Testa Brake Pads??? | FerrariChat
Testa Brake Pads???
Discussion in 'Technical Q&A' started by barabus, Feb 25, 2006.
  1. barabus
    barabus F1 Rookie
    Aug 22, 2004
    4,777
    12 Cylinder Village
    Si
    Am looking to get some better brake pads for the Testa can anyone recommend any????
  2. tvu
    tvu Formula 3
    1,361
    Southern California
    Trieu
    William H always recommended Porterfield, and that's what I'll get when it's my turn to change brake pads.
  3. barabus
    barabus F1 Rookie
    Aug 22, 2004
    4,777
    12 Cylinder Village
    Si
    Thanks, does he recommend which ones???
    Pad Maker Compound Make Model Year Front Part Number Front Price Rear Part Number Rear Price
    Porterfield R-4 1985 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R-4 1986 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R-4 1987 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R-4 1988 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R-4 1989 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R-4 1990 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R-4 1991 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R4-E 1985 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R4-E 1986 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R4-E 1987 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R4-E 1988 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R4-E 1989 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R4-E 1990 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R4-E 1991 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R4-1 1985 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R4-1 1986 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R4-1 1987 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R4-1 1988 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R4-1 1989 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R4-1 1990 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R4-1 1991 FERRARI Testarossa AP82 $ 99.95 AP32 $ 110.95
    Porterfield R4-S 1985 FERRARI Testarossa AP82 $ 79.95 AP32 $ 69.95
    Porterfield R4-S 1986 FERRARI Testarossa AP82 $ 79.95 AP32 $ 69.95
    Porterfield R4-S 1987 FERRARI Testarossa AP82 $ 79.95 AP32 $ 69.95
    Porterfield R4-S 1988 FERRARI Testarossa AP82 $ 79.95 AP32 $ 69.95
    Porterfield R4-S 1989 FERRARI Testarossa AP82 $ 79.95 AP32 $ 69.95
    Porterfield R4-S 1990 FERRARI Testarossa AP82 $ 79.95 AP32 $ 69.95
    Porterfield R4-S 1991 FERRARI Testarossa AP82 $ 79.95 AP32 $ 69.95
    PFC 80 1985 FERRARI Testarossa, GTO 082.15.04 $ 90.66 082.15.04 $ 90.66
    PFC 80 1986 FERRARI Testarossa, GTO 082.15.04 $ 90.66 082.15.04 $ 90.66
    PFC 80 1987 FERRARI Testarossa, GTO 082.15.04 $ 90.66 082.15.04 $ 90.66
    PFC 80 1988 FERRARI Testarossa, GTO 082.15.04 $ 90.66 082.15.04 $ 90.66
    PFC 80 1989 FERRARI Testarossa, GTO 082.15.04 $ 90.66 082.15.04 $ 90.66
    PFC 80 1990 FERRARI Testarossa, GTO 082.15.04 $ 90.66 082.15.04 $ 90.66
    PFC 80 1991 FERRARI Testarossa, GTO 082.15.04 $ 90.66 082.15.04 $ 90.66
  4. tvu
    tvu Formula 3
    1,361
    Southern California
    Trieu
    Here's an excerpt from their website on the different description.
    Since I'm not tracking mine, I will be just sticking with the R4-S all around.
    Maybe William H can chime in. He did suggest to put the most aggresive pad in the back to stabilize the tail under hard braking, but I'm unsure if that means R4-S in the front, and R-4 in the back.
    Good luck.
    R-4 Full Race Compound
    Designed specifically for heavy-duty motorsports. The carbon based semi-metallic R-4 materials allow the pad to absorb tremendous amounts of heat and dissipate it at very even rate. Carbon Kevlar material warms up to race temperature quickly, which is quite helpful during restarts, and when track time is limited. When used with cast iron and steel alloy rotors, the R-4 compound requires minimal bed-in period. Throughout the entire heat range, the carbon kevlar material will give extremely consistent modulation and predictably. This is truly the most rotor friendly racing brake pad material ever. Good for road courses, oval track, rally, vintage racing, autocross, club events or professional racing events.
    R4-E Endurance Race Compound
    A carbon kevlar compound made to last a bit longer than the original R-4 compound. The R4-E compound is designed to endure higher prolonged temperature and still has pad life as long or longer than Porterfield R-4 do. This pad is great for club enduro events and applications where temperatures are at their maximum.
    R4-1 Vintage Full Race Compound
    Developed using knowledge testing in the vintage racing community. Optimum uses for the R4-1, under conditions where very high friction is needed with minimal warm up time and in applications where there is difficulty in maintaining sufficient heat with conventional race pad compounds. Widely used on vintage GT and formula cars the R4-1 is also gaining popularity in off-road and rally-cross classes. Great modulation, consistent pedal feedback and rotor friendly at all temperatures as with all the other Porterfield Carbon Kevlar compounds.
    R4-S High Performance Street and Autocross
    For high performance and heavy-duty street conditions. Perfect for prolonged everyday street use while also being capable of tolerating the most severe street use without any fade. Rotor friendly of course. The R4-S friction level will give you an impressive increase in stopping ability with very minimum pedal effort. R4-S compound has the absolute lowest noise and dust levels, far below OEM equipment or any other high performance brake material. Good for autocrossing, some drivers schools, solo events, and rally’s. The R4-S compound is available for virtually any vehicle sold in the US. We also offer the R4-S in pad sizes for competition type calipers that are used under street driven conditions.
  5. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,469
    Michigan
    Jerry Wiersma
    I put the R4-S pads all the way around on my TR and they work excellent.
  6. steve f
    steve f F1 World Champ
    Mar 15, 2004
    12,119
    12cylinder town
    steve
    I am watching you just dont buy the cheap ones
  7. ASG 86TR
    ASG 86TR Formula 3
    Aug 23, 2001
    1,474
    New Jersey
    Adam G
    I use the EBC GreenStuff for normal driving and Redstuff for the track. The Green stuff produces very min dust and is squeek free.
