Testarossa Brakes Require High Effort | FerrariChat
Discussion in 'Boxers/TR/M' started by EDoug, Apr 19, 2005.
  1. EDoug
    EDoug Formula Junior
    Apr 19, 2005
    269
    Southern Florida
    I am new to this forum. I have a late 1986 Testarossa that is experiencing a brake issue that I believe is related to the vacuum servo, but I am looking for validation or any advice out there. Recently, the brakes need a higher amount of foot pressure to make them perform. The car has low miles on it. The rotors are in beautiful shape and I believe the pads are fine with no glazing. I am about to change the brake fluid, but would like to know if anyone out there has experienced a similar problem and whether it was related to the vacuum servo or something else that I am not thinking about. If it is likely to be the servo, what is a good source, or can it be serviced? Thanks in advance for your reply.
  2. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,469
    Michigan
    Jerry Wiersma
    Mine are the same way since getting it out of storage last week. I haven't had a chance to look at them though as it's in the body shop getting the front end re-sprayed.
