Testarossa (87) cooling fan issues | FerrariChat
Discussion in 'Boxers/TR/M' started by alex_kay, Apr 7, 2024.
  1. alex_kay
    alex_kay Karting
    Apr 7, 2024
    69
    Central Switzerland
    Alex
    Hi, I am new to the forum. Four weeks ago I bought an 87 Testarossa. Amazing car and it was a dream of mine.
    Now I have several questions and I would be very happy if someone could help me out.
    1. My driver's side radiator cooling fan doesn't kick in. The passenger side radiator cooling fan kicks in as it should. I can hear it, see it move and I can feel the air being sucked in on the passenger side side strakes. On the driver's side none of it. What can the problem be? The fuse, a relay or the fan? are that all possibilities? I presume the Radiator Thermo Sender (Temp Switch) works fine. Otherwise the passenger side fan wouldn't kick in. Or am I missing something?
    2. When do the oil cooler fans (passenger side, two fans) kick in? At what oil temperature? I didn't see them moving but so far my oil temp has not really gone above 80 degrees (celsius, 176 Fahrenheit).
    3. Is it normal that the radiator cooling fans go off when you turn off the engine and ignition? In mine they immediately go off. If I turn the ignition back on the fans immediately kick back in. I am used to more modern Porsche 911 models (I have a 997.1 Turbo, manual). And with them the fan just keep running to cool the engine bay even with ignition turned off.
    Has anyone had any experience with e.g. changing it so the fans stay on with the ignition off at high temps?
    Thank you guys for any help. It is greatly appreciated. I have already searched the forum and found some questions sort of related to mine and it already helped me. But nobody so far seems to have asked my specific questions.
    Best, Alex
  2. Rifledriver
    37,121
    #1 reason for a fan failure is a bad, burned connection at the output connection of the fuse panel. Very common. Its advisable to install off board relays for both fuel pumps and both radiator fans.
    No need for fans continuing to run after the engine is shut off. The heat of the engine will go down on its own and a fan is no longer required.
    I do not recall the operating temp of the oil fans but its uncommon for them to run except on hot days. They were considered rather superfluous anyway. On 512 TR for most markets there was no oil cooler fan. With the size of the cooler it would be pretty surprising if the oil ever got to any dangerous temperature unless it was being caused by a bearing failure in which case a cooler with or without fan will solve nothing. The biggest oil temp issue is not getting hot enough.
    alex_kay likes this.
  3. alex_kay
    alex_kay Karting
    Apr 7, 2024
    69
    Central Switzerland
    Alex
    Thank you very much for the answer. That helps. I will get to work.
  4. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,071
    Troy, Michigan
    James
    I have the SRI fuse box with the high load currents off the main panel. I highly suggest any new testarossa owner to consider this improvement. I’ve never had a fuse box issue in ten years and 26,000 miles.
    where are you located?
  5. alex_kay
    alex_kay Karting
    Apr 7, 2024
    69
    Central Switzerland
    Alex
    Thanks for the suggestion. Do you have some photos of how you did it?
    I am located in Switzerland
  6. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,547
    romano schwabel
    hello alex
    would be great if you could introduce yourself a little that we know on which technical level you are.
    what part of CH you are? I´m at the border to CH near basel on the german side.
    as you think right the thermoswitch ( there is only 1 for both radiator fans ) is working fine.
    fastest way first have a look at the fuse box if something is melted or burnt. also remove the relais and have a look at the connectors. if all seems ok then next to test is to put 12 V plus and minus direct to the fan and see if it will run or not.
  7. Steve Magnusson
    26,841
    #7 Steve Magnusson, Apr 7, 2024
    I'll post this again for your reference -- these are the 5 TR stock fuse-relay panel terminals (in the horizontal white connectors at the bottom) that usually get fried (and the connectors have to be unplugged to see the trouble):
    Usually the HVAC Power terminal fries first, followed by the fuel pump terminals, and then the radiator fan motor terminals. If those others are all fine, and only one of your radiator fan motor connectors is fried = you would be the exception (wouldn't surprise us at all if you get in and find some wonky fixes/repairs have already been made to the others).
    Try a search on "fuse-relay panel" in the Boxer/TR/M section for many prior threads and descriptions of your options to fix or upgrade to a different fuse relay panel solution (Guido's, G.T. Carparts, Scuderia Rampante)
    alex_kay and turbo-joe like this.
  8. alex_kay
    alex_kay Karting
    Apr 7, 2024
    69
    Central Switzerland
    Alex
    @turbo-joe and @Steve Magnusson Thank you very much for your help.
    Here is a little introduction about me: I live in central Switzerland around the Zug area. My technical skills are fairly limited but I find my way around and for the more complex things I bring the car to a shop. I have a long car history and this Testarossa is my first Ferrari :)
    I will have a look at the things you both mentioned
  9. turbo-joe
    Apr 6, 2008
    9,547
    romano schwabel
    and hopefully tell us ( may be with photo ) what you found - if you will find some. wish you all the best
    and gradulation to your 1st ferrari - a real one with 12 cylinder :)
  10. EDoug
    EDoug Formula Junior
    Apr 19, 2005
    271
    Southern Florida
    Alex, I had a similar issue on my 1986 Testarossa, except the right- side fan did not run. As I worked through the potential failure modes, I got to the fan relays and swapped the left and right relays to see if the problem just followed the relays. As it turned out, both fans then ran just fine. I swapped the relays back to their original locations and both fans continued to run fine. My conclusion was that the action of unplugging the relays and reseating same wiped the right relay and circuit board contacts resulting in good contact. BE EXTREMELY CAREFUL UNPLUGGING ANYTHING ON THE CIRCUIT BOARD AS IT IS OLD AND FRAGILE. EDoug
    turbo-joe likes this.
  11. Grease Donkey
    Grease Donkey Karting
    Jul 5, 2018
    120
    Zurich, Switzerland
    There are some diverging options on cause and consequence.
    IMHO it's the fans (and fuel pumps) that cause an overcharge (actually rather an over-amperage) on the fusebox / circuit board. Changing fuse boxes or circuit boards is only curing the consequence not adressing the cause.
    I've changed both fuel pumps and fans some time ago and have never had any issues with the fusebox again (I did change the relays). Parts are priced very reasonably. Part number for the fans is Spal Kühlerventilator 2330m³ saugend D315-D280 T=94 / VA03-AP70/LL-37A 12V
    PS: As you live in central Switzerland you certainly must know U = R * I (Ohms law, which is the technical treason for my diverging opinion: At constant voltage the amperage has to increase if the resistance is increased in the old appliances).
    PPS: Don't hesitate to reach out by PM
  12. Steve Magnusson
    26,841
    You have a whole different understanding of mathematics and physics :rolleyes:
    71veedub and Rifledriver like this.
  13. Grease Donkey
    Jul 5, 2018
    120
    Zurich, Switzerland
    :oops:
    At a constant voltage, old electrical motors may need more amps to operate. This is because an increase in resistance or inefficiency within the motor will result in higher current draw to maintain the same level of power output.
    According to Ohm's Law (V = I * R), where V is voltage, I is current (amps), and R is resistance, if the resistance within the motor increases (which can happen due to wear and tear, inefficient design, lack of maintenance, etc.), the current (amps) must increase to maintain the same voltage.
    So, even at a constant voltage, if the motor becomes less efficient or more resistive over time, it will draw more current to compensate, resulting in higher power consumption.
    :rolleyes:
    Over to you @Steve Magnusson o_O
  14. Steve Magnusson
    26,841
    Completely wrong. V = I * R means that if R goes up, the I goes DOWN at the same voltage V.
  15. Grease Donkey
    Jul 5, 2018
    120
    Zurich, Switzerland
    Sorry. I was using resistance with 2 meanings.
    Meaning 1 (mechanical resistance):
    In an old electrical motor the resistance of the components increases as bearings wear, magnets loose strength and [...], thus more torque is required to keep the motor running.
    Meaning 2 (electrical resistance; Ohms Law)
    If you need you need to produce more torque, you need more power. Assuming that Voltage is constant you need to increase current.
    Common ground?
  16. lagunacc
    lagunacc F1 Rookie
    4,422
    He must be thinking of heat
  17. Steve Magnusson
    26,841
    Yes, but your logic is still wrong. If the mechanical rotating resistance of the motor spindle goes up = the RPM of the motor goes down = the back EMF generated by the motor at that lower RPM is lower = the effective "electrical resistance" of the motor goes down = the current goes up at the same applied voltage. However, once a terminal is burned up, if that is the cause, it doesn't "fix" the the burned up terminal.
  18. Rifledriver
    37,121
    I have been fixing fans and fuel pumps and boards and measuring the loads in Testarossas since 1985. While it is true, sometimes a fan but far more often a pump in the process of going bad increases the load to the point it damages the connector and sometimes the board itself it is far more common by a large factor that the connector and board is damaged and the load placed upon them after repair by the pump or fan is normal. It was a terrible connector design. It had very little surface area and depended too much on its modest spring pressure to maintain contact. A standard 1/4 inch spade would have been far superior.
  19. Grease Donkey
    Jul 5, 2018
    120
    Zurich, Switzerland
    Ok. Let's agree to disagree then. In my universe electical motors draw more current as they get older. In yours not.
  20. turbo-joe
    Apr 6, 2008
    9,547
    romano schwabel
    this only will happen if there are too much amps or bad connection that you may see in the night even some sparks. if it would be a problem of the motor to need more amps/voltage the fuse will burn
    Grease Donkey likes this.
  21. Grease Donkey
    Jul 5, 2018
    120
    Zurich, Switzerland
    Part of the issue is, that as old electrical motors draw more current (in my universe) than specified, the surge of the current still is not fast enough to overheat the fuse and thus break the curcuit. This then leads to the melting of the connectors. Under specific circumstances this can result in fire.
    A lot of the cars from the 80s and 90s have this problem to some degree. On Porsches of this period it's often the aircondition blower ....
  22. Steve Magnusson
    26,841
    No, I agree with you that an electric motor with more mechanical drag draws more current at the same applied voltage (and tried to explain why). You just keep using terminology that is completely wrong like: "more torque is required to keep the motor running". DC brush-type electric motors do not "require torque" -- they produce torque.
  23. Grease Donkey
    Jul 5, 2018
    120
    Zurich, Switzerland
    As we agree that there is higher current on old electrical motors, I continue to promote the pre-emtive swapping out of both fans and fuel pumps before replacing the fuse box. Contacts in the fuse box will have to be thoroughly cleaned as Steve pointed out correctly. :)
    I've replaced the electrical motors on several cars from different manufacturers which had fuse box issues. It works, is closer to the factory spec and is more cost effective.
  24. alex_kay
    alex_kay Karting
    Apr 7, 2024
    69
    Central Switzerland
    Alex
    Thank you very much. That greatly helps. I will change the non working fan or even both. Will have a look at it.
    Just to make sure:
    a. The Spal VA03-AP70/LL-37A is equal to Ferrari parts no 137260 (previously 131410)?
    b. In the US the SPAL seem to have different parts numbers. So the Spal VA03-AP70/LL-37A is also equal to the SPAL 30102054?
  25. Grease Donkey
    Jul 5, 2018
    120
    Zurich, Switzerland
    Very honestly: I don't know.
    I'm quite confident that the details I gave are the ones we installed on my '89.
    They still seem to be available on ebay.
