Testarossa - tappet noise from engine | FerrariChat
Discussion in 'Technical Q&A' started by Supracat, Aug 30, 2007.
  1. Supracat
    Supracat Rookie
    Jun 24, 2005
    27
    Falkirk, Scotland
    Doug Moodie
    Hi Guys,
    My 17,000 mile testarossa has just started to develop a tappet noise. It appears to emanate from one side of the engine only (as you look from rear to front it is on the left side). It is quite pronounced when engine is cold at start-up, but possibly a little quieter when warm. The car also appears to misfire a little when driving and has certainly lost some of its performance.
    i'm trying to ponder what i've done differently, if anything recently- it got an oil change about 1 month ago, and i've started using Shell Optimax 98ron fuel as opposed to 95ron fuel it was previously fed on.
    Oil pressure looks normal too.
    Any ideas??
    Cheers.
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Low oil, dirty oil, wrong grade/type of oil, or clogged oil filter would be the typical culprits for the easy fixes.
  3. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Does the testarossa have hydraulic valve lifters??
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    No
    While a change in lubricant along with a valve that was already on the "loose" side clearancewise can start clicking, the valve train on a TR has solid tappets with shims and doesn't "pump up" like the hydraulic lifters on a Chevy.
    Excessive valve clearance that suddenly appears (especially if the noise comes and goes) can be a result of one or more loose valve seats.
    This was (and still is) a problem with some 12 cylinder Jaguars. The steel valve seats did not have enough "interference" when pressed into the cylinder head and when the engines are overheated (not uncommon for a Jag) the seats would literally fall out (really bad).
  5. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,996
    So. Shore MA.
    Kenny K
    What weight oil was put in ? That's the first place to start. If it wasn't 15w-50 or 20w-50 then I would get the oil changed with either of those weights pronto. I recommend Mobil 1 15w-50.
  6. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,879
    Atlanta
    John!
    I agree with the above posted comments. Does the car burn any oil? '84-'89 Porsche 911 engines would have ticking sound when the valve guides were starting to go, and they would burn a bit more oil than a 100% healthy engine.
  7. Supracat
    Supracat Rookie
    Jun 24, 2005
    27
    Falkirk, Scotland
    Doug Moodie
    thanks for the feedback so far.
    I'll check with my mechanic about the oil. - it doesnt appear to be burning any oil - i'm aso sure that the valve seals were doen at the last cambelt service around 28months and 2000 miles ago.
  8. tamf328
    tamf328 Formula Junior
    Mar 9, 2005
    477
    2na, the inline 6 jag also had problems on the exhaust side of the head where the guide for the tappet would
    back out of the head and the cam lobe would interfere with it... use to make a distinct tapping noise.
    Jaguar had a "hold down" kit that was retrofited to the exhaust side of the head as a precaution.
    someone once told me that ferrari valve clearance usually tightens instead of loosens due to wear.
    can anyone confirm that????
    in 17k miles that seems highly unlikely but hey who knows.
    can you verify it is a tappet by listening with a stethoscope???
    I had that happen to my porsche once, I know they all tick.
    but this tap was more prominent than normal with a definite change in performance.
    Turned out to be a plug wire discharging to ground on the head through the extender.
    burned a hole right through it.....
    thought I'd check the rest of the wires by using a spray bottle of water on them while it was
    running,,,,,, nice light light show in a dim garage.
    needless to say all the wires were breaking down over time.
  9. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Valve clearances can tend to tighten up from wear and also sometimes from stretching valve stems. I've seen the heads pop right off of some valves (Maserati, VW).
  10. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    Does the noise change when the engine is revved, or on overrun? (I obviously don't mean in frequency, but in character)
    I like the plugwire suggestion, good thing to check, but also have a look at injector seals and manifold gaskets, or even a loose plug.
    A dropped valve-seat can of course happen, a compression or leak-down test should tell the tale, but one would have to seriously overheat the engine for that to happen. Yes, the Jag V-12 has a propensity to drop valve-seats, but almost uniquely after overheating, and almost always on cars equipped with cat converters. The overheating is almost always due to lack of- or badly performed maintenance. I run mine hard, and it is problem-free, but well looked after.
    If you suspect a dropped valve seat, don't run the car until it is cured in order to avoid expensive damage.
    Good luck!
    Jack.
  11. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    A stethoscope can isolate the source of the noise (I have an electronic unit, it's amazing what sounds are going on inside a running engine when you isolate them from the exhaust sound).
  12. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Well, IMHO, I would park the car until the issue is resolved. There are several events that could be taking place with your engine, and until someone gets an eyeball on it there is not one soul here that can make an accurate diagnosis.
    You have a noise that you describe as a valve tap as well as a noticable lack of power. This is not a good sign. It could simply be a sudden change in valve clearance, it is possible a shim wore through its hardface. This is quite unlikely but certainly possible. The cam could have suddenly had a lobe failure, again, rather unlikely but... You could have a loose valve seat ready to drop, an exhaust header leak, a piston gudgeon pin that suddenly loosened up, a cracked piston ready to break up, a bent valve ready to break off, a broken valve spring, its even possible your timing belt jumped. It could be almost anything. But if you notice, just about any one of these items could be downright catastrophic if allowed to fail completely.
    A dropped valve seat can do incredible damage, as can a bent valve, a broken retainer, a broken piston. A bad cam can throw steel shavings into the aluminum cam journals and destroy the cylinder head. While a cracked piston, a loose valve seat, or a bent valve would be quite expensive, catching it before it actually destroys the entire engine would be a bit more economical.
    I would suggest you absolutely do not run the engine for any reason until it has had a compression test, a leakdown test, and a thorough going over before you run it at all. You need to inspect the cams, the tappets, valve clearance, the timing belt, etc.. Sure, a warm engine would be best for checking the cylinders, but your looking for damage now, not wear. I would also suggest a borescope to peek around inside the cylinders. And I would disable the ignition so some fool mechanic dont try starting it either. There comes a point where we dont need to listen to it anymore, we need to inspect.
  13. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I'll second that.
  14. gabriel
    gabriel Formula 3
    I've never heard of spraying water on the wires. Interesting.
  15. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I had a bad plug wire zap me through a stethoscope once. That was NOT funny.
  16. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Can you hear me now?!
  17. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    huh?
  18. Supracat
    Supracat Rookie
    Jun 24, 2005
    27
    Falkirk, Scotland
    Doug Moodie
    Hi,
    My mechanic has ordered up some mobil 1 oil and a new filter, and we'll try this option first. - will wrong oil still cause the misfiring sensation when driving???, and also the tappeting noise in 1 cylinder bank only?? - hadn't realised the extent to what wrong grades of oil can cause!!
    From reading other comments i am indeed wary about taking the car out, even just to my local mechanic.
    Cheers.
    Doug
  19. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    ?????? Your playing russian roulette my friend, I wish you luck. If your mechanic thinks driving it some more might fix it, and you follow his advice, your as foolish as he is. The odds that changing oil and driving it will fix it are about zero, but not impossible.
    I preached to my niece for years to check her oil, keep it topped up, she never listened. She once drove home over 10 miles, the last 6 of which were freeway, with no oil. The oil light was on steady BEFORE she got to work, and although a service station was across the street from her work, she chose to drive home. The car was overheating, smoking and squealing when she pulled in the driveway. It took all of 5 quarts to refill it. She drove that car almost another year before selling it. It should have blown up, but it broke the odds. And as far as my opinion about keeping oil in the engine goes, she laughs at me to this day and says I am full of crap. I hope I am equally full of crap in this instance.
  20. ZINGARA 250GTL
    ZINGARA 250GTL F1 World Champ
    Jun 21, 2002
    17,499
    PA
    Ken
    At least in Russian Roulette there is only one round in the cylinder. This is like playing with five rounds in and only one empty.
