Thanks for previous input! Question about 308 DIY maintenance | FerrariChat
Discussion in '308/328' started by Amer28, Jan 22, 2005.
  1. Amer28
    Amer28 Rookie
    Jan 19, 2005
    5
    To all for your help,
    Thanks for all the input on the model/year question. I believe I will be going with the 308 GTS and it sounds like carbs are the way to go for me. This is because I would like to do my own maintenance and am more familiar and comfortable with carbs. Since I am still researching the "do it myself" maintenance part can someone please clue me in on what a "Major service" (15K?, 30K?) is? Are there any books and manuals available that a mechanically inclined person like myself could use (like a Haynes type book) to do this work competently. I believe I am a pretty good "backyard" type mechanic. I have rebuilt a 68 vette from the ground up (as well as a lot of other automobile and truck work) and found it to be easy. Am I therefore capable, with some time and the right printed info to work on my 308 myself?
    Thanks again and you guys seem like a lot of fun!
    One other note - I can forsee myself getting into trouble with this car. I was a pretty wild teen (hot cars, etc) but have calmed down a lot in mid age. I can feel my adrenaline perking up at the thought of the sound of going way too fast. This is especially funny since I have not gotten a ticket in about 25 years - and I know I will be getting a BIG one when I get this car!
    Thanks Again!
    Lance
  2. 8valve
    8valve Formula 3
    Sep 3, 2003
    1,029
    Netherlands
    Mick A.
    I just copied and pasted this from "Eugenio's" site that was mentioned in another thread.
    *30,000 mile (MAJOR) Service for 308's, 328's, Mondial 3.2's & QV's = $2995.00
    (348's are $3995.00, Mondial t's are $4995.00, and F355's are $5575.00 due to parts cost, engine removal, etc.)
    {Documentation of every Major Service comes complete with a full write-up, pictures, and all receipts for your records}
    -Replace Spark Plugs (NGK or Bosch)
    -Replace Timing Belts and Tensioner Bearings
    -Replace Cam Seals and Housing O-Rings
    -Replace Valve Cover Gaskets
    -Replace Distributor Seals and Housing Gaskets
    -Replace Distributor Cap Gaskets
    -Replace Cam End Cover Gaskets
    -Replace Air Filter
    -Replace Fuel Filter(s)
    -Replace A/C Belt
    -Replace Alternator / Water Pump Belt
    -Adjust Valves (where applicable)
    -Torque Cam Journals
    -Torque Heads (check only)
    -Set Timing
    -Bleed Brake Lines
    -Change Oil and New Filter
    -Change Transaxle Gear Fluid
    -Replace Coolant
    -Inspection/Service of Air Conditioning System (recharge "R12" extra on 308's/348's but "R134" is included on F355's)
    -Inspect all Lines (fuel, oil, water) and replace if necessary (extra charge for parts)
    -Check of Lambda System and Bosch Fuel Injection System (make adjustments if necessary)
    -Clean Engine Compartment
    -Pressurize Coolant System, check for leaks
    -Inspect CV Boots
    -Inspect Fuse Panel
    -Inspect Tires / Adj. Tire pressure
    {The items below are inspected and advised to the customer at no charge. If any item(s) require service, the customer will be advised of the cost.
    -Inspect Water Pump
    -Inspect all Seals (shift shaft, main, timing gear assy)
    -Inspect Ignition Wires / Caps / Rotors
    -Inspect all Bulbs, Lights, Electrical Motors
    -Inspect Clutch Pedal play (adjustment setting if necessary)
    -Inspect all Suspension Bushings / Connections
    -Inspect all Exhaust Joints / Connections for leaks
    -Inspect Brake Pads and Discs
    -Inspect Wheel Bearings
  3. Amer28
    Amer28 Rookie
    Jan 19, 2005
    5
    Thanks, any other info out there?
  4. Muteki
    Muteki Formula Junior
    Jan 14, 2004
    269
    Guam
