Testarossa glove box switch button | FerrariChat
Discussion in 'Boxers/TR/M' started by leslie_choo, Dec 25, 2014.
  1. leslie_choo
    leslie_choo Formula Junior
    Aug 5, 2012
    444
    Singapore
    BCChoo
    Hello
    Has anyone changed their glove box switch button before ? Do I have to remove the console ? Or I just remove the switch button ? What's the best way to replace this switch button ? Thanks
  2. ago car nut
    ago car nut F1 Veteran Silver Subscribed
    Aug 29, 2008
    5,495
    Madison Ohio
    David A.
    Yes I have removed and cleaned my 87 TR switch. You can carefully remove the switch from the console. I posted a photo of disassembly on this TR forum. I not too compute lit, but if you do search on here it is available. look under ago car nut posts. I also removed and cleaned the window switches and the inst. dimmer. A big difference in operation after cleaning.
    Ago
  3. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
  4. dkyranakis
    dkyranakis Formula Junior
    Nov 24, 2013
    258
    Centreville, DE
    Demetri Kyranakis
    I had to change my 2 small ECU's that control the thermo couples for the cool down lights to stop going nutZ. Expensive at 700 or so x2 plus labor, but it worked. Haven't had a false warning since!!
  5. leslie_choo
    Aug 5, 2012
    444
    Singapore
    BCChoo
    Thanks everyone , so looks like I could remove the switch without dismantling the console Which is good news. I will try it ..
  6. ozziindaus
    Aug 16, 2012
    9,799
    Detroit
    Sam
    I don't think I need to change them. When I wiggle the connector, the buzzer and light turns off. It's a common problem.
  7. dkyranakis
    Nov 24, 2013
    258
    Centreville, DE
    Demetri Kyranakis
    I hope you are correct. Mine was painful 💵💵💵💵💵
