testarossa blower motor | FerrariChat
Discussion in 'Boxers/TR/M' started by cars30, Mar 22, 2007.
  1. cars30
    cars30 Rookie
    Aug 13, 2005
    18
    i have a testarossa blower motor stuck on high speed only ,is there a common fix for that problem. thanks
  2. Steve Magnusson
    26,826
    By "stuck" -- do you mean:
    1. full speed works OK, but the fan is dead when the speed control knob is set at any slower speed, or
    2. the fan always runs full speed regardless of where the control knob is set?
    If #1, the suspects are:
    A. power transistor bad
    B. micro fuse on speed control unit blown (but not all TR have this fuse -- there are three versions of the speed control unit)
    C. speed control unit bad
    If #2, this would be rather unusual, but the "full speed" relay could be stuck in the "closed" condition -- either a bad relay or a bad speed control unit always (wrongly) "telling" the relay to be closed.
    Please advise which symptom.
  3. cars30
    cars30 Rookie
    Aug 13, 2005
    18
    thanks blower motor works only on high it does shut off in any other possition.
  4. Engineer
    Engineer Karting
    Dec 22, 2004
    57
    I can confirm most likely cause is the power transistor. Replacements can be found at any electronics store for a few dollars, but the thing is buried inside the A/C ducting in the dash just right of center (at least on my '86 that's where it was). Sort of like they built the car around this piece. If you have a factory parts book it shows it on one of the last pages.
    Ron
    Stimorolgum likes this.
  5. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    You can change the transistor, just leave the old failed one in position and tie the new one up under the unit somewhere.. no need to attempt to put it inside the heater unit..
    part of the problem is that the transistor is mounted onto a heat sink... and that's fine if you use A/C all the time... but if you run the heater it gets the transistor hot!
    Buy a genuine transistor including the heatsink and connector etc.,.. and just plug it in and tie it up under the dash... hanging with the hot parts not touching anything of course...
    You need to access the forward part of the centre console... it's only a few screws... the whole job should take no more than 30 minutes.
  6. Boxer12
    Boxer12 Formula 3
    Jun 1, 2003
    1,672
    Mine worked on 'high only,' until I changed out the Bosch fuse (silver sq thing) in the fusebox. Works fine now. ;)
