Testarossa Door strakes screws help | FerrariChat
Discussion in 'Boxers/TR/M' started by Auraraptor, Oct 13, 2023.
  1. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,958
    MO
    Omar
    The screws to hold the side strakes are missing on my TR; unfortunately PN 20286704 is NLA
    Does someone know the exact size /pitch / etc so I can just get a replacement set? Appreciate the help
  2. Steve Magnusson
    26,785
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,525
    romano schwabel
    when it is metric size then in europe it is no probolem to find. even every hardware store has them. may be not in black but galvanized for sure
    your personal info says you are from MO, so is this modena in italy or missouri in the US? may be in the US it is not so easy to find metric screws? then you may go to a european car shop, they for sure have.
  4. Auraraptor
    Sep 25, 2002
    13,958
    MO
    Omar
    I tried ferrparts and allferrariparts and both said NLA.
    Let me our UK friends directly
    Omar
  5. Auraraptor
    Sep 25, 2002
    13,958
    MO
    Omar
    MO is Missouri USA tragically not Modena
    We have metric readily available as well....I just need to know the size (aka length/diameter/pitch) and I can just buy it. As mine are all missing I can't work backwards to figure it out.
    If someone with a testarossa can share the info I can just buy locally.
    Also I called a few more US suppliers, all out of stock and NLA from Ferrari. Only technical details I can find is its a black Philips head screw used for finishing...which is vague at best.
  6. turbo-joe
    Apr 6, 2008
    9,525
    romano schwabel
    #6 turbo-joe, Oct 13, 2023
    the thread looks like M6 or M5. it looks like standard pitch. so when you order M6 it is 1,0 and when you order M5 it is 0,8. from the photo at steve´s link I would say it is M6. take a caliper please and meassure the outside diameter from the thread, then you know what you need. and the length you may meassure the lenght of the blind holes in the side strakes, add the thickness of a washer, then 1 mm for the doormetal and subtract 2 mm, better 3 mm then you have the length you need.
    best is to take 1 side strake and just test if the screw will fit. I never took those away so I not know what size they have
  7. lagunacc
    lagunacc F1 Rookie
    4,374
    https://www.ebay.com/itm/234463554452
    looks different than the pic fparts uk has
    Auraraptor likes this.
  8. lagunacc
    lagunacc F1 Rookie
    4,374
  9. versamil
    versamil Formula 3
    1,223
    Gaston, Oregon
    Brian Healy
    I have FOUR Testarossa's and there are THREE different mounting configurations for the side strakes depending on year.
    !991 and 1990 use a small stud and acorn nut on the top mount. The lower bolt is a metric machine bolt that uses an 8mm socket. I'm going to say these are 5mm bolts These appear to be secured with NUTS on the inside of the door. 1989 Testarossa uses TWO 4 millimeter phillips head machine screws with mating brass nuts on the inside of the door that are seven millimeters across the flat 1986 Strakes are held on with a LOT of bolts- two each- i didn't count.
    What YEAR is your car. I have an 89 parts car with door panels out- so easily ascertained what it uses. Most people are NOT going to remove their door panels to answer your question. there's NOTHING special about these fasteners The one I took out of my parts car might be 5/8ths inches long- long enough to go through the outside strake mount, the door and room for a nut. Probably had a black oxide head at some point. The strakes on the later cars are also held on with a 6mm socket head cap screw at the top of the strakes. They're an assembly on the late cars and separate on early cars.
    The little black oxide acorn nut used on the top mount of the 90 and 91 may be challenging. I didn't stick a socket on it, but I'd bet it would be a seven millimeter across the flats- smaller than the lower bolts.
    turbo-joe likes this.
  10. versamil
    versamil Formula 3
    1,223
    Gaston, Oregon
    Brian Healy
    I had a micrometer AND the removed phillips machine screw for the 89 sitting in front of me. It's a half inch long and .151 in diameter- a few thousanths under 4MM. You could just use #8 machine screws at .161 diameter. I think the interior BRASS nut is a good idea, as it's a wet location and the nuts are not in the clear. They're both behind a bracket or window part- so if they rust up, you'll have fun getting them out. Yeah for Ferrari for using brass.
  11. Auraraptor
    Sep 25, 2002
    13,958
    MO
    Omar
    I have a 94 512TR . I was able to order the factory nut and washer, just not the screw. I just
    bought the eBay screws linked above as a starting point.
