Test pipes being put in..keep old cats? | FerrariChat
Discussion in '308/328' started by climb, May 8, 2007.
  1. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    Took my 308 to this Austrian guy that's worked on every car i've had for 15 years now. He's got a muffler and a body shop as well as a repair facility and specializes in euro cars.
    Wanted him to work on the exhaust to make it sound better but on a budget.
    Turns out one cat was clogged (toast) and the other sounded like glass was loose on the inside(double toast). You could feel more air coming out of one side than the other.
    I wanted to put in two magnaflows and run them out the standard holes in the lower rear valence. He suggested two test pipes that he'd fabricate and just use the standard can exhaust. Said if it smells bad then it's the CIS system that will need be looked at or just live with it.
    Does he need to drill a hole in these pipes for the o2 sensor and what about the other two wires that originally went to the cats? Do i wanna keep the original cats just in case?
  2. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    What year 308? Which K-jet system you have is important for this question (lambda versus non-lambda)
    Birdman
  3. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    Oh..i see. '80 308.
  4. Brunello
    Brunello Formula Junior
    Sep 10, 2005
    250
    Vancouver, British C
    Al
    Depending on how deafening you want your car to sound, I would recommend you install two magnaflow mufflers instead of the strait test pipes. Unless of course you want to race the car. I tried straight test pipes on my car and it was far louder than I could stand for any length of time. Lastly, you can have the sensor installed by your muffler guy. I don't have a 308 and so I would not know about which connectors could be left off the system entirely. Suffice to say that the magnaflows to another muffler is doable but also check for any problems you might have with your local emissions control authorities you may need to get your car tested and in this regard it could fail the test.
  5. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    I plan on running the test pipes into the black can muffler. It'd just be without the cats and have test pipes in lieu of the cats with the standard muffler. Florida doesn't have emissions. The cats are toast and the car passed emissions in VA last year even with the bad cats.
  6. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    Got the car back and WOW! What a difference.
    Love the car and loved the sound at higher revs. Now it sounds great all over the tach. Yeah it has a little exhaust smell but not too bad and well worth it.
  7. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    17,074
    Wellington, FL
    Duane
    Do a search, I seem to recall a source for rebuilding cats. Would be nice to have them rebuilt and saved for future use, if needed.
  8. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    If the cats are fine, hold onto them....they're Expen$ive to replace. I 'dropped' mine. The sound is great, but rumor has it cat-less cars with Tubis/Stebros sound the best....
    BTW, I have an 84 with Lambda....
  9. D.Mauro
    D.Mauro Formula 3
    Jun 18, 2006
    1,266
    Cumming/ Hlwd Fl
    Dominick
    Thermocouples just wired them up out of the way no need for them since you remove the cats.
  10. D.Mauro
    D.Mauro Formula 3
    Jun 18, 2006
    1,266
    Cumming/ Hlwd Fl
    Dominick
    I have Stebro's and test pies on both cars the sound is great!
  11. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    That's what he did. Said the cats are three way and need the air from the pump to work right. On '80 with the oil burning issues and the air pump being disabled he thinks destroys the cats.
    Finally got a good drive in today between the rain showers...oh man.
