Testarossa, how many teeth on the flywheel? | FerrariChat
Discussion in 'Boxers/TR/M' started by alhbln, Nov 26, 2015.
  1. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Does anyone know how many teeth the Testarossa flywheel has?
    The workshop manual has a "Z=146" label next to the flywheel, but given that the flywheel has three TDC teeth, the amount of teeth (RPM pulses) per TDC segment would result in a point number (48.66…) which is kind of unusual for an early mapped ECU setup.
    While reverse engineering the MED120B Microplex i found out that the number of teeth between the TDC pulses is hardwired to 48, so that would indicate that the flywheel actually has 3*48 = 144 teeth.
    I had a chance to measure the RPM pulses on a Ferrari 412 (equipped with the same MED120B ECU as the Testarossa), and got 144 teeth as expected.
    Thanks,
    Adrian
  2. OptimusPrime
    OptimusPrime Formula Junior
    May 10, 2011
    291
    Florida
    Tom
    Starter has 11 teeth
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,541
    romano schwabel
    the sprocket on the flywheel has 146 teeth ( just counted here )
    and those teeth are only for the rpm
    for the ignition there are the 3 "negative" teeth with 120° distance because all 120° crankshaft each bank needs 1 spark, so 120° times 6 is 720°, 2 turns
  4. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Romano, thanks! If possible could you post a close up photo of one of the TDC negative teeth shown with the flywheel teeth? I want to understand the phase relation between the two.
  5. turbo-joe
    Apr 6, 2008
    9,541
    romano schwabel
    #5 turbo-joe, Nov 27, 2015
  6. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    I think it does make a difference, as the Microplex calculates the start of the individual advance timing based on the RPM sensor pulses (internal clock) starting from the TDC pulse crossing zero.
  7. turbo-joe
    Apr 6, 2008
    9,541
    romano schwabel
    you are right adrian
    the RPM sensor gives signal to the ignition box, but only for rpm, nothing more, the 3 negative teeth are for each TDC, but remember, you have a distiributor and so it does not matter if cyl 1, 2, 3...or 6 is firing, important is only the 120° distance on the flywheel for the signal.
    I changed more than once the sprocket from the flywheel and never had any problems when I put it on other way than it was before.
