355 - Testing the HVAC Control Panel? | Page 2 | FerrariChat
355 Testing the HVAC Control Panel?
Discussion in '348/355' started by WATSON, Jun 17, 2022.
  1. Qavion
    Qavion F1 World Champ
    14,615
    Ian Riddell
    So that means no power to the instruments :eek:
    How do you get anything to work on the car... including the engine? No power on fuse 24 means no vehicle speed or engine rpm information for the F1 TCU or engine ECU. Has your voltmeter died?
    Are you using a good earth?
    WATSON likes this.
  2. WATSON
    24,030
    WI
    I have no idea Ian.
    It's driving me nuts. I have nothing at that fuse. No HVAC panel response and the power mirrors are in-op.
    Everything else is fine..... my head hurts
  3. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    do the turn signals work? If memory serves me correctly, my mirrors, turn signals and back up light were on the same fuse. But my car is a 2.7.
  4. Qavion
    14,615
    Ian Riddell
    Same on 5.2. Mirrors, turn and reverse on same fuse. i.e. fuse #26 on the 2.7 car and fuse #25 on the 5.2 car. Same physical location on the relay panel on both cars, just a different numbering system.
    In summary, there must be power on fuse 24 (Aircon/instruments), otherwise the car wouldn't run.
    Does your meter work on other fuses? e.g. 19, 27, 28, 29, 30 & 31 should be live all the time. 24, 25 & 26 should be powered with ignition.
  5. Qavion
    14,615
    Ian Riddell
    WATSON likes this.
  6. Qavion
    14,615
    Ian Riddell
    Thought I'd better update this thread as I ran my own checks and the results disgreed. My checks showed:
    Pin 1 = earth
    Pin 2 = panel lighting (variable volts as it is controlled by dimmer knob)
    Pin 3 = fuse power (12 volts)
    Pin 4 = function unknown other than being affected by both STOP and RECIRC
    Pin 5 = temperature control
    Pin 6 = function unknown other than being affected by both STOP and RECIRC
    Pin 7 = air direction control
    Pin 8 = fan speed control
