Tesla charger for 296? | FerrariChat
Discussion in '296' started by tontondavid, Aug 13, 2024.
  1. tontondavid
    tontondavid Karting
    Sep 19, 2022
    101
    David Leng
    Hello,
    Does anyone know if one can use a home Tesla charger to charge the 296? Of course using the proper adapter.
    Thanks.
  2. mkraft3003
    mkraft3003 Formula 3
    2,389
    Tampa, Fl
    Sure you can use it but you run the risk of doing major harm. Why not use the OEM one which regulates the charge.
  3. soulsea
    soulsea Formula 3
    1,390
    29464
    Don't.
    Caeruleus11 and mkraft3003 like this.
  4. tontondavid
    tontondavid Karting
    Sep 19, 2022
    101
    David Leng
    Because I have an installed Tesla charger in my garage so instead of plugging in the OEM one, I thought I could use the one I already have on the wall.
  5. mkraft3003
    2,389
    Tampa, Fl
    With the complexity of the hybrid system and the fact that the car is very finicky I would not chance it. The OEM is only 110 and not 220. I have mine plugged into the regular 110 outlet and have never even tried using my CCS charger. I think the manual even says to only use the OEM.
    jm2 and Caeruleus11 like this.
  6. tontondavid
    tontondavid Karting
    Sep 19, 2022
    101
    David Leng
    I guess you're right.
  7. CinciOptics
    CinciOptics Karting
    Nov 10, 2022
    153
    James B
    I have an adapter for my mach e to tesla and still didn't do it. Probably works but why risk it.
    Caeruleus11, bamaman and tontondavid like this.
  8. q8ferrari
    q8ferrari Rookie
    Jun 25, 2006
    29
    Kuwait
    i am using a porsche wall charger everything is fine, u can use it.
  9. ShadowLAP
    ShadowLAP Formula Junior
    May 15, 2017
    590
    SW Suburbs of Chicago, IL
    Lawrence P.
    I have Tesla wall charger with 220v/48a service to charge my Model Y. Are you planning to use 220v to charge the 296? I have a 296 GTS on deposit waiting for my Allocation to come up. I thought they charged, as my current 458 Spider does, on 110v in the US.
  10. tontondavid
    tontondavid Karting
    Sep 19, 2022
    101
    David Leng
    That is my case as well. That is why I asked but most people on this forum said not to use it out if precaution.
    I'm pretty sure it's fine as well but I'm using the one that came with the car.
    BigJay2050 and Caeruleus11 like this.
  11. jordanfsl
    jordanfsl Formula Junior
    Dec 11, 2010
    722
    Los Angeles
    The battery in the 296 is small and only needs a 110 outlet. I wouldn’t personally run anything higher to it, that just sounds like a bad idea given Ferrari electronics….and there is no need.
    Caeruleus11 likes this.
  12. ZubayrC
    ZubayrC Karting
    Apr 1, 2024
    83
    Middle East
    Nice!
    I have a Porsche wall charger outside that I use for my Taycan, was going to use that for the 296 since i dont have a mains-plug outside, but I wasn't sure if it would have any problems.
    Can I ask, how long have you used the Porsche charger for on the 296? Have you had any charging problems?
    Thanks!
  13. q8ferrari
    q8ferrari Rookie
    Jun 25, 2006
    29
    Kuwait
    I have been using it since feb 2023 and no issues at all
  14. Dino_Argento
    Dino_Argento Formula Junior
    Sep 22, 2017
    290
    London
    Dino Diary
    The 296 user manual actually mentions that you can use commercial/ public charging stations if necessary so don’t see why it would be an issue.
    BigJay2050 likes this.
  15. Caeruleus11
    Caeruleus11 F1 World Champ
    11,631
    It’s just an abundance of caution. These parts communicate with each other, if there is a fault, you are making it easier to deny possible warranty coverage. Why do it when they provide you the charger?
  16. Magneto
    Magneto Rookie
    Apr 13, 2022
    24
    Al
    Caution is no doubt good but I don't think using a commercial charger would void the warranty, and please correct me if I'm wrong about this.
    All charging stations talk to the EV when plugged in and before the charging cycle begins, they negotiate parameters like voltage, current and power via standard protocols (IEC 61851 / ISO 15118). Today the possibility of breaking anything in an EV when using a charger that fits the plug, should theoretically be zero, in fact if the vehicle or protocol are not fully recognized, the charge cannot begin.
    That is not to say that one should do experiments recklessly, just that I do not see an immediate reason for things to break, charging systems have been designed to handle events like plugging in unsupported EVs (and this shouldn't even be the case here). So worst I can see it happening, is the charging station not initiation the charging cycle.
    tontondavid and rmmcdaniel like this.
