Testarossa Top Of Engine Refurbish | Page 3 | FerrariChat
Discussion in 'Boxers/TR/M' started by Shamile, Nov 9, 2010.
  1. ago car nut
    ago car nut F1 Veteran
    5,539
    Madison Ohio
    David A.
    When you change your own oil cut open the filter and look for bits of metal. Also drain the transaxle in to a clean container and do the same. The transaxle drain should of gave some evidence of something not right.
    Ago
  2. Maranelloborn
    Maranelloborn Karting
    Nov 16, 2009
    227
    New York
    Remund
    Could you describe a little more in detail what we are looking at with this photo Testamon.
    I'm interested in learning as much as I can about the diff carrier issue, and what it would take to correct the problem, Parts Labor etc... I could likely remove the lump myself and handle disassembly, but is it realistic to be able install a new Differential and set the end-play and proper clearances. Or is this something that needs to be preformed at an experienced shop? I have heard stories of differentials installed incorrectly, and being a LSD it seems more complex. BTW I'd love that engine in my Man Cave over the winter as a Coffee table..its that clean!
  3. testamon
    testamon Formula Junior
    Aug 16, 2008
    346
    Mike O
    If I can figure how to remove this from Shamiles Thread I will and I will place it in checking Diff with borescope thread... Sorry to hijack your refurb Shamile!
  4. Maranelloborn
    Nov 16, 2009
    227
    New York
    Remund
    Same here.... My apologies, lets get back to the thread topic of Top End Refurb and the bonus pics..
  5. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    BUSTED !!
    600 miles...hmmm...I do that in a couple of weeks...
    Shamile
    Freeze....Maimi Vice !
  6. testamon
    Aug 16, 2008
    346
    Mike O
    Shamile I would have love to have done much more, however as we all know in Testarossa world things break. Hopefully not long till back on road!
  7. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Hey there Mr. Shamwow...Long time, no speak. I must that even for a Lambo guy with all that tempting tail around, you still do very nice work!
    Best,
    David
  8. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Thank you for the kind words....especially coming from a professional tech. like yourself. :)
    Shamile
    Freeze...Miami Vice!
  9. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #59 Shamile, Nov 20, 2010
  10. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #60 Shamile, Nov 20, 2010
  11. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #61 Shamile, Nov 20, 2010
    Dear Ferraristi,
    1. Moving along....
    2. Moving along............
    3. Moving along......................
    4. With all the closed valves done. Now it's time to rotate the engine so the open valves will close.
    The way to rotate the engine is to go to the flywheel gear (under the perforated cover) and using a flat blade push gently against the bell housing casting....using a cloth to prevent any scratching. You want to make sure you are rotating in a clockwise direction ( as seen from the front of the car) ...rotate towards cyl 7/12 bank.
    Credit for this method goes to my local F-pimp Central Florida Ferrari. My service manager Rocky and F tech. Troy, showed this to me on a 512 TR in their service bay. They actually took the time to open the cover, place the blade in the gear tooth and showed me which way to push and how. ....can't beat that for great service....thanks guys.. :)
    Shamile
    Freeze....Miami Vice !
  12. Sandy Eggo
    Sandy Eggo F1 Rookie
    3,636
    Encinitas, CA
    Rick
    Well, with the weekend here, I knew it was time to check back in on Shamile's exploits.
    Wow, looking good...the engine refurb ain't bad either! :D
  13. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #63 Shamile, Nov 20, 2010
    Dear Ferraristi,
    1. Rotating the engine using a blade or large flat-head screwdriver in the flywheel gear...
    2. With some more closed valves (not all ) pour more GM Top End Cleaner into the intake and cover....do not open till x-mas...naw...4 more days. :D
    3. All closed valves with cleaner marked with tick.
    While I'm waiting for the cleaner to do it's job, I'll now move on to Dave Helms (Scuderia Rampante) gold connector replacements for the coolant sensors. Pix soon....
    Shamile
  14. Sandy Eggo
    3,636
    Encinitas, CA
    Rick
    Smart, very smart. The coolant sensors are a low voltage sensor which could have all sorts of knock-on ill effects if sending bad information. I'm no mechanic but that's what mine told me while we were doing my gold connector kit on the F355 and found my coolant sensors to be in terrible shape.
  15. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,430
    Alabama (was Mich.)
    Jeff
    Cleaning the intake valves too !!!! Wow Shamile...your attention to detail is exemplary. Are the intake valves on the TR prone to deposits and crud? Can you elaborate on this process...I must admit my knowledge about that procedure is lacking...
  16. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    All of the intake valves on all of the opened up engines I've seen have build-up behind the head of the valve. Some not so bad through the use of top tier fuel, others looked like a growing science project of carbon deposits, BIG chunks of the stuff..
    I think the differences are due to how the engines were used and maintained as well as the differences in the type of engines.
  17. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Well, I will say, Dave Helms suggested this to me and even sent me everything to do the sensors free. He just felt so strongly about while I was "in there". On Monday, I'll be ordering for the cold start valves and injectors....cause....."while I'm in there" of course.
    When I removed the intakes, I was kinds shocked that I had alot of crud on the back of all the valves. When I started taking things apart, I noticed that the 1/6 fuel meter plate didn't return to full close with ease....it would but eventually. So..the 1/6 side was getting too much fuel and running rich. BUT....the 7/12 side running just fine was also full of crud.
    Now, this is a surprise for me as I use Chevron Techtron once a month or so...and shift gears at redline....all the time.
    It really did look like the overstated picture on the Chevron package. Well I use the stuff and it's didn't look like the "after" photo either...haha. I didn't know what cleaner to use so I asked Dave Helms. He recommended the GM cleaner. The stuff really works. The crud was so heavy, I had to leave it in there for a few days and scrub it off with a tooth brush. While the crud was soft, I also picked it off CAREFULLY with a pic tool....and vacuumed it all away. Not one bit of crud was left to be ingested into the engine upon start-up.
    I wouldn't be surprised if there is more likely to have heavier deposits on the TR valves as we all know TR's like to run a little rich...well, what I've always read on the forum.
    My settings and balance was done by my local Fpimp a few years ago and runs smooth.
    I could be overstating what I saw...but it looked alot to me. I really expected to see nothing there....
    Shamile
    Freeze...Miami Vice !
  18. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #68 Shamile, Nov 21, 2010
  19. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Carefull with those scissors... Snip the plug leaving just enough wire on the plug so you can identify.. then cut the shrink tube at the rear of that insulated glob,t then pull forward.. New boot will protect all wires once installed... Remember... boot first.. then splice crimp and install..
    R
  20. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    #70 Shamile, Nov 21, 2010
  21. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Ideally the valves should be spotless all the time but because the dirty nature of internal combustion engines that isn't going to happen. What you are doing is a good thing as long as no chunks of carbon are left behind to scratch up your cylinder walls (and other stuff).
    If you REALLY want to see something dirty, look at the exhaust valves on an engine that is torn apart at your local machine shop.
  22. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Ha ha, I spent DAYS doing what you are doing to ALL of the connectors in my engine bay last winter.
    If you want consistent performance of the fuel injection, emissions and ignition I strongly suggest getting the entire kit from Dave, "while you are in there".
    You could have one of your "helpers" wipe your brow while you work.
  23. Mr.Chairman
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Hey Shamile... when you insert the extractor tool... push the old terminal in a bit as you push the extractor... She will pop out much easier..
    R
  24. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    You are exactly correct Robbie. I'm just posting an overview of what I'm doing. The full instructions from Dave Helms covers everything you say. As I'm posting , I'm now doing the crimp connectors. I've come across a weird resistor soldered into the temp sensor (brown plug) I'll post it for comment.
    HI Spasso. I really want to do the full system but if I start, it will be one thing after another and I'll never get the car back on the road. It's soooo tempting once you start though.
    I'm going to order the rest for the top of the engine....that's it. On a next project, I'll go further... :)
    Shamile
  25. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Ahh....cool...thanks... :)
    Shamile
