That nose.... | Page 4 | FerrariChat
That nose....
Discussion in 'F1' started by MisterMaranello, Feb 3, 2012.
  1. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,974
    Atlanta
    John!
    #76 Ferraripilot, Feb 3, 2012
  2. Jack-the-lad
    Jack-the-lad Seven Time F1 World Champ
    Don't blame the engineers and designers. The rules dictate cars of unsurpassed ugliness. They're all uglier than a sack of ***holes.
  3. schumacherf2006
    schumacherf2006 F1 Veteran
    9,100
    Chris
    As ugly as it is... if it wins I am well off to luck the other way in the sense of car design
  4. Greenback
    Greenback Karting
    Mar 24, 2005
    57
    the rear brake duct is massive, pretty damn sure it will be use to create some sort of down force. looking at how they sculpted the side pot, it does look like air will be channel down the same exit as the exhaust as well.
  5. kraftwerk
    kraftwerk Two Time F1 World Champ
    May 12, 2007
    26,826
    England North West
    Steve
    AFAIK The exhausts must now sit in small allowable area, too high and far forward to direct the exhausts towards the diffuser. The exhausts must feature just two exits and no other openings in or out are allowed. The final 10cm of the exhaust must point rearwards and slightly up (between 10-30 degrees). Allied to the exhaust position, the system of using the engine to continue driving exhaust when the driver is off the throttle pedal has also been outlawed.
    Lifted from scarbsF1
  6. jmuriz
    jmuriz Formula Junior
    Dec 9, 2003
    395
    Arlington, VA
    I personally don't care...as long as it's fast.
  7. furmano
    furmano Three Time F1 World Champ
    Jul 22, 2004
    32,215
    Colorado
    Furman
    Ouch.
    What is the reason for the "no go" areas around the nose? What is the rule change that is being referenced?
    -F
  8. fluque
    fluque Formula 3
    Jul 30, 2004
    1,759
    Above 2240m
    Fernando
    #83 fluque, Feb 3, 2012
    That nose seems to be the common solution for this year. Vintage 2012 will certainly not produce the prettiest F1 cars.
    Here's the Caterham
  9. tifosi12
    tifosi12 Four Time F1 World Champ
    Oct 3, 2002
    49,897
    @ the wheel
    Andreas
    I remember a couple of years ago when the new regulations for the bigger front wings and smaller rear wings came into effect, everybody cried foul (incl. me).
    Yet some time goes by and nobody thinks any of it anymore. This too will go the same way.
    At least MiniChamps can no longer just dust off the old molds and put on new stickers. :)
  10. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    43,190
    ESP
    Bas
    with FI I meant Force India...
    I must say, at this point I haven't much confidence in the Ferrari.
  11. TheMayor
    107,577
    Vegas baby
    I guarantee that next year they will change the rules again to get rid of this hump. People don't like ugly cars.
  12. Drive550PFB
    Drive550PFB Two Time F1 World Champ
    I'm not gonna lie to you. That is pretty hard to look at.
  13. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    IIRC, and apologies if I'm mistaken, you also claimed that RBR would not be allowed to win all the races last year.... (?)
    They've (the FIA) changed the rule on nose height because they don't want to see someone's head get cut off.
    Neither do I.
    If it makes for an "ugly" car, so be it.
    Cheers,
    Ian
  14. barbazza
    barbazza Formula 3
    2,116
    Orange County, CA
    The 2010 cars looked strangely out of proportion with the new wings.
    This is different. The nose is catastrophically ugly. At first I thought they mistakenly brought out the chassis that failed the crash test...
  15. GordonC
    GordonC F1 Rookie
    4,169
    Calgary, AB, Canada
    Gordon
    Without looking up the exact regs - the FIA set a maximum height for the bulkhead in front of the driver's feet, since F1 designers were raising the top of the nose higher and higher to get more air flowing underneath - and the concern was that the driver's ability to see forwards was being impaired.
    At the same time, they set a maximum (lower) height for the nose a short distance in front of that bulkhead, because they were concerned that the higher and higher noses being used were creating a danger that in a t-bone collision, the high nose would ride over the side impact protection of the sideways car and force the high nose up into the driver's cockpit area.
    So, if a designer wants the maximum bulkhead height, the step nose is the obvious solution. McLaren's gorgeous car without the step nose has a bulkhead well below the maximum height allowed. This means that McLaren has a different airflow management philosophy around the front of the car than any of the step nose cars... either McLaren knows something the others don't, and will have an homologated advantage for the entire season, or McLaren gambled wrong, and will have a homologated disadvantage for the entire season.
  16. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    :eek:
    Biblically ugly!
    But, they're not trying to win any beauty contests. ;)
    Cheers,
    Ian
  17. barbazza
    barbazza Formula 3
    2,116
    Orange County, CA
    I'll still be happy if they win. I'll just have to listen to a radio broadcast rather than watch it on tv. ;)
  18. Gatorrari
    Gatorrari F1 World Champ
    16,547
    Georgia
    Jim Pernikoff
    There have always been "uglifying" features in F1; they come and go, and that's life. Eventually the stepped noses will go away as the rules change again, and some other despicable feature will come along.
    Consider the following:
    --The high wings used in 1968 into 1969.
    --The tandem wings and winglets used in 1983 and 1984.
    --The "X-wings" and "Viking horns" that were used at times in the '90s and '00s.
    All of these were similarly despised at the time, but for one reason or another, they all disappeared.
  19. TifosiUSA
    TifosiUSA F1 Veteran
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    Best post so far
  20. TifosiUSA
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    Thanks for that, had a nice laugh
  21. MisterMaranello
    MisterMaranello F1 Rookie
    Apr 5, 2011
    3,335
    Europe
    [ame]http://www.youtube.com/watch?v=WsPX-oozCoM&feature=g-all-u&context=G2aa27d5FAAAAAAAADAA[/ame]
  22. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,606
    Pacific NW
    Anthony C.
    Just noticed the OZ wheels that's on the car. When did Ferrari end their association with BBS ?
  23. DF1
    DF1 Three Time F1 World Champ
  24. TifosiUSA
    Nov 18, 2007
    8,468
    Kansas City, MO
    DJ
    Noticed that too
  25. 4rePhill
    4rePhill F1 Veteran
    Oct 18, 2009
    8,291
    Worcester, England
    Phill J
    The FIA have put a tight limit on the positioning and the angle at which the exhausts exit at, which is nowhere near the rear diffuser (or the brake ducts). The exhaust gases now exit in a "neutral" zone, midway up in front of the rear wing (they are trying to prevent people from having the exhaust blow directly onto the wing elements in the manner that Mercedes and Williams had been experimenting with).
    What it appears Ferrari are doing is using the spent air from the sidepods to blow onto the rear diffuser, in a similar way to last years exhausts. This will have no effect on downforce at low speed (likr the blowing exhausts did), but will probably provide a bit of useful additional downforce in medium to high speed corners.
    That's an interesting point, the angle of the step could well be designed to create a downforce pressure point on the front axle giving more front grip in medium to high speed corners (and help to balance out the rear end grip mentioned above).
    It may possibly also help deflect air up to the air box (and secondary intakes), and into the the airflow for rear wing.
    As others have already said, It's as ugly as hell but if it wins races then all will be forgiven (almost!).
