Test Device for Waterpumps | FerrariChat
Discussion in '308/328' started by Martin308GTB, Mar 17, 2016.
  1. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,301
    Black Forest Germany
    Martin N.
    #1 Martin308GTB, Mar 17, 2016
    Hello together,
    since I had a few waterpumps commissioned for rebuild and/or conversion, some weeks ago I decided to make a simple testing device for checking, whether all is leak free.
    I wanted something I could look inside to check, that it's filled with antifreeze and as little air as possible.
    So I made it from PMMA ( Plexiglas, acrylic glass ) . The first one literally 'exploded' while testing (without pump) when applying pressure at 8 bar :) because I forgot to regulate down my compressor. Calculations with the tensile strength values of the PMMA glue did prove, that I should better have avoided this pressure.
    But the second try worked and stands 4 bar without problems. That PMMA glue is amazing.
    There is one bore for filling, one for bleeding and a truck tire valve to pressurize.
    Now I can test my waterpumps for leak tightness with pressure of 1 bar for one hour.
    Best Regards from Germany
    Martin
  2. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
  3. energy88
    energy88 Three Time F1 World Champ
    32,754
    West of Fredericksburg, VA
    Clever! Can you also rotate the water pump shaft during testing to check for any out-of-round, flatness, or alignment anomalies that may be present within the assembly?
  4. Martin308GTB
    Jan 22, 2003
    4,301
    Martin N.
    This is also possible, though I check for axial and radial runout of the shaft, the bearing seat and the seal seat, while rebuilding the pumps. Or prior to cutting work on the shaft and housing for the conversion of the old two piece seal version to the one piece seal.
    I aim for max. 0.01mm (0.0004") axial and radial runout tolerance, what's the instruction of the seal and bearing manufacturer.
    That said, I always like to mention, that repro shafts - I once purchased one - have up to decuple radial runout tolerance between bearing and seal seat (0.1mm, 0.004")
    Best Regards
    Martin
  5. fatbillybob
    Aug 10, 2002
    29,302
    socal
    Excellent! I like the design. Don't you want to test for higher? The cap might blow at 1bar but somtimes people use higher pressures like 1.3 for a reason. Anyone know what industry test procedures are?
  6. antoninosavoca
    antoninosavoca Formula Junior
    Aug 9, 2011
    283
    Montesilvano Italy
    antonino savoca
    Fantastic work , Martin !!!!!
  7. Martin308GTB
    Jan 22, 2003
    4,301
    Martin N.
    Maybe I go up to 1.5 while testing, but I don't want to stress the seal's rubber bellow much more, than what it was designed for.
    Best Regards
    Martin
  8. Martin308GTB
    Jan 22, 2003
    4,301
    Martin N.
    I just had a look onto the engineering drawing I once got from the seal manufacturer, whose seal I use for the conversions. They determine the leak rate at a test pressure of 1.9 bar.
    Best Regards
    Martin
  9. SeattleM5
    SeattleM5 Formula 3
    1,266
    Kirkland, Washington
    Ettore Palazzo
    This is great Martin! Nice work.
    Sent from my SM-G900V using Tapatalk
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #10 2NA, Mar 17, 2016
    I have a similar fixture that I use for 355/360 pumps.
  11. SeattleM5
    SeattleM5 Formula 3
    1,266
    Ettore Palazzo
    Martin, I'm curious, what prompted the development of testing apparatus? Were you having problems with leaks using the new one piece seal?
  12. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,834
    Cerritos, CA.
    1.5bar is like 22psi, that might be too high but if doesn't leak, then you know it's very good.
  13. Martin308GTB
    Jan 22, 2003
    4,301
    Martin N.
    #13 Martin308GTB, Mar 18, 2016
    Ettore, not at all but I just like to test things as far as possible prior to bringing into service.
    Something like a last electrocardiogram, prior to leaving hospital :)
    During 35 years of industrial activities ( machining, engineering ) I experienced so many faulty machine components out of the box, since no manufacturer is immune against it. Even before China and others were part of the game. This leaves an impression.
    You once told, that you had problems with leaks before you tackled our conversion. With pumps from a professional rebuilder. Probably it would be a good thing, if he had testing equipment.
    Best Regards
    Martin
  14. 455Fosbery
    455Fosbery Karting
    Oct 3, 2013
    212
    Hi Martin,
    Great work and nice to have the visibility that this PMMA formulation provides.
    This may fall into one of those 'engineer with too much time on his hands' categories, but it would be interesting to source a current 'stock' part and then test it to determine performance versus your improved version, e.g., leak threshold as a function of pressure. Additionally, what about testing the impact of temperature?
  15. SeattleM5
    SeattleM5 Formula 3
    1,266
    Ettore Palazzo
    Indeed, it was my frustration with the "expert's" multiple unsuccessful rebuilds that led me to your method. As you know, I've now rebuilt several of the pumps with the single piece seal and wanted to make sure you weren't noticing problems with them. The first pump I rebuilt with this method remains in service on my 328 (two years and counting) and it gives me great pleasure to see those weep holes staying dry.
  16. Martin308GTB
    Jan 22, 2003
    4,301
    Martin N.
    Hi John,
    temperature impact would require a much more complex system. I just wanted a device for a quick leak test to avoid such surprises I once experienced with a current 'stock' part when it immediately leaked after installation.
    Regarding your proposal with comparing a current part with my conversion would not be very meaningful, I think, because I am certain, that the problem with the current available pumps is the variation in manufacturing quality. Say, one may be o.k. and the next can be faulty.
    Quality control is left to the customer.
    Best Regards
    Martin
  17. fatbillybob
    Aug 10, 2002
    29,302
    socal
    #17 fatbillybob, Mar 18, 2016
    How simple. I like that. I have been lucky. 39 plus years of rebuilding and never a leak. But I don't do many.
    Tim What do you use as a test pressure or what is your test procedure?
