Testarossa costs of purchase and ownership | FerrariChat
Discussion in 'Boxers/TR/M' started by Whiskeyjet, Oct 3, 2025 at 10:06 AM.
  1. Whiskeyjet
    Whiskeyjet Rookie
    Sep 15, 2025
    7
    Hampton Roads
    Jeff B
    What is a reasonable price these days for a good driver’s car? Something that’s solid and reasonably well sorted. Nothing crazy. And how much money should be set aside for the maintenance kitty right off the bat? Assuming the car has had a fresh major in the last year or less. And no major outstanding issues.
  2. 66MK
    66MK Karting
    Nov 1, 2020
    211
    Mark
    Values in the UK have shot up recently I'm afraid. Right now there are a dozen or so for sale from GBP120,000 to GBP224,500 for mono/mono. So I would say some where in the middle of that range for what you're after. But remember - nothing is quite as expensive as a cheap Ferrari. :) Please take someone who knows these cars specifically - there are lots of things to look out for, but get a good one, stick a Capristo on it and OMG!
    I'm pretty sure I'll never willingly sell mine.
    Whiskeyjet likes this.
  3. Whiskeyjet
    Whiskeyjet Rookie
    Sep 15, 2025
    7
    Hampton Roads
    Jeff B
    Thanks!
    so I know the fuse panel is a sore spot for a lot of the Ferraris in this timeframe. What are some other things that that you would look out for?
  4. Chindit
    Chindit Formula Junior
    Oct 18, 2008
    431
    Navarre, Florida
    Nick P.
    A good answer to this question depends a lot on the overall mileage. My concept of a "good driver's car" is a car that has been frequently driven and carefully maintained. I would dismiss low-mileage garage queens from consideration immediately, and would look for a higher-mileage example. My answer to you is this:
    Mileage = 40-50k (or higher...)
    Reasonable Price = $125 - $135k
    Set aside maybe $3k for fresh tires, A/C recharge, change of every fluid, and to fix the "bunch" of little things that you will want to fix...stuff that comes with any used car that has been regularly driven.
    ago car nut, Whiskeyjet and ryalex like this.
  5. ryalex
    Aug 6, 2003
    26,169
    Las Vegas, NV
    Ryan Alexander
    $125-140k
    I'd say 5k/yr upkeep and "while you're in there".
    I got mine for $100k and it was running well but needed a major. Wheels, tires, tint, paint refresh, 3 month major with a handful of "while we're in there" and proactive things, and I'm probably around $135k all in now.
  6. Whiskeyjet
    Whiskeyjet Rookie
    Sep 15, 2025
    7
    Hampton Roads
    Jeff B
    Hmmm…I could’ve with that.
  7. Whiskeyjet
    Whiskeyjet Rookie
    Sep 15, 2025
    7
    Hampton Roads
    Jeff B
  8. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,601
    romano schwabel
    Jeff B
    you are a member here not so long. so it would be great if you could fill out your profile more and also introduce yourself a little that we could know how good your technical and mechanical knowledge is.
    I´m sure that will help you to get more answers ;)
    regarding your question here: from what car you are talking? there are several testarossa
    - first series with 1 outside mirror and central lock wheels ( I think Mark - 66MK means this one with the mono/mono ? )
    - 2nd series with 2 outside mirrors and central lock wheels
    - 3rd series with 2 outside mirros and 5 bolt wheels
    - then there are the 512 TR and the 512 M what looks equal to a testarossa but are the modified ones and not official called as testarossa.
    very important between the not so expensive fuse box it the diff. as I often have written here it is not a question of "if the diff will break" it is the question only "when the diff will break". and when you are just "in there" you replace all bearings and also may be some gears ( 1st and 2nd ) because of pitting at the gears. and this all has nothing to do with when the last major has been done when you not know what all has been done. sure you can replace the diff without dismantling the gearbox, but then you still not know what about the gears
  9. Whiskeyjet
    Whiskeyjet Rookie
    Sep 15, 2025
    7
    Hampton Roads
    Jeff B
    Thanks Turbo,
    I have some experience doing my own car work, nothing deeper than removing and replacing a motor, so transmission work would be a new experience. I don’t have any experience with Ferraris or other exotic cars. I’m still not entirely certain that’s something I’m ready for. Mostly from the perspective of, it’s not just about buying the car. It’s about being able to take care of it properly. Also, I’m not sure if I can get one in and out of my driveway because of the steepness of it. I currently have a Mustang, which sits around 5 inches off the ground give or take, but it has a better approach angle than say, a Testarossa. So right now I’m basically considering the TR or a 308. But I might still decide not to do it altogether. I’m just not sure yet. As far as which kind of Testarossa, the 512 models are out of my reach. I suppose I would refer a vehicle that has the more standard wheel type, but that’s not gonna be a dealbreaker for me I don’t think.
  10. 66MK
    66MK Karting
    Nov 1, 2020
    211
    Mark
    Since I got mine some 5 or 6 years ago:
    • Changed all the suspension bushings and powder coated everything.
    • Changed the Diff. for one of Newmans
    • Changed the main PCB for one from Jenni Helms
    • Sorted some vacuum issues
    • Changed belts and tensioners
    • Capristo stage 3
    • Had new wheels made so I can use imperial tyres
    • Reworked the throttle cable
    • Full detail and ceramic
    • Replaced the frunk struts
    • Driven it a lot!!
    Costs? Not sure really, maybe GBP25K - GBP30k
  11. 66MK
    66MK Karting
    Nov 1, 2020
    211
    Mark
    I'm lucky enough to have both - a 308 is quite simply a joy to drive! The Testarossa is a bit more of an 'event', but believe me, which ever you get - you'll love it!
  12. ago car nut
    ago car nut F1 Veteran
    5,527
    Madison Ohio
    David A.
    TR speedos are easy to disconnect, so be wary of so called low mileage drama queens. Not all Ferrari dealers are honest!
    turbo-joe and Whiskeyjet like this.
