Testarossa engine removal | FerrariChat
Discussion in 'Boxers/TR/M' started by Serpent Driver, Aug 14, 2010.
  1. Serpent Driver
    Serpent Driver Formula Junior
    Jul 4, 2004
    324
    Norway
    Saw a picture gallery at Universal Autosports where they where performing a major service on a Testarossa. They lifted the engine up and out with a crane instead of dropping it down with the subframe. I have never seen that before. What are the best method? Fastest and easiest?
    Looked like they saved a bunch of work doing it like this.
  2. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    It is possible and quite easy if things go right. Its what my independent service agent does.
    However, things that can and do go wrong include not being able to get the exhaust headers off the block which means having to first get too, and then grind / cut the old nuts off.
    I prefer to lift the car as it gives me the opportunity to check things more clearly and to clean some of the parts that are not usually accessible.
    P
  3. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Are you sure it was a Testarossa? It could have been a 512 TR in which it's normal for the engine to be removed out the top.
    The early TR's had the script "Testarossa" on the top of the engine cover. Can you post the picture?
    Shamile
    Freeze...Miami Vice!
  4. Steve Magnusson
    26,777
    #4 Steve Magnusson, Aug 14, 2010
  5. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Those photos are NOT of a Testarossa but from a 512TR.
    P
  6. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Note that the 512 TR does not have a removable subframe so the engine must come out the top.
  7. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Ya learn something new every day :)
    P
  8. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    Steve I see in the photo that one of the headers is already removed. Is this necessary if the clutch is off?
    P
  9. Steve Magnusson
    26,777
    #10 Steve Magnusson, Aug 14, 2010
    Not 100% sure (as that's not my photo), but my guess would be that it (and maybe the corresponding one on the farside) did have to come off -- good catch. The shop that did my last major also lifted the engine out the top, but I didn't get photos of the details (IMO, they preferred to do it that way mostly just to have a way to move the remaining carcass around more easily).
  10. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    From memory I believe that the ends of the headers are under the anti roll bar. To get them past the anti-roll bar the engine has to go forward a couple of inches at least. I dont think there is enough room to do this (especially because of the gear selector rod) hence the headers are removed.
    When I took my car for a final check after having the whole engine and subframe out they told me that I did it the hardest way :(
  11. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Yeah......who's yo daddy! :D
    Actually Rifledriver has mentioned many times that it's much easier to remove the Testarossa engine on the sub frame as it was designed to do.
    Why reinvent the wheel.....do it the way it was designed.
    Shamile
    Freeze...Miami Vice !
  12. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    I agree with you both, lifting the car off is the easiest and best way :)
    P
  13. Serpent Driver
    Jul 4, 2004
    324
    Norway
    Did not know that about the 512tr:) Anyone know why they designed it dfferently?
  14. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    The engine was mounted lower in the chassis to improve the center of gravity and they made the frame one piece to improve rigidity and handling. Suspension geometry was also improved.
  15. Serpent Driver
    Jul 4, 2004
    324
    Norway
    Okei:) Cool!
  16. Serpent Driver
    Jul 4, 2004
    324
    Norway
    Is this the same on a 512M?
  17. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    #18 Spasso, Aug 16, 2010
    I would think so. Continuing evolution. The 'M' was the last of the last.
    IIRC the engine block casting and motor mounts are different on the 512TR vs. the TR.
  18. silvergts1998
    silvergts1998 Formula 3
    Apr 10, 2005
    2,426
    ky
    Adam
    yes you need to remove the rear header to pull the 512TR engine out.
