testarossa problem...how screwed am I? | FerrariChat
Discussion in 'Technical Q&A' started by bpu699, Aug 25, 2008.
  1. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,774
    wisconsin/chicago
    bo
    Changed the oil. gearbox fluid, changed intake gaskets, fuel hoses, replaced a ton of hardware... no problems.
    Went to flush the coolant, no problems...
    Took out the airbleed screw near the front of the engine, filled the system ... no problems...
    Went to tighten the airbleed screw... and it snapped. CRAP!!! This was the last thing I needed to do to start the motor!!!
    This screw is on the firewall, and an absolute bear to reach. Brass perhaps? Tried to remove it with one of those screw extractors and an airratchet, but it just chewed up the screw...
    ARGH!!!
    Now what???
    Its part 26 that snapped... http://www.ricambiamerica.com/images/diagrams/full/TR-87_024.jpg
    I am hoping this isn't one of those things where the whole motor comes out... :( .
  2. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    Man!! Looking at where that is in relation to the engine........DAMN! :(:(
    Did you overtighten it to cause it to break? Just seems strange that you removed it then it snapped when you went to tighten it. I wouldnt have used an air rachet on that screw extractor personally. :(:(
    If you can remove the housing, then you may have a chance to fix it on the bench then re-fit housing to the engine. :eek::eek:
    I suppose a right-angle drill wont fit down there? :(:(
    You may be sh*t out of luck if you cant get that housing off and onto the bench mate. :(:(
  3. bpu699
    Dec 9, 2003
    17,774
    wisconsin/chicago
    bo
    That is such an odd spot, that no tools will fit...
    I actually used a small rechargeable ratchet my wife got me for christmas. Its pretty useless for most things due to lack of torque, but it is one of the few tools that fit in that tight space.
    I was shocked the screw broke. There is a copper washer there, so I figure I had to apply some torque to it. I was using the smallest ratchet in the set (4 inch long handle, TINY!), and a 10mm nut. You can barely move the ratchet an inch, using a couple of fingers to tighten. So, its not like you can go nuts on torquing it...
    The screw went in super easy, its not like there was any corrosion. If I could cut a slot in the remaining screw, it would probably easily come out.
    I have tried two different screw extractors, with lousy luck. They are going in just a bit off center, and its limiting their function....
    I suspect that unless I get really lucky, I am going to have to get that housing off...
    So, the follow up question...Can I get that housing off with the motor in?
    Anyone?
  4. PAP 348
    Dec 10, 2005
    100,224
    Pap
    I SURE hope it can be removed in the car!! :D:D
    Sounds like a little bit of bad luck there mate. :rolleyes::rolleyes:
  5. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    Perhaps a Dremel tool with a small, this cut-off wheel might be used to cut a slot in the screw. a
  6. ASG 86TR
    ASG 86TR Formula 3
    Aug 23, 2001
    1,474
    New Jersey
    Adam G
    Not an easy place to get to at all. I had an issue with one that goes up the right rear of the firewall. If you think it may come out very easily, how about trying some kind of epoxy or such that you can "weld" a small bolt onto that may just have enough hold to back the screw out....
  7. bpu699
    Dec 9, 2003
    17,774
    wisconsin/chicago
    bo
    Too high a risk it will get into the threads... sigh
    I might try the dremel next... cutting in a slot won't be easy...
    I thought about getting a right angle adaptor for it and trying some tiny drill bits... problem is, the dremel only goes clockwise... it may push the screw in further...
  8. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    You need to post this in the TR section so we all can help.
    http://www.ferrarichat.com/forum/showthread.php?t=205838
    I just replaced all my coolant sleeves on the driver side of the car. You can access the the bleed screw/ thermostat housing without taking out the engine. Start a thread in the TR section so we can guide you along.
    ....I just went through this....just finished yesterday. I was even able to get the "magical" green stripe hose.
    Shamile
    Freeze...Miami Vice !
  9. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    Mine broke off when the major service was done. It still cost quite a bit to drill it out with the engine out of the car. I'm sure it can be done with the engine in there but it won't be easy to get to.
  10. Rifledriver
    37,274
    #10 Rifledriver, Aug 25, 2008
    Take it out.
    Not that hard, just 6 hoses. Besides if they were installed with silicone grease like I always do they will slide right off with your fingertips.
    Trying to fix it in the car will almost promise to cause your problem to snowball.
    The screw is brass and on many it is hollow. Tighten gently. A very slight cinch is all that is required. The bleeders on the waterpipes should always have a coating of antisieze.
  11. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    ....geez Brian, where was this great advice when I just put my hoses back on.
    Ok, I'll know for next time. :)
    Shamile
  12. fatbillybob
    Aug 10, 2002
    29,203
    socal
    Take 33 out for decent access so you don't bung up the female threads. But if you must do it insitu call a dentist its easy like doing a root canal.
  13. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    and about as painless we presume?
  14. bpu699
    Dec 9, 2003
    17,774
    wisconsin/chicago
    bo
    Thanx guys... Looks like the housing is coming out... Looks like a tight fit. I will go at it this weekend... :)
    So it looks like just the 2 screws hold it on, and then 3 hoses (6 clamps) ?
    Brian, you mentioned "6" hoses? The diagram only shows 3. Am I missing something? Does the alternator/compressor need to be removed, or will the housing slip between the two?
  15. ferraripete
    ferraripete F1 World Champ
    rifle to the rescue!!! thanks mr. crall!!
  16. Sigmacars
    Sigmacars Formula 3
    1,240
    you can get a left hand drill and when the drill starts rabbing it might come out if not atleast you can get an ease out in to it
  17. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    Nowhere important, USA
    Brian should change his username to "Rescuedriver" or "Riflerescue" or just plain "Mr.Rescue".
  18. bpu699
    Dec 9, 2003
    17,774
    wisconsin/chicago
    bo
    Alright, finally got the thermostat housing out, got the broken screw out... getting ready to put it back together...
    Now, I don't want to go through this again...
    Can I replace the brass screw with a steel one or stainless steel and just use some anti-seize? Or is the risk of it seizing so high that a brass screw must be used???
    Help please...
  19. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,284
    Illinois
    I would stick with brass and anti-seize as well. If you go with a plane steel plug, it will corrode so I would keep it brass. I wouldn't go with stainless steel because it is much harder than the metal it is going into and can easily cause damage if over tightened. Just my 2 cents.
  20. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Awwww.....don't keep it a secret. How did you go about removing the thermostat housing?
    What problems did you encounter?
    How did you eventually get the screw out?
    What tools?
    So we all may learn ! :)
    Shamile
    Freeze....Miami Vice !
  21. bpu699
    Dec 9, 2003
    17,774
    wisconsin/chicago
    bo
    Shamile, removing the thermostat housing is a bear:
    1) Remove the black grate over hood
    2) Remove the short large radiator hose connecting the thermostat to the block
    3) Loosen the CAD plated strips holding the aluminum coolant tubing to the firewall
    4) Loosen the 2 bolts retaining the thermostat, this is the easiest part
    5) Now, you have to loosen the radiator hose clamps. There is a hose on either side to the radiators, and a small hose on the left. Getting these hose clamps undone is a complete bear. The screws on the clamps point straight down, and a ratchet just won't work. You can barely move the ratchet 1 inch or so, before you hit something. Go to sears and buy a lithium powered hand ratchet. $50 or so, great tool. I got it for Christmas from my wife. Figured I would never use it.... :). Taking these clamps off took me the better part of a weekend, with tons of cursing involved. You are pretty much laying on top of the motor to even reach some of them..
    6) Now, in theory, the radiator hoses should just slip off. But then reality sets in. These things WILL NOT SLIDE off. I had to wiggle the thermostat for a long time to loosen it at all. Subsequently, had to remove the passenger side aluminum cross over radiator tube... also not fun. The housing will slip out between the alternator and compressor...
    7) Putting it back in is worse. The hose clamps are an absolute bear to get back on. At one point I was laying on the passenger rear fender, on my left side, with two hands way into the dark-side, blindly trying to tighten a clamp... Not fun. The rest is just going in reverse.
    8) Some folks have had problems putting the radiator hose back on the thermostat to the block. If you bend it in 1/2, into a 90 degree angle, you can fit it in, and when you let go, it expands perfectly onto both housings...
    Moral of the story... Working on anything along the firewall is not a lot of fun. You will drop tools! I dropped a socket 3 times!!! I got to the point that I was tying strings to the socket wrench so I could pull it back up. The space is very tight... I still have to find 1 socket that managed to get "lost."
    So, can you change the thermostat in a testarossa with the motor in? Yep. You just don't want to ;) ...
    As my wife saw me cursing, she looked at me and said, "You are secretly enjoying this, aren't you :) ." And honestly, I did. Its therapeutic. But on the flip side, if I had tons of excess cash, I would pay someone to do this in a heartbeat. This project gave me 3 weekends of "fun." :)
  22. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Now you understand why being a Ferrari mechanic is such a personally rewarding occupation. ;)
    Seriously, there are a few tricks that can make this a bit easier. As difficult repair operations go, you haven't even scratched the surface.
  23. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    Magnetic pick up tool and a claw picker upper are your best friend's when working on these cars.
  24. bpu699
    Dec 9, 2003
    17,774
    wisconsin/chicago
    bo
    I know...
    I look forward to the major over the next couple years :).
    Everything always takes a long time the first time you do it...
  25. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Thanks for the write-up Bpu699.
    I too just replaced my coolants hoses with the magical "green stripe" hose completely on the driver side of the cooling system. A coolant hose on the driver rad had split and had to remove the rad.
    Took me awhile as well.
    I just wanted ask a different perspective on tackling the problem.
    Thanks again....
    Shamile
    Freeze.....Miami Vice !
