Tensioner Bearing (PT355) by Hills Engineering? | FerrariChat
Discussion in '348/355' started by Nero308, Jun 8, 2009.
  1. Nero308
    Nero308 Karting
    Jan 2, 2004
    190
    NorCal
    Yoshi
    My 355 has the tensioner bearings (X2) by Hills Engineering, and its part number is PT355. My mechanic has pointed out that the core is made of two pieces and not single solid piece and suggest I should exchange them with the OEM. Have anyone had any experiences with these tensioner bearings by HE? Any quality and reliability differences compared to the OEM? Any input and suggestion will be appreciated.
  2. Nero308
    Nero308 Karting
    Jan 2, 2004
    190
    NorCal
    Yoshi
    #2 Nero308, Jun 8, 2009
  3. Euromog
    Euromog Karting
    Apr 5, 2009
    102
    Oakhurst, CA
    John Wessels
    I have installed several sets of Hill Engineering tensioners with confidence. Along with their clutch release bearings and seals. All of their products are top quality. In many cases they improve on the original Ferrari part they replace. I would leave them installed. I would recommend checking the belt tension with an ultrasonic tension meter.
  4. Vegas-Guy
    Vegas-Guy Formula 3
    Nov 25, 2007
    1,828
    Austin, TX
    Reg
    I had these installed when I did my 30k service in Aug. '08 and 5k miles ago..:) I bought the 30k service pack from Ricambi and had NO problems..:D
  5. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    When I get to my next 'major' service ...... I will definitely be installing Hill bearings ......... :)!!!
  6. 355
    355 F1 Rookie
    3,643
    Toronto
    Frank
    I have them on order from Daniel at Recambi to go in my car in a few weeks. They are supposed to be a vast improvement on the OEM bearing.
  7. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    I wnoder if Hill makes the 'tensioner' too ..... :)?
  8. Chris Honeywell
    Chris Honeywell Karting
    Nov 11, 2007
    98
    Trowbridge UK
    Chris Honeywell
    They are FAR better than the Original Ferrari ones.
    Just had Hills Tensioners fitted to my 348
  9. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    I'd be exchanging your mechanic for one that knows what he's talking about! Seriously, they are a gazillion times better than the OEM junk.
  10. Nero308
    Nero308 Karting
    Jan 2, 2004
    190
    NorCal
    Yoshi
    Thanks guys for all the inputs. I will certainly keep the HE tensioner bearings!
  11. rimoore
    rimoore Formula 3
    Nov 18, 2004
    1,353
    Island in Maine
    Richard Moore
    +1
  12. johan6504
    johan6504 Formula 3
    Jun 28, 2005
    1,168
    Sweden
    Johan
    I will use HE on my next major service/cam belt change
  13. 355redcar
    355redcar Karting
    71
    hi guys
    how many MILES or YEARS should hill TENSIONER BEARINGS last ?
    versus the ORIGINAL tensioner bearings..with these 3 holes
    does other car manuf. uses the same bearings
    what about timing bearings--
    --alternator tensioner etc.
    red car
  14. dkny
    dkny Formula Junior
    Jun 8, 2005
    575
    Kingston, NY
    dave
    +1
    I am just completing the major on my 348 and used Hill Eng bearings...
  15. GerryD
    GerryD Formula 3
    May 5, 2010
    2,444
    North of TO
    Guido
    Bearings can last a few months or many many years. The H. E. bearings are better designed and because the roller is wider the load is distributed better and more evenly. Mine felt so good last engine out service that we left them in. They have now been in for 6 years and Ill bet they will last another 6 or more but Im not a betting man so ill change them next service in 2 years. If a bearing is going to fail, it will fail in its early days because of a bad design or a defect. After that they last a long time especially the H. E. bearings
  16. 355redcar
    355redcar Karting
    71
    hi anyone that knows
    can you post pictures of the 355 timing marks & how to line them up or are they posted
    somewhere that I can't see them
    I am looking everywhere
    redcar
  17. plugzit
    plugzit F1 Veteran
    7,779
    Redondo Beach, CA
    Bruce Bogart
    Start by looking for the notch behind the first cam bearing cap on each cam, engine at TDC.
  18. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,328
    Palos Verdes
    Vince V
    I was told that Hill bearings are designed for replacement every other major, but it truly depends on how the car is driven, if at all, during the 5 year interval between majors. Drive it consistently, but not excessively. Not too many track days. Not too much red line time. Keep the engine bay dry and garaged. Should be good for 10 years, Hills' stuff is that well made. That's what I'm planning.
  19. 355redcar
    355redcar Karting
    71
    thanks to all that sheared my concern on my f355
    redcar
