Testarossa Transmission/Gearbox | FerrariChat
Discussion in 'Boxers/TR/M' started by WJGESQ, Nov 25, 2009.
  1. WJGESQ
    WJGESQ Formula 3
    Dec 30, 2004
    1,477
    #1 WJGESQ, Nov 25, 2009
    What are the options for the rebuild/replacement of a transmission/gearbox for the 84-90 TRs?
  2. Marty
    Marty Karting
    Nov 21, 2003
    108
    Boston/PTown/SW FL
    Martin Stark
    The only option I found was $$$$$.
  3. testarob
    testarob F1 Rookie
    May 13, 2006
    2,504
    Debary, Florida
    Rob
    #3 testarob, Nov 25, 2009
  4. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    Dear Ferraristi,
    Testarob knows of what he speaks. He has had the disaster we all feared.
    Rob's main problem was the diff carrier split and cracked the case.
    If you need a rebuilt gearbox, TRutlands will be a good source. Don't forget to add Newman's diff if you're going this route. Newman has SOLVED the TR diff split problem.
    http://www.ferrarichat.com/forum/showthread.php?t=226140&highlight=TR+Diff
    What makes you think you need a rebuilt box?
    What problems are you having?
    Are you sure it's not just shifter / fork / alignment problem?
    Shamile
    Freeze....Miami Vice !
  5. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,112
    Mel
    Take the other option also serious....
    Get yourself a used 512TR gearbox instead.... they are available, like 512TR engines...
