testarossa battery dying | FerrariChat
Discussion in 'Technical Q&A' started by Drew_4RE, Aug 21, 2009.
  1. Drew_4RE
    Drew_4RE Formula 3
    Dec 19, 2005
    2,292
    FL
    Drew
    So the testarossa is done over heating.
    But now, I take it out, brand new battery, and it dies once the car is stopped and turned off.
    Alternator? Sure sounds like it but wanted to check here first.
  2. fatbillybob
    Aug 10, 2002
    29,279
    socal
    charge battery to see if you can start car. No could be dead cell in new battery. Yes points to alternator. once running 1st test is if you get 13.8+volts from battery terminals implys alternator could be doing its job. If no check alternator. If yes and battery dies again your alt many not be putting out enough juice and it needs a real bench test.
