The 348 Le Mans engine is here | Page 7 | FerrariChat
Discussion in '348/355' started by angelis, Dec 9, 2009.
  1. BigTex
    Dec 6, 2002
    79,408
    Houston, Texas
    Bubba
    #151 BigTex, Feb 20, 2010
    The first pic is the engine number, you have #0000172 of that series design...F129'B00' sounds pretty special too, that refers to the design specification.
  2. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    Very horny pictures:) I have to say though. On an ultimate engine like this running at the le mans, using a 355 block and probably internals like rods ect ect. I have to wonder why did they still use the single serpentine cambelt?
    Fine engine that brother:) Love the detail shots.
  3. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    Man if you have to ask a question like that, you truly don't deserve that fine piece of historic engineering:rolleyes: I shall be down tomorrow morning to collect it :)
  4. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    thanks :D
    any idea what the other number on the block is?
    I moved house today!!!! ;)
  5. mad dog
    mad dog Formula Junior
    Jan 5, 2006
    875
    suffolk uk
    andrew
    times getting on - get cracking on this, I shall be most disappointed if you are not out on track asap!
  6. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    #156 angelis, Feb 20, 2010
    Thanks for the tip Justin.
    Deals done and the airbox should be here in a few days time.
    Thanks also to Morry at www.collectorstudio.com. He's a fellow Fchatter as well.
    The box is off Micheal Schumachers 1997 F1 car which was raced early in the season.
    "1997 Ferrari F310B engine airbox cover ex- Michael Schumacher. All carbon fiber with Ferrari shield, measuring 22x10x5". From the '046' engine."
    It will be used as part of the airbox we will be building for the engine.
    Just need Schumey to sign it for me.
  7. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    Forgot to add....
    The engine uses race plugs.
    Champion A55V
    These plugs are now obsolete, so will have to find a replacement.
    Any suggestions?
  8. PinoyP
    PinoyP Formula 3
    Aug 7, 2006
    1,023
    Bay Area
    AL
    Wow that's a great piece there man! Congrats :)
  9. MarkJ
    MarkJ Formula Junior
    Sep 10, 2006
    729
    NW Arkansas
    Mark Jones
    They assumed it was adequate to make it through an entire race.
  10. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    #160 ernie, Feb 21, 2010
    WOW Sy!!!
    The F129B is the same type block Ferrari uses in the 355.
    I'll bet that they first tested it in the Le Mans cars from 1994? Sort of how the Mondial T was the test bed for the 348.
    This is VERY interesting. You have an E X T R E M E L Y RARE engine Sy. Talk about hitting the jackpot bro! I would even go as far to see if the factory has more info on the history of this engine.
  11. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    I would talk to someone at NGK tech support. Or even the guys rebuilding it for you.
  12. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    Oooooo........coil on plugs! Close ups of the Bosch part numbers please. :D
  13. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    #163 angelis, Feb 21, 2010
    Will ask when I next talk to Simpsons.
    Hopefully Silverstone in April, but I have to run the engine in first. :(
    Always knew it was a special engine (sambomydog doesn't let me forget it!!!!) hence why we are spending $$$$ doing it properly.
    I'm visiting the Ferrari Factory in April, so if possible will try and find out then.
    Good idea. Will call them first thing monday morning.
    For you sir, anything. :D
    They fit really well.
  14. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    #164 angelis, Feb 21, 2010
  15. sambomydog
    sambomydog Guest
    May 23, 2009
    1,380
    First of all, i think the car is ready when the car is ready. It will find its own completion date. So if its not ready for April it does not matter.
    Secondly had i had the cash that engine may have been mine during the time that you were dithering:) A 348 Le Mans engine in a 355!!! Now that's novel :)
  16. fatbillybob
    Aug 10, 2002
    29,357
    socal
    OMG! a non-ferrari timing belt in a ferrari race engine from Micholotto. The world just stopped turning did you all feel it?
  17. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    BUUWAHAHAHAAAAA!!!
  18. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    YES!
    Your a good man Sy.
  19. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    #169 ernie, Feb 21, 2010
    I can't make out the Gates belt number.
    I can see the 5475-174 x 28mm, but what are the numbers on the other side? All I can make out is 3--A-
  20. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    Will take a better pic next time I'm there.
    Also going to try and fit the 348 cambelt on it and see what the problem was.
  21. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    Got the info from NGK Technical. Very imprtessed with their response time. Only sent the email last night. :D
    The Champion number you have quoted is an equivalent to an "11" heat range in NGK. The closest we have available in the UK is a heat range hotter R2349-10 (Stock code 6839, £44.34+VAT), however this may be too hot for your application so we advise you carry out some testing to see if this heat range is suitable.
    R2349-11 is produced by NGK, but unfortunately has not been made available to us in the UK market, so you would have to carry out some internet searches to try and find if any distributors worldwide stock this product and are willing to export it. Unfortunately we do not have any information available to us of which market this is produced for.
    The NGK part number mentioned above is a resisted plug compared to your original Champion which we believe is non-resisted. Provided your ignition system is at least coil based and in good operating condition, running resisted plugs should cause you no issues.
  22. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    Ata boy Sy.
  23. NeuroBeaker
    NeuroBeaker Advising Moderator
    Moderator
    Oct 1, 2008
    40,224
    Huntsville, AL., USA
    Andrew
    Wow - good to see things moving along nicely! :cool:
    All the best,
    Andrew.
  24. clean512
    clean512 Formula 3
    Feb 4, 2010
    2,137
    Josh @jtcarprojects
    very nice st up , caint go wrong with ITB's at high rpm ,
    Did a 1957 chrylser 300c conv with TWM itb and aem fuel mang.
  25. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
