Testarossa fans | FerrariChat
Testarossa fans
Discussion in 'Boxers/TR/M' started by Knockoff, Jul 2, 2008.
  1. Knockoff
    Knockoff Rookie
    Jun 3, 2007
    18
    91 Testarossa......If the fans are not coming on, where is the first place to look? Fuse box or is there an acchilles heel? The idle speed also seems to be irregular (up & down).
    Thanks........
  2. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,424
    Alabama (was Mich.)
    Jeff
    Yes...check the fuse panel, specifically the white connectors at the bottom of the fuse board, look for burned connections. Another possible source is the temp. sensor, this is located on the driver's side radiator, down at the bottom.
  3. blown daytona
    blown daytona Formula 3
    Feb 6, 2008
    1,679
    maryland
    Ditto, Also check fuses. If all looks Ok, try to jump the sensor wires on the lower left radiator. If fans still dont operate, youll need a wiring diagram to find out where power is being lost
