Testarossa not starting | FerrariChat
Discussion in 'Technical Q&A' started by Capone, Mar 29, 2005.
  1. Capone
    Capone Formula Junior
    Mar 29, 2005
    257
    Midwest
    I have a new (new to me) 1990 TR with 35,000 miles. I drove it fine last week but have since tried to start it with no luck. It turns over but will not fire. My mechanic ordered a "fuel pump protection switch" since the car did act up a few times during normal driving. What it would do is only idle at 800 RPMS and then it had about half the "get up and go" as normal. I'm told if this switch goes bad it wont allow fuel to the engine.
    When I try to start it it will fire but then sputters a few times and dies.
    Is there any thing else I should be checking for? It appears all sparks and other electricals are fine.
    Any input is appreciated. Thanks,
  2. Myhorse
    Myhorse Formula Junior
    Oct 31, 2003
    387
    By no way am I a mechanic...
    But a similar problem happened to my TR
    Same deal - sputtering etc, would not stay running idled well below 1000 then died. When it finally remained running heavy smell of gasoline ( and subsequent vision of flames engulfing my car) prompted me to shut it of and leave it off.
    Problems:
    1 - R fuel accumulator was leaking.
    2 - fuel pumper sensor shorted out ( ?because of the leaking fuel accum - I don't know)
    accumulator was changed, sensor was changed and BINGO Ferrari back on road and me happy again. ( both available at a fraction of what I paid from Rockauto.com )
    So if I were you make sure it isn't something simple - fuse, relay,
    then look for a leaking accumulator ,
    If you can't find anything, then take it to the doctor - let him / her start undoing the bolts, cable, wires etc to figure it out. maybe something easy like a dirty fuel filter.
    Let us know what they come up with
    myhorse
  3. brent Lachelt
    brent Lachelt Formula 3
    Dec 6, 2003
    1,831
    Brownsburg, INDIANA
    Brent R.Lachelt
    By any chance did you buy this 1990 TR from Motorcars International in Missouri? Just curious.
    Brent
  4. Capone
    Mar 29, 2005
    257
    Midwest
    Yup, I do. Why you ask?
  5. brent Lachelt
    Dec 6, 2003
    1,831
    Brownsburg, INDIANA
    Brent R.Lachelt
    I've sent you a PM
    Brent
  6. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Typically the left bank coil can fail, this also controls the fuel pump circuits. The car may try to fire while cranking, albeit on the right bank only.
    Also, the wiring connectors on the left side engine comp. just ahead of the coolant resevoir, they corrode and make poor contact.
    finally, the usual problems with the overheated contacts in the main fuse box.
    Look at those, good luck, Brian
    www.autocarsports.com
  7. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Instead of relisting everything, do a search on " non-starting TR ", hard starting TR or Testarossa won't start.
    I had a big-time starting problem a year or so back. You will find great information from, coils, to tacometric relays, and sensors.
    Everyone was so helpful and there is great info. Mine is a 91TR
    Shamile
    Freeze...Miami Vice!
  8. Rifledriver
    37,290
    Or you could apply some basic, sound, diagnostic procedures and test for compression, fire and fuel and go from there. Works well for us in the industry.
  9. coachi
    coachi Formula 3
    May 1, 2002
    2,108
    SC USA
    just my 2 cents worth...my 1986 TR would not start unless it was given shots of engine starter fluid...not a good thing to do, and once it was started and it ran for while, it would restart when hot but not when it cooled down. After many trips to the dealer, i found a Porsche mechanice who replaced a 40$ relay under the right (passenger side) rear fender...no problems since.
