Testarossa gear oil | FerrariChat
Testarossa gear oil
Discussion in 'Boxers/TR/M' started by jbcottrell, Oct 17, 2005.
  1. jbcottrell
    jbcottrell Rookie
    Apr 8, 2004
    31
    How do I check the gear oil on a Testarossa?
  2. Steve Magnusson
    26,829
    If you mean "how do I check the gearbox lubricant fill level with the powerplant in place", the first thing you'll need is a 12mm hex "L" key that you can cut off the short leg really short -- but you'll find both pieces useful ;)
    See any TR OM:
    Section 1, liquids and lubricants, has a useful figure showing the gearbox fluid levels in the main and transfer gear reservoirs.
    Section 4, gear box and differential, has a figure identifying the various drain and fill plugs (in your case, you'd remove plug "C" to confirm/deny if the main gearbox reservoir level is up to the bottom of the plug "C" hole).
    PS the "17 pints" for the transfer gear case reservoir is a misprint -- should be "0.17 pints"
