Testarossa engine out | FerrariChat
Discussion in 'Technical Q&A' started by McRedHead, Nov 8, 2022.
  1. McRedHead
    McRedHead Rookie
    Jul 14, 2021
    14
    Aberdeen, Scotland
    Alastair
    I am in the process of removing my TR’s engine - all going well but how do I separate the main electrical connector which is U bolted to the lower engine cradle ( driver’s side LHD ) or should I remove it on the engine side, from where? Cheers
  2. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,032
    Summerfield, NC
    Tom Jones
    That is just a 2 piece connector that unplugs. No need to remove the U bolt.
  3. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,860
    The Cold North
    Tom
    Give it a good pull on the car side harness. It will just pop free. Leave the ubolt in place..but it will need to be removed later to get the left timing cover off.
  4. McRedHead
    McRedHead Rookie
    Jul 14, 2021
    14
    Aberdeen, Scotland
    Alastair
    Thanks for that, gave me confidence to pull that bit more and hey presto, connector separated tonight + I also won the battle with the throttle cable holding brackets so it’s now free …. I can see the light now :)
    Ak Jim likes this.
  5. tbakowsky
    Sep 18, 2002
    19,860
    The Cold North
    Tom
    Removing is easy..getting the throttle cable back in..is a bugger..
  6. McRedHead
    McRedHead Rookie
    Jul 14, 2021
    14
    Aberdeen, Scotland
    Alastair
    Oh oh, looks like I’ll be back in touch in that case o_O
  7. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,211
    Georgia
    Wade Williams
    I made a pull tool. I took a stainless TIG welding rods and welded them together, then welded a threaded bit on the end. I feed that through the path of the cable and screw it on. As I install the engine. I just pull the cable into place. Easy.
    Rexcat458, 2NA, Llenroc and 1 other person like this.
  8. McRedHead
    McRedHead Rookie
    Jul 14, 2021
    14
    Aberdeen, Scotland
    Alastair
    Good idea, much appreciated
  9. tbakowsky
    Sep 18, 2002
    19,860
    The Cold North
    Tom
    I just use mechanics wire..
    Rifledriver, ferrarioldman and 2NA like this.
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,423
    San Carlos, CA
    Mitchell Le
    I just use strings to pull it through.
  11. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,056
    Troy, Michigan
    James
    I use thin clear plastic tubing. Fits right on the end of the fitting.
  12. McRedHead
    McRedHead Rookie
    Jul 14, 2021
    14
    Aberdeen, Scotland
    Alastair
    1Superleggera likes this.
  13. McRedHead
    McRedHead Rookie
    Jul 14, 2021
    14
    Aberdeen, Scotland
    Alastair
  14. yelcab
    Nov 29, 2001
    13,423
    San Carlos, CA
    Mitchell Le
    Loosen the big 17mm bolt the tensioner will snap to its most extended position. Use a long screwdriver, lever in such a way to push the tensioner back to its most compressed position. Lock the 17mm bolt back. Now the belt is loose. You can remove the belt and the tensioner.
    Do not ignore the cam timing.
  15. McRedHead
    McRedHead Rookie
    Jul 14, 2021
    14
    Aberdeen, Scotland
    Alastair
    Thanks for your quick reply, I’ll let you know how I get on
    I see 2 white marks on the toothed cam pulleys which I’ll line up before I undo anything
  16. yelcab
    Nov 29, 2001
    13,423
    San Carlos, CA
    Mitchell Le
    Don't rely on the white marks...
    Rifledriver, V4NG0 and tbakowsky like this.
  17. tbakowsky
    Sep 18, 2002
    19,860
    The Cold North
    Tom
    Before loosening and removing the cam belts... get that engine to #1 TDC on compression (firing). You will find roughly the crank position by looking at the engine fly wheel and lining up PM 1-6 line to the pointer on the clutch housing. (Under the drilled cover to the right side of the engine at the back end.). At this point (hopefully you have the valve covers removed) the scribe marks on the cams will line up..or be very close to the scribe marks on cylinder 1 cam caps and cylinder 12 cam caps. Once engine is set in that position.. carry on with belt removal.
  18. yelcab
    Nov 29, 2001
    13,423
    San Carlos, CA
    Mitchell Le
    These are not questions I expect from someone with a nicely welded engine stand ...
    tbakowsky likes this.
  19. McRedHead
    McRedHead Rookie
    Jul 14, 2021
    14
    Aberdeen, Scotland
    Alastair
    Aha, one of the advantages to having my own fab shop - I appreciate any / all your help guys, I am familiar with engines but not this one so just going steady
  20. McRedHead
    McRedHead Rookie
    Jul 14, 2021
    14
    Aberdeen, Scotland
    Alastair
    My car does not have cats which were removed before my ownership
    Can I remove the secondary air pump ( Pt.No.134082 ) and ancillary pipework without making problems / fault warnings ??
  21. Steve Magnusson
    26,606
    If you mean no precats and no cats = yes, you can remove the air pump without any ramifications, but you should remove the entire system IMO (check valves, air injection manifolds, cutoff valves) to not needlessly keep "cooking" the components and close the air injection manifold ports on the cylinder heads with flat plates. However, do not disable the differential pressure valve -- it's vacuum plumbing source is shared with the air injection cutoff valve operation. (And, even if you do have precats or cats, there is no intelligent fault warning system on a TR to detect no air pump, but they will foul more quickly without a working air injection system.)
  22. ago car nut
    ago car nut F1 Veteran
    5,473
    Madison Ohio
    David A.
    Ok Steve, where is the differential pressure valve?
    As always, your knowledge is well appreciated.
  23. Steve Magnusson
    26,606
  24. McRedHead
    McRedHead Rookie
    Jul 14, 2021
    14
    Aberdeen, Scotland
    Alastair
    After many months ( mainly waiting for parts ! ) I finally have the engine back in and it started 1st turn
    My issue now is reconnecting the gear linkage as I don’t remember if I put it into any particular gear when I disassembled it, duh !
    The gear selector shaft slides in and out of the gearbox housing easily but doesn’t appear to be changing gear - in fact the car is in gear but nothing I do affects it ?
    Have I missed something / made a big mistake - if so how do I fix it ?
  25. Rifledriver
    36,821
    Get a shop manual? I know I know. Silly concept.
    Island Guy and TTR like this.
