TEST DRIVE VID. Finally. 308gtb with P6 cams and 10.5:1 cpr | FerrariChat
Discussion in '308/328' started by Ferraripilot, Oct 2, 2010.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,756
    Atlanta
    John!
    GrayTA came up today to go for a ride, and was therefore volunteered to hold the camera and add commentary and childish snickers about how cool this is now (who can resist!).
    Anyway, the car with these cams is very driveable, and to prove it, Patrick drove it himself to objectively compare against his QV. I am sure he will chime in after he has had a chance to reflect on today's face-melting session. Making this thing driveable was essentially a tuning twilight zone, so in the interest of keeping whatever sanity a person might have remaining, I suggest not doing this unless you really really really want to.
    Very pleased. Dyno next
    enjoy!
    http://www.youtube.com/watch?v=ogjKRhQua_w
  2. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,784
    Marin
    Geno
    That sounds awesome, all the hard work paid off. Great job man.
  3. 308 GTB
    308 GTB F1 World Champ
    11,650
    New Jersey
    Barry Wolinsky
    Very nice, John!!
  4. Ferraripilot
    May 10, 2006
    17,756
    Atlanta
    John!
    Thanks fellers.
    For you carb fanatics, my current jetting is as follows: 55 idles. F24 tubes. 200 air correctors and 135 mains. Still a shade lean! Running 36 degrees total ignition timing with 10 degrees at idle. Lots of timing coming in by 2500 rpm, say about 28 degrees.
  5. GrayTA
    GrayTA F1 World Champ
    15,130
    Deep South
    PDG
    Finally getting on here to give my commentary.
    I have long heard that the P6 cams were unstreetable as well. After driving it I have come to really understand a LOT more about this buildup. The power comes on really strong the higher you push it. I was really surprised at the torque difference between this engine and my QV. I know, the carbs vs. FI will make a difference, but this thing pretty well screams!! The throttle response was pretty amazing - I thought my QV was pretty responsive, but John has me beat there too.
    What I felt was that below 3k the engine had a lot of overlap due to the cams, so it spat and sputtered a little bit - but nothing that was unmanageable at all - once I had a few minutes behind the wheel. From 3k it seemed to even out a bit, then above 4.5k or so that thing pulled like a freaking freight train!!! There was seemingly no end to the powercurve - at least not that I was willing to reach in someone else's car.
    I had a blast!!! Thank you for the opportunity to drive it!!!
    PDG
  6. viper_driver
    viper_driver Formula Junior
    Jan 1, 2009
    978
    Vegas
    Jason
    sure sounds good.
  7. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,784
    Marin
    Geno
    remind me what changes you made to jetting
  8. Papa G
    Papa G Formula 3
    Dec 29, 2003
    1,406
    Sounds great, thanks!
  9. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,004
    Cape Town South Afri
    Dave
    Finally we have some real life proof !!! Where is " Paul " ( artvonne ) he must be enjoying this ???
    Well done John you certainly stuck at it .
  10. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    WOO-HOOO!!!
    Hard to get a visceral feeling from a video but it sure sounds good.
    Rick
  11. Ferraripilot
    May 10, 2006
    17,756
    Atlanta
    John!
    I have been all over the map with plugs and jetting. From BP7ES- BP9ES back to BP7ES, and am now using a surprisingly hot BP6ES. The F24 tubes throw so much fuel into the chamber that they cool the plugs partially causing much of the stuttering which baffled me forever as I was trying to fix the stuttering issue with jetting. Turns out it needed to be a combo of both while using a specific timing curve. What jets where when and with what plugs, I can't recall now as I tried so many combinations.
    Before this rebuild, I had F36 tubes with 140 mains, 190 ac and 55 idles. The F24s change everything so basically throw whatever you think you know out of the window when they go in.
  12. hinton308
    hinton308 Formula Junior
    Jul 13, 2009
    299
    Gaffney, SC
    Don Hinton
    Great video John!!
    Don
  13. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,517
    Avvocato
    just curious of the under 3,000 rpm spudder - do you need to drive it at over 3,500 constantly then ? great video - i see the car on the video was always 4,500 and over and sounded great in the cabin.
  14. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Oh man, that sounds sooo sweet.
    You did a great job on her John.
  15. GrayTA
    15,130
    Deep South
    PDG
    I dont think thats really completely the case. My mention of it probably overstates it a bit. Its just a really noticeable difference once it hits 2750-3000 in the smoothness. You dont have to keep it up that high at all. I was surprised at how tractable it was given all the rumors and stories of this type combination. Yes, it definitely likes the higher RPMs, but thats it.
    PDG
  16. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,784
    Marin
    Geno
    not to hijack your thread but i have
    F36, 200ac, 60 idles and 125 mains
    i was able to tune out (painfully) almost all the midrange stumble with the 55's but then for the fun of it put 60's in and the stumble was gone.
    The things seems to run right, but i would like to check the air fuel ratio to see if I am rich or lean, bc I am not certain. I dont have near the level of skill you do, so what is the best way? take it to a dyno? read the plugs (i can do that pretty well). Appreciate the insight.
  17. Ferraripilot
    May 10, 2006
    17,756
    Atlanta
    John!
    not at all. glad to talk about this stuff! I am certainly no expert, but I have made good on understanding what is what with these carbs and engines.
    With your cams, I suggest at least a 135 or 140 main with your 200 ac. Remove the 60 idles and replace with the 55s as if you go to either of those main jets than they will meter plenty of fuel for the idle jet channel for 55s to work well. The main is where everything comes in through, so more through the main often means less idle jet is required. Understand these mains will not allow you to pass emission, so when you need to do that obviously swap back to your 125s, get it hot and do the test.
    The plugs should have a thin base soot ring deep inside the ceramic insulator at the base. This is where wide open throttle testing and max power is read. Open up the engine in 3rd gear with a fresh set of plugs (old plugs are difficult to read), pull a plug after you shut down which should be immediately after the WOT run and then read what you have at the base of the insulator. 125s are going to be far too lean and I promise you will feel a difference with 135s or 140s. You probably have 15bhp hiding in there right now.
    If you want a set of early cams, I have mine sitting around. Shoot me a PM if you want to get them in to get some more scoot! I understand the obsession lol.
    -john
  18. Ferraripilot
    May 10, 2006
    17,756
    Atlanta
    John!
    The big difference is you cannot mash the gas pedal below 3k rpm or you will get stuttering, but you don't have to really nurse it either. I drive it below 3k often and usually stick below it as best I can until the engine oil is warm. There is no really getting on it in that rev range, but then again the stock cams barely allow you to get on it at that rpm too.
  19. MS250
    Dec 10, 2003
    26,517
    Avvocato
    thanks for the clarification guys - under hard load the rev up it did sound more aggressive, and i heard in the video that there was more torque felt, which the 308 is missing. if you have more vids, would love to see them , thanks for sharing your findings on this project.
    maybe a silly question (s) what grade and type of motor oil are you using now ? And how did the tranny feel with the extra torque on tap?
    thks !
  20. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,784
    Marin
    Geno
    so would you guess I am running lean at WOT with my 125's? Its definately running a little rich at little, but it sits there an purrs nicely...
  21. Ferraripilot
    May 10, 2006
    17,756
    Atlanta
    John!
    Tranny feels fine. Shifts very well. The extra torque is about 1k higher than in a stock car but maintains what a stock motor makes below that.
    As for oil, I am running 15w/50 mobil 1. During break in I used 10w-40 regular oil and changed it twice after a period of say 400 miles break in. Rings are set really well.
  22. Ferraripilot
    May 10, 2006
    17,756
    Atlanta
    John!
    yeah 125s are way too lean for modern fuel
  23. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,784
    Marin
    Geno
    <calling pierce manifolds in the morning>
  24. AJS328
    AJS328 F1 Veteran
    Apr 23, 2003
    7,520
    New Jersey
    Augustine Staino
  25. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,784
    Marin
    Geno
    cloudy few days in northern cal, so I pulled the 125 mains and 60 idles and put in 135 mains and 55 idles. Backed out the mix screws a little and took her for a drive. The 135's definately feel wetter above 3k, so that was a very good call. Seems like it wants just a little more fuel below 3k.....its almost there. Going to drive it around all weekend and see, didnt have a chance to reall wring it out before the sunset, but overall moving to 135's was a great call.
