355 - Teves hydraulic brake delay valve leak | Page 3 | FerrariChat
355 Teves hydraulic brake delay valve leak
Discussion in '348/355' started by MAD828, Sep 8, 2020.
  1. ShineKen
    ShineKen F1 World Champ
    19,607
    Southern California
    Nostradamus
    If the brake pedal feel was good, what made you think there was a leak? Just periodically removing the undertray to check?
    During the first test when you had replaced the delay valve and said the leak was gone, were you driving around with the undertray off to confirm the leak was gone?
  2. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,620
    Elliott Caras
    Yes brake pedal was fine.
    I should have left the undertrays off I just bled the brakes noticed no leaks and put it back on.
    I noticed brake fluid running from the drain hole in the large under-tray while working on the front suspension so I took the under-tray off to confirm.
    This time I will leave all the under-trays off until it’s confirmed fixed.
    ShineKen likes this.
