Testarossa leaking fuel | FerrariChat
Discussion in 'Boxers/TR/M' started by TR86, Jul 11, 2015.
  1. TR86
    TR86 Rookie
    Jun 14, 2015
    15
    I can see leaking dropping from near firewall... Hoping will be just line because of freaking Ethanol.
  2. peteficarra
    peteficarra Karting
    Jun 22, 2010
    158
    ontario
    peter j ficarra
    Common problem. Make sure you cut the area where the hose clamps are. Pulling on them will rip off the aluminum nipple.
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,546
    romano schwabel
    is it leaking or only droping?
    when the engine runs or stops?
    easy to find when you have a hoist.
    if the return line leaks be careful when removing as peter already told
  4. ozziindaus
    ozziindaus F1 Veteran
    Aug 16, 2012
    9,799
    Detroit
    Sam
  5. jim94-348
    jim94-348 Formula Junior Owner Silver Subscribed
    Aug 19, 2010
    981
    Greenville, NC
    Jim
    I'd be very careful with that. The fuel lines, return lines and the vents are all along there and go up to the injection system, fuel tanks, etc. If it is fuel do not start the car as it is flammable and the leak can be on anything. These fuel lines dry rot and leak. Check and see what it is on the ground and maybe we can tell you what to try next. These are all accessible from the ground if the car is on a lift. Not easy to get to but you can do it,
  6. Melvok
    Melvok F1 World Champ Owner Silver Subscribed
    Jul 25, 2008
    14,268
    Mel
    Very TRUE and gives massive repairs and costs ... :)
  7. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I had a similar leak that was traced to one of the fuel pumps (externally mounted).
    A seam in the case of the fuel pump was leaking.
    At the same time I noticed the cross over hose and supply hoses were rock hard and ready to crack.
    They were replaced with the Silicon/Nomex hoses from Scuderia Rampante.
  8. JasonMiller
    JasonMiller F1 Rookie Silver Subscribed
    Jul 16, 2004
    3,649
    Co Springs/ Texas
    Jason Miller
    Mine did the same thing, spent an afternoon chasing and replacing fuel lines, fixed it.
    Good luck!
  9. Melvok
    Jul 25, 2008
    14,268
    Mel
    That is the way to go: be prepared and do it before they burst !
  10. ozziindaus
    Aug 16, 2012
    9,799
    Detroit
    Sam
    Right on. The pumps are built like coke cans and seem to leak at the crimp. Mine occurred over a winter hibernation when I lost almost an entire tank of fuel. Anyway, pumps are cheap but a pain to change if you don't have a hoist.
