fitting lubed with 30 wt engine oil. So again, especially when AL is involved, it is really important to know how the torque settings are specified.
    OTOH, in reality, relatively few bolts are actually tightened with a torque wrench and they don't really need to be AS LONG AS the person doing the work has a good feel for it. I had a good friend who probably broke half the fittings he ever touched because his view was the assembly should be as tight as he could make it. When he attached a 1/2" drive ratchet/socket to a 7/16" bolt/nut head, the results were always predictable... ;)
  7. chairpilot
    Mar 3, 2007
    1,547
    PlateClipGuys
    Funny you mentioned the studs Mike. While tightening the 3 nuts on each tensioner plate, the one farthest forward on the front plate would not "click" on my torque wrench. Things did not feel right about it. So I removed the plate, double nutted the stud, removed it to discover the stud was only penetrating the block about 5/16"!! Worse than that, the entry threads of the hole in the aluminum block looked stripped. The stud looked original like the others but seemed too short as I could not just thread it in farther without loosing outer threads for the plate. I checked the hole depth to see what I had available and determined about 3/4" of potential thread depth. I re-tapped the hole to be sure the remaining threads were sound the full depth (they were). So I took a longer "8.8" 8mmx1.25 bolt I had, cut off the head and threaded the end to make a longer stud. Re-mounted the plate-bearing and torqued the nuts to 18 ft-lbs. Now all is good!
    Bob
  8. mwr4440
    57,988
    Bavaria, The 'Other' Germany
    Mark W.R.
    Guys,
    Aren't those torque values in the WSM? Many are. I know yours is a Euro QV but I think the Mondi 8 WSM has the correct torques for those bolts we would use on an early GTSi.
    I check tonight in and around packing for Krakow and post.
  9. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,324
    Not in the 308/328 manual hence reverting to the standard(ish) values normally used for std pitch M8 threads. 18lbft on the nut isn't going to pull a stud out the block (unless the thing is not in the block properly in the first place as above IMO).
  10. mwr4440
    57,988
    Mark W.R.
    Did a semi-quick look and could NOT find them in the Mondi 8 WSM either.
    Sorry, I really thought they were there.
  11. Squirrelmonkey
    Squirrelmonkey Karting
    Dec 27, 2010
    126
    Manitoba ,Canada
    Tom Thieme
    According to the 308 dino manual the torque is 2.5 Kg/m, Which translates to 2.2 LB x 2,5 Kg x 3.3 = 18 Ft lb.
    Tom
  12. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,312
    Ventura, California
    Robert Garven
    #12 robertgarven, May 16, 2011
  13. mwr4440
    57,988
    Mark W.R.
    Granted it was a quick look, but darn it, did I MISS THAT?
    I looked in my Mondi 8 WSM and did not find it. I'll check again.
    Maybe it was my Dino manual I was thinking of. Got to dig it up from the packing box. :(
  14. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    The 308/328 Specs & Recalls doc. available from the Steve Jenkens web site has the most comprehensive set of torque specs for the 3x8s & Mondials. It's generally regarded as superceding the specs in earlier WSMs.
  15. skipgt4
    skipgt4 Formula Junior
    Nov 3, 2003
    446
    GR Michigan
    Charles VDB
    I have an issue with the tensioner studs. When I tried to remove the three locknuts, the nut didn’t come off the stud, the stud came out of the block. Is there a torque number for the stud into the block?
  16. BigTex
    79,386
    Houston, Texas
    Bubba
    Yes....Locktite
  17. robertgarven
    Feb 24, 2002
    5,312
    Ventura, California
    Robert Garven
    4 out of 6 of mine were stripped due to the nature of the block & or to much torque. Repace the the threads with timeserts!!!!!
  18. mwr4440
    57,988
    Mark W.R.
    I finished stripping one. It 'gave' long before that torgue was attained. :(
    I put in steel coil threads (Helicoil).
    Drilling a Ferrari aluminum block for the Helicoil is the scariest thing I have ever done.
    Walking thru a minefield in Bosnia/Croatia was easier.
  19. skipgt4
    Nov 3, 2003
    446
    GR Michigan
    Charles VDB
    the studs on mine are in good shape. its just that the locknuts were so stuck that the stud turned out of the block before the nut broke loose from the stud.
    Do i just put put loctite on the stud and put it back in the block? no torque value?
  20. robertgarven
    Feb 24, 2002
    5,312
    Ventura, California
    Robert Garven
    I have never used locktite in the aluminum block but be very careful as the porosity of the 308 engine blocks are well known and even the most careful removal or replcement of a stud can strip easily!. I am not an expert on this but highly reccomend timeserts they are better than any other thread repair and permanent, any OEM car companies use them in their new engines... ++ TIME-SERT Official Threaded inserts for stripped threads, blown out sparkplugs,
