Testarossa Manual | FerrariChat
Testarossa Manual
Discussion in 'Boxers/TR/M' started by Dutchman, Nov 13, 2005.
  1. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    I tried to download the Testarossa manual from the owners website. But after download I cannot open the file. Do you guys have any suggestions?
  2. Kingpin328
    Kingpin328 Formula Junior
    Nov 7, 2003
    433
    What's the problem Ton? didn't you get a regular PDF-file?
  3. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    No, when I download the file I receive a file called MUM_testarossa.exe.
    But I can't open the file. I tried to rename it as a pdf but it still doesn't work. I tried it on my iMac and on my Windows machine.
    I was hoping that someone else had encountered the same problem.
    Could it be that I do not have the Testarossa registered yet at the owners site? They only have my 328 registered at the moment.
  4. Kingpin328
    Nov 7, 2003
    433
    I see what you mean,
    however it's just a Zip-file that you have to unzip, it creates the PDF-file you need. I overlooked it at first, because it seems to state the original date of creation of the file. Not that I know the least bit of Windows etc. :)
    Try again?!
    Edit: I reread your post, make sure you EXECUTE the MUM-file, don't try to open.
    Edit @: you don't own a 328 at the moment :)))))
  5. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    Thanks Bram,
    But how do I execute the file? When I double click on the file it says that it doesn't recognize the format.
    And....... yes, you are right. I still must tell them that I sold my 328. I will do that the same moment that I register my Testarossa. :)
  6. dm_n_stuff
    Dec 10, 2003
    43,756
    26.806311,-81.755805
    Dave M.
    Problem solved.
    Check your PM's for a link to the pdf.
    DM
  7. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    Thanks Dave! :)
