Testarossa Dreaming - realistic maintenance budget | FerrariChat
Discussion in 'Boxers/TR/M' started by brent95m3, Jan 6, 2015.
  1. brent95m3
    brent95m3 Rookie
    Nov 19, 2013
    27
    Austin
    I'm finally in a financial place where I can consider a Testarossa as a possibility but I'd like to get a little feedback from owners. I have a DD and a fun driver (BMW M Coupe) and a Porsche 997 turbo. I'm contemplating selling the Porsche which should cover the cost of a clean 15-20k mile Testarossa.
    I've read to budget maintenance in the neighborhood of $5-10k every 3-5 years. I can handle that. I'd probably put a few miles on it (figure 5k/year). I'm in a good place financially and plan on putting a monthly amount away into a savings account for car goodies. I could afford a hypothetical $25k one time hit (assuming the savings account hadn't been built up yet) if something went wrong, but it would hurt, not enough to impact my lifestyle significantly, but definitely a hickey.
    So I guess if I budget appropriately, find a recently serviced car, and drive it regularly (5k/year) do those with experience think this is a reasonable plan? Like most, the fear of catastrophic failure has always kept me away. The bills could be offset by a more stable resale value versus the Porsche so that could be factored in as well to the overall costs.
  2. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
    #2 ozziindaus, Jan 6, 2015
    That sounds about right. Assuming you believe in the 5 year routine engine out schedule and you plan on getting the work done rather than doing it yourself, then plan for about $5-$6K or $1k/year on a major alone. I say alone because you still need to consider fluid changes every year ($700 at a dealer) but I'm sure you can handle this one. Also note that if you live in a cold weather climate where driving a car like this is seasonal, try and get your service done during the off peak period. Could save you a few grand here.
    Now if you decide to take on the major service and have the tools and knowhow, then it can be as low as $300/year. Good luck
  3. brent95m3
    brent95m3 Rookie
    Nov 19, 2013
    27
    Austin
    I'm in Austin so it'd be driven year round. Regular maintenance I can handle, the fear is some catastrophic $25-50k blown engine. I should probably drive one first before I fall too far down the rabbit hole.
  4. ozziindaus
    Aug 16, 2012
    9,799
    Detroit
    Sam
    The engine is probably amongst the most robust around. I have yet to hear of an engine blown so I'm sure it's not the weak link. You will however hear a lot about differentials blowing which will set you back about $25k. Preemptively upgrading it will set you back about $5k but it's a one off cost.
    As for driving one first, unless you are amongst the very few that do blow the engine and on your first drive, then you'll be immediately sold. :D
  5. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    As stated the engine is usually not the weak link. Not too long ago if you blew the engine you'd just sell it, cut your losses and buy another. Now with prices on the rise owners will have to bite that bullet. But again, not really something to lose sleep over. Look into the diff upgrade, find something with up to date service or one that needs it and have it done under your supervision and enjoy.
  6. tvu
    tvu Formula 3
    1,362
    Southern California
    Trieu
    You should definitely drive one to make sure it's what you are looking for. It's a GT car, so not as tossable. If you do continue down the path, Rifledriver, who just moved to Austin can probably set you straight since he has been working on these cars since their introduction and owns one himself if I recall.
    Budget 10K for the major every 5 year. 1K for every year(oil, fluids, brakes, A/C, misc).
    Good luck.
    SkiFreak likes this.
  7. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,577
    Avvocato
    The main key is buying the best car upfront to avoid any real nasty surprises.
    I would not be concerned about mileage , as you mention mileage between 15-20, I would focus on the service history and ownership of the car first, then condition , then mileage.
    Long ownership tells you the car was most likely cared for, time not used as a Saturday special, and someone maybe had a vested interest in changing the oil;) that's were service records come in .... The more detailed, the better.
    These cars are old enough where mileage has really become secondary, and condition and history is more important, unless you buy a bubble wrapped car with under 5,000miles.
    Good luck in your search - these cars are awesome to own and drive, and really not that expensive for what you are getting, just have fun shopping and go see in person 4-6 cars to really compare with your own EYES....not Internet pictures.
  8. ago car nut
    ago car nut F1 Veteran
    5,502
    Madison Ohio
    David A.
    If you happen to drive one with louder than stock muffler You will love the sound.
    Ago
  9. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    If you are comfortable turning a wrench, your budget is more than enough. TR's are nothing magical and are very easy to work on. Parts can be spendy but there is a a sticky thread that lists where to get OEM parts at non 'Yellow box' prices.
    I think you will find the the TR maintenance costs are less than the M3. A well sorted car will give you years of joy. The flat 12 is a very reliable powerplant.
  10. rickytestarossa
    Dec 25, 2014
    10
    Pacific Northwest
    Ricky Torres
    I think the most important thing is the experience to own a Testarossa.
    Maintenance and what could go wrong shouldn't matter as you will be having a really nice swing in life.
    Keep post it about your plans.
  11. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,958
    The Cold North
    Tom
    If your going from a 997 turbo to a TR, prepare to be really disappointed. Sorry to say, the TR drives like an old truck, and will feel slower then a snail compaired to what you are used to.
    You are going to be seriously down grading performance wise, and upgrading cost wise. Your BMW will make a TR look really silly let alone the 997. Don't get caught up in the hype.
    Just my humble opinion. Worth what you paid for it..
  12. Scaledetails
    Scaledetails F1 Rookie
    Nov 19, 2003
    4,211
    Daytona Beach, FL
    Stephane
    +1000000
    I just bought one recently from a dealer sight unseen (long story, don't ask ;) ), only being told it needed a "major", so I put aside $10K and had it shipped directly to my dealer. 2 months later I am close to $30K in repair bills and counting, but in the end I will have a well sorted car. Due to their age, mileage isn't the only concern one should have. I could write a book on what to expect from a somewhat neglected TR. With that said, they are so worth it :)
  13. jonack
    jonack Formula Junior
    Jul 3, 2007
    291
    Berkeley, California
    J. Clark
    IMHO you should budget about $2-$4 per mile in standard service costs. This number does not include odd things that may go wrong I.e. Like a radiator hose in which you might have to take the underside panels off. Depending on year of car those panels are held on with some 200 pop rivets that must be drilled out individually, I have personally seen this done. And there can be other hidden costs. Any Ferrari repair will cost more than a Porsche repair.
    I also agree with the previous poster regarding the '80's /'90's Ferrari technology vs the 2000's Porsche technology. The 997 put out more horse power and will get that power the the wheels better.
    With all that said there is little better than owning and driving one of Ferraris big boys! There is no Porsche sound like the flat twelve in the Testarossa.
  14. brent95m3
    brent95m3 Rookie
    Nov 19, 2013
    27
    Austin
    Thanks for the information. $2-4 per mile might be difficult to rationalize especially if I do want to actually drive it. It seems like I may have undershot the mark on budget, or at the least, created a budget based on a best case scenario.
    Stories like Scaledetails are what puts me off from considering the Testarossa for the time being.
    Don't flame me, but I may consider a Gallardo or possibly just keep the 911 for a few more years.
  15. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    Scaledetails story shouldnt put you off. A good PPI will weed out the lipstick pigs.
    I have owned a bunch of 911's. The Pcar is a beautiful woman who all your friends admire. The TR is a super model who after meeting her, your friends go home and spit on their wives.
    D-Gunz likes this.
  16. Total Recall
    Total Recall Formula Junior
    Aug 21, 2014
    324
    East Yorkshire, UK.
    Dominic Bradley
    Wow! You`ve got a 5-10k budget over 3-5 years and could take a 25k hit if something went really wrong?
    If you can`t afford to run a Testarossa, no one can!
    I`ve got a fraction of that budget and I`m having the time of my life with my Testarossa.
    Sure I do my own maintenance but even if I trippled what it`s cost me to allow for labour, it would be nothing like that amount - and that`s buying a high miles car that needed a service.
    Obviously there are no guarantees, you can`t plan for everything - but unless you buy a brand new car with a warranty then the same goes for any car.
    There`s no set rules that an old Italian supercar car has to break you - and definitely no reason why a Testarossa is more likely to break you than most other old Ferrari, Lamborghini or Maserati models.
    It`s engine out to do the cambelts every 5-7 years for peace of mind - and some cars have had broken diffs - but you have to counter balance that with the fact that unlike a lot of other old Italian cars, there`s no sodium exhuast valves to break and no cam chain tensioners to gradually wind up the tension over the years until the chain snaps!
    Also taking the engine out of a Testarossa is nothing like the big deal it is on just about any other Supercar either as it was made for ease of removal purely for servicing - so if you are charged an absolute fortune for it to be done then you are getting ripped off.
    I`m sure anyone with half a brain knows it isn`t going to perform like a 997 Turbo - just the same as a Countach isn`t going to perform like a ZO6 Corvette - but people don`t buy these old Flagship supercars for that anymore - they buy them for the driving experience and character that no modern car can mimic.
    I know I shouldn`t make it sound like such a light decision - but come on in, life`s too short!
    Buy one and if you love it great, you`ve got one of your dream cars. If you don`t like it, just sell it. If you bought well in the first place you probably won`t loose a thing - and may even make a bit - but even if you lost 5k isn`t it worth it to find out for yourself rather than wondering the rest of your life ?
    I bought mine 3 years ago and had nothing like your budget. As I said doing the work myself makes up for a lot of that - but since doing the engine out service the only thing that has gone wrong in 3 years is a temp sender anyway, so it wouldn`t have cost anymore even if I was paying someone else at this stage.
    Even if I had some kind of massive 25k failure I would still have less in it than it would cost me to buy even the scruffiest example now.
    Sure have a drive to make sure you don`t really hate it - but other than that with your budget if you really want one, I can`t see any reason not to get one!
    Dom.
  17. ago car nut
    5,502
    Madison Ohio
    David A.
    Howie,
    What you said might be true, But the passion and satisfaction you get from a 12 cyl. Ferrari doesn't compare to the German. Yes the Italians are different but if you owned a 12cyl. Ferrari you would understand. I have a louder exhaust on my TR. I'm tempted to remove the small muffler and run straight exhaust. The German might be more practical but it seems you don't own a Ferrari. There can be some expensive costs to owning German also.
    The TR can be maintained buy an average mechanic if he his patient and into the car.
    Ago
  18. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    My two cents, and something to keep in mind in forums like these, is that there is a lot of guys with a lot of different meanings of 'maintain'. For example. Some have detailing shops wash their cars and then rub them dry with diapers. Others turn on the hose and use a sponge with Dawn. Similar result, much different cost.
    For me, I budget a belt svc every 5-7 years (as opposed to others 3-5 years) and use modern, cheaper repair parts (for example, fuel injection hose from AutoZone to repair a fuel leak instead of the braided OEM fuel line from Ferrari). Same result, much different price.
    Threeofnine likes this.
  19. MS250
    Dec 10, 2003
    26,577
    Avvocato
    #19 MS250, Jan 7, 2015
    A 997 turbo is a new car .... Put that against a 458 and Nissan GTR, but you still need to look at the GTR unfortunately ;) compare apples with applies.
    Compare years of cars if you are looking at classics, the Testarossa is a great driving car, and the 12 cyl is nothing short of spectacular for what it was in the day, no different than what a Daytona was, or a 250 gto back in the day.
    A couple of cars were making out 180 mile an hour mark with the ease and comfort the Testarossa was back in 1984/1985 which was 30yrs ago.
    For the OP - comparing a bmw M3 or 997 turbo into a Testarossa for driving the same you are comparing the wrong cars.
    Good luck in your search if you make the move, buying the right car is key to enjoying ownership, service is not expensive, and this myth of 5 yr belts is another long saga that's nonesense. These cars were built well for the time, and the tranny and engine and body are bullet proof if cared for like an exotic rather than a DD.
    As I've said before - Testarossa owners on this forum have now made this OP change his mind because of the nonesense of a select few.
    High five to you guys for scaring another guy ! That will help you guys sell your cars for more money soon enough if you keep that up.
  20. brent95m3
    brent95m3 Rookie
    Nov 19, 2013
    27
    Austin
    I'm not making the comparison. I realize performance of a 25 year old car won't equal a modern 911 Turbo.
  21. mikegr
    mikegr Formula Junior
    Jul 3, 2012
    415
    Europe
    i 'm sure nobody would buy a TR for performance or daily drive
  22. brent95m3
    brent95m3 Rookie
    Nov 19, 2013
    27
    Austin
    I'm interested in the Ferrari for the visceral sensation of a 12 cylinder Ferrari supercar and if it appreciates over the next few years, Yahtzee.
  23. Total Recall
    Aug 21, 2014
    324
    East Yorkshire, UK.
    Dominic Bradley
    Well I hope we haven`t put you off!
    The Testarossa is such an emotional car that it does divide people down the middle - and people are going to be strongly oppinionated on the car.
    Also owners` experiences are different so it`s hard to tell the basic facts from the hype - but I hope you have got some useful insight so far.
    The important thing if you decide is to buy the right car and not get carried away by that emotion!
    I`ll admit I did just jump in 3 years ago - I literally thought "OMG there`s a Testarossa I can actually afford to buy" - and bought it!
    For me it turned out great - and tbh if I hadn`t of I wouldn`t have been able to afford one at their current price level - so even taking a massive gamble it can turn out ok - but I wouldn`t advise that to anyone ofc.
    It sounds like you are in a different position though and have the budget to be able to go in with your eyes open and be 99% sure you`re picking the right car to start with.
    I bet a Gallardo is a fantastic car - and very different to your other cars - but it`s still modern and a different thing altogether to an old 12 Cyl mid engined supercar. I think at the current values anyone could sell their Testarossa and get a decent Gallardo (over here in the UK they could at least) - but there`s obviously a reason why many of us don`t.
    Whether it`s beacause they just want something different, something they can work on themselves, the special character it has, the unique looks, possible investment potential or just because it was on the poster on their wall - everyone has their own reasons.
    If you are keeping the BMW and Porsche - then adding an old school 80`s Testarossa will mean you have the best of all worlds and at least have something about as different to the others as you can get for your money!
    Have fun looking!
    Dom.
  24. Scaledetails
    Nov 19, 2003
    4,211
    Daytona Beach, FL
    Stephane
    I didn't mean to put you off with my TR's bills, but let's be real. The Testarossa is the most expensive Ferrari to maintain, period. Anyone here that says it isn't is simply in denial, or hasn't had one long enough.
    I have owned 5 Testarossas, and yes, they can be expensive to own, but well worth the admission price. If you don't pay up front for the perfect sorted car, you will afterwards, it's all the same. The upside is it is a "supermodel" compared to a 997 Turbo, which I just sold (2008 997TT) to get this Testarossa a few months ago. No comparison, I'll keep my TR ;)
    My point is pay now or pay later, and it will be very rewarding either way.
    Good luck, I hope you find one soon.
  25. Shark01
    Shark01 F1 Veteran
    Jun 25, 2005
    6,483
    I don't have a TR BUT I have a similar maintenance intensive car. The plan by which you start with a $10k maintenance fund and add $5k to it each year is VERY sound.
    Yes, cars like this WILL have a 5 figure service. The only questions are when and how many.
    So how do you justify this? Easy look at depreciation. Your M3 was what, $75k new? Five years later it is a $45k car. 997 Turbo? Stickered for $180k for a 2011 Turbo S that can now be had for $110k
    I'd rather have a car that didn't depreciate that I spend money on to keep it nice.
    So IF this is your dream, don't sell yourself short and buy yet ANOTHER depreciating wonder like a Gallardo.
    Zeff likes this.
