Testarossa Starting Problem | FerrariChat
Discussion in 'Boxers/TR/M' started by David A. Sebok, Sep 4, 2007.
  1. David A. Sebok
    Jun 7, 2006
    12
    Myrtle Beach, SC
    David A. Sebok
    My 1990 Testarossa is in great order and generally starts perfectly. On occassion after having run and when hot it will not re-start until it cools down. Turning the key just gets a "click click". It did do this one time when cold in the garage but seems to be more common when very hot. I have heard this could be the key switch or starter /solonoid as they sit right on top and get quite hot. Anyone have any experience like this and what was the cure?
  2. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    The guys at Norwoods told my that my Testarossa (1986) did this too, and they put in a relay to get more voltage on hot starts. It was during the PPI and before I took delivery. If I recall correctly, the story was that the actual switch provided the solenoid current by itself without any sort of starter relay...
  3. Steve Magnusson
    25,123
    Yes, most likely a solenoid problem:
    Case I -- If the click is very "soft", the solenoid plunger is maybe just shifting a little in the bore, but it's not actually moving/stroking.
    Case II -- If the click is very "hard" (i.e., the solenoid plunger actually moves thru its stroke), but the starter motor doesn't spin, the switch inside the solenoid that should convey power to the starter motor (when the plunger is displaced) is bad.
    Try a search here, and at the old FChat, on "Ace Electric" -- should get you many threads on the Case I type of failure (some add a relay, as James mentioned, to increase the voltage applied to fire the solenoid, and some just get a better solenoid that can fire reliably at the reduced voltage). If Case II, no option but to get a replacement solenoid.
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,214
    Twin Cities
    Tim Keseluk
    Start at the battery and clean and tighten connections (don't miss the place where the ground cable attaches to the frame).
    Make sure the battery is in good condition and fully charged.
    Clean and tighten the connections at the starter.
    It is also a good idea to remove the starter (very easy) and wire brush the area where it bolts up to the bellhousing.
    Clean and tighten the engine ground strap(s).
    This is the easy stuff. If it's still a problem it is likely time for a starter rebuild.
  5. billb
    billb Formula Junior
    Jun 4, 2001
    407
    Shorewood, IL
    Bill Badurski
    Check the plastic battery cable quick disconnect under the car. It's near the engine and is there for engine-out services. The plastic may be cracked, resulting in poor contact between the two ends of the positive battery cable. This happened to me. Be sure to turn the battery switch off before wiggling this connector around to prevent a direct battery short circuit.
  6. vvassallo
    vvassallo F1 Veteran
    8,281
    Palos Verdes
    Vince V
    What about a heat shield for the starter? I had a different car do this for years until I fashioned a heat shield and that was it. Turned out excessive engine heat due to exposure to an exhaust pipe. Maybe this is an issue with the TR. I should mention that the heat killed a few starters and solenoids before we came to this conclusion.
  7. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,214
    Twin Cities
    Tim Keseluk
    A good idea for a lot of cars but on a Testarossa the starter couldn't be farther from the exhaust unless you left it at home.
    It is right on top of the engine, underneath the air intake scoop.
    You can remove it without getting your hands dirty (depending on the car of course).
  8. Rock
    Rock Formula 3
    Nov 9, 2003
    1,652
    Toronto, Canada
    Rocco
    There are three to four connections between the ignition switch and starter. Look for them and replace the connectors. It solves the problem all the time.
  9. David A. Sebok
    Jun 7, 2006
    12
    Myrtle Beach, SC
    David A. Sebok
    All great places to "start". Amazing how many possibilities exist that could cause or contribute. Will proceed and work through the suggestions which are all pretty simple tasks.
  10. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    Also, there is a large connector at the left fender, when looking at the engine bay from the rear, round If I remember correctly, make sure you have good connection there.
    Mine did the same thing and I found it to be this connection.
  11. rjnavion
    rjnavion Karting
    Nov 1, 2003
    128
    Gate, OK (western O
    Ron Judy
    On my 512TR the cable disconnect was in bad shape when I pulled the engine out. I don't know exactly where it is on a TR but on the 512 it was on the forward side of the engine. Trace the cable from either the top or bottom to find it. I don't know how mine started at all with the corrosion where these two cables met. They simply plugged into each other. The plastic around the terminals was bad so I soldered on two lug type terminals and bolted them together. Several layers of heavy heat shrink protect from grounds. They shouldn't have to be disconnected until the engine comes out five more years down the road. Provided there is no catastrophe bringing it on sooner.
    Ron
  12. tvu
    tvu Formula 3
    1,310
    Southern California
    Trieu
    I had this problem before, and tried replacing with the new solenoid. Still had the same problem. While I having my 30K service done a few months ago, I mentioned it to my mechanic, and he said it's pretty common issue.
    Don't quote me on this since I'm not a electrician or a mechanic, but I believe he explained as it gets hotter, the wires running from the battery to the solenoid is not able to conduct/pass enough of the 12V to trigger the solenoid.
    The solution is to install a relay which only requires a minimal amount of voltage for it to trip, and send the 12V from the battery to the solenoid or starter(sorry I can't remember which, but I guess I can pop open the hood to look if you need it).
    So far so good. I hate that feeling of getting stuck at a gas station after a good drive.
  13. 90koenigTR
    90koenigTR Formula Junior
    Dec 6, 2004
    439
    Northern California
    I. P. Freely
    Obviously, many of us have had this problem -including me. I purchased the Ace solenoid and an Optoma battery for extra power. Worked very well. But the car went to Norwood Peformance for turbo mods and James installed a new relay without hesitation. They don't fool around so I would never question them. Never had a problem since. Give James a call for advice on this permanent fix. Nothing is more frustrating/embarrassing than having a fun car and the motor won't turn over (especially if you have a nice passenger)
  14. Sega355
    Sega355 Formula Junior
    Nov 25, 2004
    361
    Hong Kong
    I had the exact same problem on my 94' TR. My local ferrari dealer install a new pair of bypass wiring and new relay for the starter wiring to solve the problem. Total cost we US$100.
  15. jratcliff
    jratcliff Formula 3
    Sep 7, 2004
    1,024
    Texas
    Talking to my electrical engineer, he noted that when the solenoid gets hot the efficiency of the coil is reduced (commonly called heat soak). This reduction in efficiency along with any external resistance (friction) would reduce the effectiveness of the solenoid. A more efficient solenoid or more juice to the present one will increase it's efficiency. Alas, I too have this problem and have just finished taking the solenoid apart. I measured the diameter of the piston and someone before me has reduced the diameter (so that theory has been shakened). I will need to run it for a while and see if there is an improvement.
  16. testarob
    testarob F1 Rookie
    May 13, 2006
    2,504
    Debary, Florida
    Rob
    Try a search. There are several good threads discussing this topic.
  17. amo66120
    amo66120 Rookie
    Jul 23, 2006
    20
    Poughkeepsie NY
    Al
    Having the problem on my 93 512.
    Does anyone have a detailed diagram of the
    relay solution ?
  18. Sco-Bar
    Sco-Bar Rookie
    Sep 8, 2007
    6
    Driftwood, Texas
    Scott Bauerle
    Sounds like I have the same issue. Does yours also affect the lights? ( make them surge ). I searched and found the responses. It sounds like a relay is the answer, but do you know where it goes or what kind?
  19. silvergts1998
    silvergts1998 Formula 3
    Apr 10, 2005
    2,419
    ky
    Adam
    So where do you hook up this relay? Do you hook it up between the battery and selenoid with a 12volt turn on lead?
  20. amo66120
    amo66120 Rookie
    Jul 23, 2006
    20
    Poughkeepsie NY
    Al
  21. fuentesa3
    fuentesa3 Rookie
    Jun 15, 2007
    24
    Houston, Texas
    Arturo
    Anyone have pictures of the relay they installed? Where can you get one (part number etc.)? Also, I tried replacing the starter solenoid and the screws on the housing wouldn't budge. Tried using WD-40 etc., nothing! Screws won't budge. Anyone have this problem? Is there something I'm doing wrong? If any of you have replaced the solenoid, please post an explanation of how you did it, i.e. procedure and any pictures you might have.
  22. David A. Sebok
    Jun 7, 2006
    12
    Myrtle Beach, SC
    David A. Sebok
    I got a lot of responses which I assume you have seen. I have worked through the simple ones like cleaning the connections etc. and can't tell if my hot starting problem has been resolved yet with the cooler weather but my guess is that my 17 year old solenoid should be replaced. There seem to be three screws on the back but I have not tried to remove them, mechanically inclined but don't want to mess up what is mostly working got now. I would use a ratchet with a good philips head type socket to try to break them loose so as to have good leverage and not strip the screw head. I am now inclined to have my mechanic look into the whole thing some time before next summer rather than me take a chance on breaking something. That said it sure seems to me a simple thing to do.
    As far as the other things suggested to me, a heat shield and a relay bypass - I and a few others prefer to make it work right and not mess with Mr. Fixit type solutions. Again, that said some others are very happy with their fix.
    Let me know if you get any answers.
  23. gabriel
    gabriel Formula 3
    Use a manual impact screwdriver. Buy it at Sears for $15. Hold it on the screw and whack it with a hammer and I guarantee that screw will come off.
    WD 40 is almost useless for loosening screws and nuts. Use a penetrating spray like Liquid Wrench or PB Blaster.
    Buy it at Wal Mart for $3.
    It may not help right away because the fastener might be very long.
  24. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    These are not jury-rigged happy go lucky fixes.
    The relay to the starter is a time tested permanent fix ....to one possible problem.
    I have it on my daily driver 91 TR....no problems
    Shamile
    Freeze...Miami Vice !
  25. Steve Magnusson
    25,123
    This is doing it the hard way. It's much better to remove the whole starter assembly and do the solenoid replacement on the bench -- this gives you a chance to lubricate/check the pinion gear sliding mechanism and the pinion gear.
