That Hill Engineering Aluminum Stick Shift Bush | FerrariChat
Discussion in 'Technical Q&A' started by pauls, Jun 22, 2024.
  1. pauls
    pauls Formula Junior
    Apr 25, 2004
    566
    California
    I have taken a lot from Ferrari Chat. Now I believe I have an opportunity to give back.
    I am going to give a pectoral of what I did to get around the hard parts for me. The first picture is a schematic pictorial that another member sent to me. It was really helpful.
  2. pauls
    Apr 25, 2004
    566
    California
    This how to get the small square hard rubber in the pin that goes all way from the right hand of the gear shift box to the left and exiting out of the gear shift box into the small square with a hole in the center of the rubber piece. The dot is the square piece and the other dot is the very end of the pin that will go into the square rubber piece. Look at the wood next to the square piece. This just a bunch of wood paint stirrers put together until I get the right thickness against the square rubber piece. Image Unavailable, Please Login
  3. pauls
    Apr 25, 2004
    566
    California
    The I went to the hardware store to find the diameter dowel.
  4. pauls
    Apr 25, 2004
    566
    California
    Here you see the dowel in the gear shift box.
  5. pauls
    Apr 25, 2004
    566
    California
    Then tap the dowel against the pin (flat round surface) with the wood paint stirrers on the other side. Make sure the dowel is long as shown as it will be ergonomically easier to tap the pin into the round, flat part of the piston shaped pin.
  6. pauls
    Apr 25, 2004
    566
    California
    You will save yourself a lot of time if you get this clamp. They are cheap at harbor Freight.
    Here you can see the clamp compressing 22,23 24, and 25 into the gear shift box which is spring loaded. Use a 14 mm socket between the clamp and number 24. See the spring clip? Once everything is compressed with clamp use a straight spring clip pliers to put the spring clip in its place. You are free of the long clamp as it is holding everything in place while you secure the spring clip.
  7. pauls
    Apr 25, 2004
    566
    California
    #8 pauls, Jun 22, 2024
    Spring clip.
  8. pauls
    Apr 25, 2004
    566
    California
    #9 pauls, Jun 22, 2024
  9. pauls
    Apr 25, 2004
    566
    California
    I use this cushion on the seat. I have nightmare's of my knee cracking the leather or slipping a seam.
  10. pauls
    Apr 25, 2004
    566
    California
    Spring clip.
  11. pauls
    Apr 25, 2004
    566
    California
    I highly recommend the lights for working at night. I have two, on for each side of the care.
  12. pauls
    Apr 25, 2004
    566
    California
  13. pauls
    Apr 25, 2004
    566
    California
    Close up.
  14. pauls
    Apr 25, 2004
    566
    California
    I know this is a dead poor formatting of the steps. I had a hard time figuring out how to post the pictures. Sorry for that but I hope this will be of help.
  15. pauls
    Apr 25, 2004
    566
    California
    Plastic pad
  16. pauls
    Apr 25, 2004
    566
    California
    Rubber pad.
  17. pauls
    Apr 25, 2004
    566
    California
  18. pauls
    Apr 25, 2004
    566
    California
    Feel free to contact me if you have any questions. The idea was how to make it easier to get the job done. I may just have confused you all.
  19. pauls
    Apr 25, 2004
    566
    California
    #24 pauls, Jun 23, 2024
    The light I used is: There are a lot of lights like this to choose from.
    Klutch 28676 Dual Head LED Tripod Worklight - 24 watts, 1800 Lumens
  20. pauls
    Apr 25, 2004
    566
    California
    Yes, I did take English in school. For some reason can't correct my spelling/grammar.
