Testarossa Turbine Project, Happening NOW! | Page 5 | FerrariChat
Discussion in 'Boxers/TR/M' started by APA#1, Jun 30, 2007.
  1. LouB
    LouB Formula 3
    Apr 15, 2001
    1,811
    FL, OR
    Make sure you maintain overspeed protection for the free or power turbine in case of a sudden loss of load like a broken drive shaft or similiar. Without it, disk burst would be an ugly possibility.
    Overtemp control is also critical.
    Will you use the existing fuel and electronic control? Modified for auto use? Derated?
    Will you run JP5?
    How will you get it spinning to fire it? Existing start system? Is it electric or hydraulic?
    The exhaust gas coulld be as high as 1000F. Watch out.
    Also watch out for sucking in small birds and animals :)
  2. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    Hi Carl, might take you up on it. Still need to do some business with you :)
  3. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    The overspeed should not be a problem. Overtemp can be a problem during start however manual modulated startup should be OK, I have run the turbine many times on the stand I built.
    I an using existing fuel controls, no derated hp.
    The engine will run on Jet-A, JP5, kerosene, Avgas, pumpgas, biofuel and diesel. Currently I am running it on diesel.
    It has a built in starter and generator.
    Exhaust can go max 750 or so C
  4. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    #104 APA#1, Jul 15, 2007
  5. 90koenigTR
    90koenigTR Formula Junior
    Dec 6, 2004
    439
    Northern California
    I. P. Freely
    Take solace in the likelihood that the purists' howl will be drowned out by the screaming turbine! Sign me up as APA founding member #3! Of course, keeping in mind that mods should only be applied to our post- boxer cars in my humble opinion.
  6. RacerX_GTO
    RacerX_GTO F1 World Champ
    14,850
    Oregon
    Gabe V.
    FERRARICHAT NOMINATION
    2007 - Best custom Ferrari
  7. tifosi12
    tifosi12 Four Time F1 World Champ
    Oct 3, 2002
    49,765
    @ the wheel
    Andreas
    +1
  8. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    Your there, #3. We can announce it all later :)
  9. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    ++1 :) Thanks !
  10. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    A.P.A.?
  11. Simba
    Simba Formula Junior
    Oct 24, 2006
    779
    New York
    Interesting project. I have to wonder about the practicality (amusing, I know), however, as you're planning on running AC and such. If it's just a demonstration car, that's one thing, but something to be driven on the road is very much another.
    Have you given any thought to modifying the engine with a regenerator setup similar to that which Chrysler used to reduce exhaust temperature and increase range?
    And, emissions requirements not withstanding, I will be amazed if you're able to drive this thing more than a few miles without every donut shark within a 20 mile radius showing up to have a little chat with you.
    In my mind, the only way to practically use a turbine engine in a road car is with extensive modifications along the lines of a regenerator setup and some kind of variable stator pitch control to allow for engine braking and low turbine speed acceleration. Just plunking in a surplus aircraft engine, al la MTT, is cool for demonstration purposes, but not so much for something you actually intend to use.
    I also believe that at the absolute minimum, you will need a two-speed gearbox (plus reverse) to get any kind of acceptable performance out of it. You're either going to be stuck with a 60-70 mph top speed, or take half an hour to pull away from a traffic light.
    By the way, where are you planning on storing the huge amount of fuel this thing will need?
  12. Jim Frentress
    Jim Frentress Formula Junior
    Mar 7, 2007
    682
    Laguna Niguel, CA United States
    James Frentress
    I was sitting at a stoplight in my 56 Chev BelAir hot-rod (about 20yrs ago) when beside me rolls-up a T bucket with jet engine. Exhaust was so HOT I backed up out of it for fear of melted candy paint (and left arm.) Met up with the guy later and apparently his car had been on the cover of Hot Rod mag at one point as an early (first?) jet powered road car. It's fun to watch this Fspool project!
  13. notoboy
    notoboy F1 Rookie
    Jul 8, 2003
    2,531
    NYC
    David
    Any updates on the project???
  14. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    Weekends are the time I work on the project. Saturday we are test fitting the turbine into the engine compartment. Pics thereafter
  15. carl63_99
    carl63_99 Karting
    Oct 22, 2001
    199
    Turbinarossa
    Kewl, very kewl.
  16. tifosi12
    Oct 3, 2002
    49,765
    @ the wheel
    Andreas
    Clever!
  17. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    #117 APA#1, Jul 20, 2007
  18. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    Good name, I was thinking of Turbinerossa, the "a" adds a better flair though
  19. Jdubbya
    Jdubbya The $10 Trillion Man
    43,614
    Hell's waiting room
    How about Testatoaster
  20. Jdubbya
    43,614
    Hell's waiting room
    Was it white with yellow flames? It was probably the one now in the LeMay collection. Cool car!!
  21. TestShoot
    TestShoot F1 World Champ
    12,319
    Beverly Hills
    or TestaRoaster
  22. Jim Frentress
    Mar 7, 2007
    682
    James Frentress
    HA! I haven't seen that car in 25years, and I didn't know it was part of the Lemay collection. The guy in the picture was the one driving it too, with his wife I believe, near the Puyallup fairgrounds for some yearly car event we had our cars in. Ironically, I now live only a handful of miles away from where this car will be housed when the new Lemay Museum is built. Life is stranger than fiction!
    Thanks for the memory Jdubbya... ya made mah day!
  23. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,392
    E ' ' '/ F
    Enzo Gorlomi
    The RocketRossa
  24. RobertM
    RobertM F1 Rookie
    Apr 17, 2005
    2,502
    Weston, Florida
    Robert M
    Craig,
    I can not wait to see her in action, that is just amazing !!! Let me know if you need any help. I am just around the corner.
  25. tifosi12
    Oct 3, 2002
    49,765
    @ the wheel
    Andreas
    Oops, I just soiled myself. :)
