Testarossa T/Body Flap adjustment | FerrariChat
Discussion in 'Technical Q&A' started by flav, Jan 13, 2007.
  1. flav
    flav Rookie
    Jun 1, 2006
    7
    After a week servicing and doing fine tuning on this car i have 1 thing left... I have found that the throttlebody flap for the left bank needs a very fine adjustment. I can see that when it is running, warm or cold with the filter box removed, that the right flap is fractionally more open than the left one. If i gently press it down, about .2mm it runs much smoother, if i do the same to the right one it runs rough. I have played with the balance and air valve a little but i put them back where they were. How do you adjust the flap when its running?
    Cheers nice people!
    Thanks for all the help so far.
    p.s. Did anyone see the testa, the 550, the 360, the 348ts and the orange muricelago on Lygon st today? That was us!! Come say hello anytime and say your from here!
  2. Steve Magnusson
    26,931
    #2 Steve Magnusson, Jan 13, 2007
    Flav -- Your observation that the deflections of the airflow sensor plates are noticeably unequal is a sign that things are not well, but their positions during idle are a result of other adjustments/conditions (i.e., you don't adjust them directly). What's important is that the (absolute) air pressure (measured with a vacuum gauge or manometer) inside the intake plenums at warm idle is quasi-equal on both banks -- if they are (significantly) not equal, then some tweaking (of the throttle plate linkages and/or stops and/or air bypass screws) is necessary (and, just like a multi-carb system, if you tweak something that changes the airflow, you'll need to tweak/confirm the mixture adjustments also so it probably won't be a single tweak fix if it needs help).
    ...so please first measure/compare the vacuum in each intake plenum at warm idle (and if you use a Bourdon Tube-style vacuum gauge just use one gauge and do it one bank after the other as quickly as possible -- I've found that the difference/error between these type of vacuum gauges can be significant).
    What Engine Family is this TR? It will be something like F113A, F113B, F113A040, etc. -- it's shown on the top surface of the engine block at cyl #6 along with the engine SN.
