TetraBOOST lead for fuel, anybody used it? | FerrariChat
Discussion in 'Technical Q&A' started by stephen308gt4, Jan 10, 2011.
  1. stephen308gt4
    stephen308gt4 Karting
    Dec 28, 2010
    55
    Scotland
    Stephen
    Hi Guys,
    I came across this stuff a while back and have wondered about using it in my gt4, it sounds really good stuff http://tetraboost.com/ and is also endorsed by http://fbhvc.co.uk/fuel-information/
    I am wondering if anyone out there has used this stuff and what are their views, it seems kind of hard to get a hold of as the order form requires printing/ filling out and posting, or to leave card details on an answer phone and you can't buy it in any shops and must buy a box of eight, just seems to be marketed very tightly or am I just being paranoid??
    However, the thought of my gt4 running on real lead sounds fantastic for valve seat protection.
    I am using castrol valvemaster plus at the momment in my fuel which is a phosphate type of lead replacement and wondering if this tetraboost in the long run would be an advantage as I don't want to chop and change products and do damage in the long run.
    Regards
    stephen
  2. Rifledriver
    37,099
    I think you are trying to fix something that isn't broken.
    We haven't had lead for longer than just about anyone on Earth and I haven't seen any problem with Ferrari motors attributable to that.
    Low octane
    Sure
    MTBE
    Sure
    Alcohol
    Sure
    No lead
    Nope
    Find something to worry about that is worth the effort.
  3. stephen308gt4
    Dec 28, 2010
    55
    Scotland
    Stephen
    Where do I start about the worrying Brian;-)))
    Great thanks,guess I just need a confidence boost.
    Im just looking to see others opinions on the matter of lead, I use shell 99 in my car and she runs smooth with it so your right about trying to fix a problem that isn't there, however, I wondered about the long term effects of valve seat wear and wondered if the lead would slow the process down a bit by using the product.
    Stephen
  4. Rifledriver
    37,099
    After many years of no lead fuel exclusively we have seen no valve or seat problems.
    Trust me, you will be rebuilding that motor or those heads for other worn out parts before the seats are a problem. We have had zero trouble with that aspect.
  5. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Waste of money and more likely to cause new problems (like sticking valves).
  6. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    #6 Pantdino, Jan 10, 2011
    My understanding is that a lead substitute is only needed in cars without hardened valve seats in the head-- basically the valve seat was just machined into the cast iron of the head.
    I think this was mainly a problem with British and American cars with iron heads up to 1970 or so.
    Certainly any car with an aluminum alloy head would have to have steel inserts of some kind, although I suppose the manufacturer could save a tiny bit of money by using soft, cheap iron.
    Or am I wrong?
  7. Nickrry
    Nickrry Karting
    Jan 4, 2009
    156
    when I got my Dino I was paranoid about the valves and used Shell addative. Then I got some tetraboost - there was no doubt about it, it was significantly quieter and smoother - whether the valves benefited I don't know. I now realise that the engine will go fine without anything added but it when I tried it, it was great.
  8. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    #8 greyboxer, Jan 14, 2011
  9. Squirrelmonkey
    Squirrelmonkey Karting
    Dec 27, 2010
    126
    Manitoba ,Canada
    Tom Thieme
    Has anyone tried avgas 100LL in thier cars?
    Tom
  10. dino clay
    dino clay Karting
    Oct 31, 2007
    185
    san mateo, cal
    clay cavanaugh
    a needed additive for flat tappet cams especially at high speeds and loads. Lead not required for valve seat longevity, this was a myth invented by machine shops to promote valve seat replacement and more revenue. A phosphate additive, supplied by most cam grinders for EARLY APPLICATIONS, keeps your cam lobes alive but is DEATH on your catalytic.
