Testarossa engine removal step by step | Page 3 | FerrariChat
Discussion in 'Boxers/TR/M' started by ang308, Jul 7, 2018.
  1. ang308
    ang308 Formula Junior
    361
    Stamford, CT
    Billy
  2. ang308
    361
    Stamford, CT
    Billy
  3. ang308
    361
    Stamford, CT
    Billy
  4. ang308
    361
    Stamford, CT
    Billy
  5. ang308
    361
    Stamford, CT
    Billy
    With that done throttle bodies come right out. Engine looks much cleaner with everything out of the way
  6. ang308
    361
    Stamford, CT
    Billy
  7. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    fyi... these frame bolts should all be identical - looks like an undersized bolt was previously substituted. You may want to start a ‘parts list’ even now and add new frame bolts as item#1.
    Cheers!
  8. ang308
    361
    Stamford, CT
    Billy
  9. ang308
    361
    Stamford, CT
    Billy
  10. ang308
    361
    Stamford, CT
    Billy
    Last thing to do before undoing frame bolts is shifter. Put shifter in second and undo the 13mm bolt that attaches to transmission
  11. ang308
    361
    Stamford, CT
    Billy
    Next you have to undo shifter rod from shifter. Took me a while to get it but it’s REVERSE thread. My head couldn’t wrap around it for a minute. Break loose the tightening nut and twist shifter rod till loose. Don’t undo tightening but to much just loosen because then you won’t have to adjust shifter. With that out of the way the only thing left is frame bolts.
  12. ang308
    361
    Stamford, CT
    Billy
  13. ang308
    361
    Stamford, CT
    Billy
  14. ang308
    361
    Stamford, CT
    Billy
  15. ang308
    361
    Stamford, CT
    Billy
    While unloosening these bolts you should have some sort of cradle supporting subframe. Next there are 8 bolts on each side that are attached where the shock towers mount to. 4 17mm and 4 13mm. Two of the 13mm you don’t have to undo I found out. They come out with shock tower. You live and learn. This is best done from wheel opening.
    Reman likes this.
  16. ang308
    361
    Stamford, CT
    Billy
    And with that all undone life body and motor stays down. Success!!! All in all it took me about 6 hours plus another 2 to remove intake and wiring harness. So 8 hours altogether. Next is servicing motor and fixing coolant leak that made me take out motor. I have to remove oil tank so I can get to pipe with stripped bleeder.
  17. ang308
    361
    Stamford, CT
    Billy
    All the parts lined up. Next up is clean motor and engine bay do service and put motor back and enjoy car for another 5 years. At least this time I have a step by step with photos for the next time.
  18. ang308
    361
    Stamford, CT
    Billy
    The photo makes it look like it's undersized but they're all identical. I already have a parts list that's getting longer by the minute.
  19. archimedou
    archimedou Rookie
    Aug 9, 2013
    11
    Zurich, Switzerland
    Hello,
    I will do the same work on my 1987 Testarossa before the end of the year.
    What you just did by posting all these pictures is incredible.
    I sending you the biggest THANK YOU ever from France :)
    Looking forward to hear from you when you will reach the "tensionning the cambelts" step, and what the pitfalls may be.
  20. jjeffries
    jjeffries Formula Junior
    Sep 4, 2012
    250
    Connecticut
    John Jeffries
    WOW! Pretty serious jigsaw puzzle. Cool garage and collection of drivers, in the best sense of the word. John...in the other side of CT.
  21. Nick G48
    Nick G48 Karting
    Aug 18, 2016
    57
    Clinton Township, Michigan 48316
    Nick
    Big Thank you from me. I live in Michigan. I own a 86 Testarossa. Bought it three years ago with 30,000 miles. I know it needs the major engine pull service. I have not even started the car since I purchased it. I own a 4 post lift and and am going to purchase a two post just for this service. I plan on starting the work in the Spring. This step by step process that you did is absolutely amazing. I would love to contact you by email. My email address is [email protected]. If you contact me, I will email you back Thanks again.
    Nick
  22. jgmblair
    jgmblair Formula Junior
    715
    Winnipeg, MB Canada
    Jeff Blair
    Hey Nick G48 welcome to Fchat :) I too have an 86 and will be taking the engine out next month to do some routing service. I see you are relatively new here but feel free to post some questions and some pictures of your car. Lots of knowledge here and most willing to help. Billy's write up is a perfect example of the type of info you can find here if you ask questions and use the search function.
    Cheers
  23. raysur
    raysur Formula Junior
    561
    So. Cal.
    Jeff
    #73 raysur, Oct 19, 2018
    Hi Nick G48,
    These threads make this forum great. I love seeing the process too.
    I just wanted to mention that you can easily pull the engine with a four post lift. I just pulled mine and it was simple. I'll eventually make a thread to show it, I am just knee deep into maintenance items and tracking parts down.
    Save your two post lift money for parts. :D
  24. ago car nut
    ago car nut F1 Veteran
    5,246
    Madison Ohio
    David A.
    Pulled my engine twice without a lift. Made a cradle with casters, took the tires off, rear bumper, muffler etc. lowered car down on cradle, unbolt rear frame and disconnect everything. Jack up body, roll engine, gearbox suspension out. Do a search, I posted on here.
  25. Gialllo uno
    Gialllo uno Formula Junior
    Jul 5, 2014
    342
    Reisterstown, Maryland
    Mark
    Pool rafts on the 69 Pace car camaro? And a 71 Camaro..?. I sold a 70 1/2 Z28 that I had for 23 years to buy my Testarossa . ?.....wish I had a bit more room in the garage. I had a 98 F355 and have been looking again. Great stuff..keep it up. I am inspired to do my engine out this winter. Marco
