Testarossa Cold /idle ok but car stutters when engine is hot | FerrariChat
Discussion in 'Boxers/TR/M' started by leslie_choo, Jul 15, 2017.
  1. leslie_choo
    leslie_choo Formula Junior
    Aug 5, 2012
    444
    Singapore
    BCChoo
    My car is doing fine when Cold /idle but car stutters when engine is hot .
    Any idea ?
    Before this happened , the right engine bank almost down. the right side ignition coil ticking sound is very loud . After some tuning , during idle and cold it's ok but the car stutters when car is hot. The ignition coil no longer ticking loud.
  2. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    Coil packs?
  3. leslie_choo
    Aug 5, 2012
    444
    Singapore
    BCChoo
    Need to test again with extra ignition coil . Btw if it's the coil issue normally do when change a pair ? Or the side that's faulty ?
  4. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,441
    romano schwabel
    first change from left to right side and otherwise to see if it is the coil issue. if so then it would be ok only to change the faulty one.
  5. leslie_choo
    Aug 5, 2012
    444
    Singapore
    BCChoo
    Thank you Joe .
  6. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,938
    Good advice
    The coil pack usually starts breaking down first when hot because either the fluid (that acts to cool) breaks down or the electronic module breaks down
  7. leslie_choo
    Aug 5, 2012
    444
    Singapore
    BCChoo
    The mechanic tested with new coil but the problem is there . :( So not the coil pack issue
  8. turbo-joe
    Apr 6, 2008
    9,441
    romano schwabel
    only new coil or also the electronic for the coil?
  9. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,254
    Mel
    Vacuum lines tested ?
    Sparkplug connectors ...
  10. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,938
    I would do the following:
    1. Borrow an oscilloscope and check the ignition on each bank (you can do it by putting the scope inductive probe first on the left-hand coil-to-distributor wire, then on the right-hand side). This will tell you if it is ignition-related
    2. if you still have the O2 sensors, back-probe a voltmeter into them to read the voltage. Best to use 2 (right-hand, left-hand) so you can observe voltage as it warms up. This will tell you if it is fuel-related
  11. leslie_choo
    Aug 5, 2012
    444
    Singapore
    BCChoo
    Thank you ! I will check accordingly
  12. leslie_choo
    Aug 5, 2012
    444
    Singapore
    BCChoo
    I changed the coil , everything runs smoothly !!!
  13. turbo-joe
    Apr 6, 2008
    9,441
    romano schwabel
    both or only one side?
    I told you already change from left to right side and then you see
    nice that it was not more :)
    but I wonder: your mechanic tested a new coils and the failure still has been there? and now you write you changed the coil and all is ok - what now???
  14. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,930
    Isle of man- uk
    Assuming these coils are similar to those on the mondial, these can get hot and break down after say 4 miles.
    With the car cold, start it up and drive until the engine starts to play up, then jump out and put your hands on both coil bodies. If you notice a temp difference then the warmer one is the one breaking down. Mine stated to misfire after about 4 miles and the temperature difference was easy to find. When the coils are cold you can test them and they will be electrically good
  15. turbo-joe
    Apr 6, 2008
    9,441
    romano schwabel
    good idea
    but before you touch the coils you may shut off the enigne
  16. tommydogs
    tommydogs Karting
    Nov 9, 2016
    137
    Los Angeles, CA
    Tommy Robinson
    Thanks, Mike, this is a very interesting observation! My car has had these symptoms since I took it out for an hour or so at highway speeds for the first time since my full major service. And it has been fairly easy to reproduce again. The last I checked with my mechanic, he didn't know what was wrong, but said the car would drive very, very nicely and then <boom>, start sputtering and went to ****. With what you're saying, he could test my coils from today until the end of the world when they're cold and they'll check out (or could check out) OK. But only start to disintegrate and misfire or not fire when heated.
    Unfortunately, *I* got fired since I last talk to my mechanic, so I've really been focusing on other priorities for the time being, but I will definitely go down and talk to him tomorrow and see if we can do this "heat test" on the ignition coils when the engine starts sputtering.
  17. tommydogs
    tommydogs Karting
    Nov 9, 2016
    137
    Los Angeles, CA
    Tommy Robinson
    #17 tommydogs, Aug 9, 2017
    Went down and talk to my mechanic this morning. He says he actually figured out what the problem was - the fuse panel overheating - and was just waiting for the part. I asked him, about the part currently in the car, "it isn't a stock fuse panel, is it?". He replied that yes, it was a stock fuse panel. So that's another thing lyin' Artie screwed me on.
    Could I test his idea by driving around with the fuse panel cover open and maybe have a couple of small computer fans blowing in on the fuse box?
  18. turbo-joe
    Apr 6, 2008
    9,441
    romano schwabel
    #18 turbo-joe, Aug 9, 2017
    picture from the fuse box would be fine
    there are several options:
    I prefer a cheap one: take 5 relais ( 2 for the fuel pumps, 2 for the water radiator fans and 1 for the AC fan ) outside the fusebox and connect the wires directly to those and you have no more problem
    you may search here - a lot of information you will find about the fuse box
  19. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,930
    Isle of man- uk
    Mine started farting and banging as the coil warmed up, in effect it was running ok on 1 bank as its coil was fine, but the other was causing the problems.
    The ends of the plug wires can go hard over time, be sure you get the correct wires as it will not work correctly with aftermarket ones unless a straight replacement, its very fussy on these
  20. tommydogs
    tommydogs Karting
    Nov 9, 2016
    137
    Los Angeles, CA
    Tommy Robinson
    Thanks Romano and Mike for your responses. I called my mechanic to try and get it back and do a little testing on my own, but he says a lot of things are unplugged and it's not drivable in its current state. He says the new fuse panel should be in very soon. I'll provide an update then.
  21. tommydogs
    tommydogs Karting
    Nov 9, 2016
    137
    Los Angeles, CA
    Tommy Robinson
    I talked to my mechanic about a week and a half ago and he said the problem ended up *not* being the fuse panel. Turned out to be ignition coil, driver's side. Replaced it with the model for the 512, and says it hasn't had any problems. I test drove it around town for 20 - 30 minutes this afternoon and didn't have any problems. Will drive it some more later in the week to verify the problem is truly fixed.
  22. Natkingcolebasket69
    Out of curiosity how much do the coil go for?
  23. tommydogs
    tommydogs Karting
    Nov 9, 2016
    137
    Los Angeles, CA
    Tommy Robinson
    I got effed. I really need to talk to my mechanic and let him know if there's an identical non-Ferrari-branded part, I'd rather use that. Little over $700.
  24. Natkingcolebasket69
    Seems okay to me! Coil pack on my cl65 are about 2k and need to be replaced often!!
  25. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Did you check the cross reference sticky thread at the top of this forum? Lesson for next time then.
