Test Drove 328 - Damn-warning lights lit up | FerrariChat
Discussion in '308/328' started by 4re4me, May 3, 2007.
  1. 4re4me
    4re4me Formula Junior
    Jun 12, 2006
    485
    Wickenburg, AZ
    Barbara
    While test driving an 87 328 - the yellow light came on to the far right in dash- looked like a possible fan light. Then the red light came on that said slow down - not good. The mechanic diagnosed as the ignition coil went up.
    The yellow light did eventually turn off. Considering buying this car - opinions please. Thanks
  2. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Not a good omen!! I would want an iron-clad warrantee on that car if I bought it, particularly the slow down light issue.
  3. barcheta
    barcheta F1 Rookie
    Nov 15, 2003
    3,738
    Maryland
    Jim
    good thing is that there isn't anything new with these cars..... most of the issues are easily diagnosed by a trained mechanic. GET A PPI. The fan light is also something that could be easily fixed... the guy you have diagnosing is one of the best in the business. His word and reputation precedes him
  4. nero328gts
    nero328gts Karting
    Dec 5, 2006
    235
    slow down light is common and good to know it works you definitely need to determine whats causing that and have it corrected does it stay on or does it go off when you slow down?
  5. 4re4me
    Jun 12, 2006
    485
    Wickenburg, AZ
    Barbara
    As we slowed the light would go off but would flash a bit. Mechanic diagnosed as ignition coil - there are 2 and 1 needs replacing. Car lost power as well - did what is was suppose to do and shut a bank of cylinders down.
    Better it happened B4 I purchased.
