The 456 journey | Page 41 | FerrariChat
The 456 journey
Discussion in 'Australia' started by Gizzi, Jul 22, 2015.
  1. Raulmenen
    Raulmenen Rookie
    Jun 28, 2010
    1
    Hello!! But if the electric air pump motor is broken? This parts is NLA... I do not know what to do
  2. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,183
    Brisbane, Australia
    Gezim
    When you say ‘broken’, do you mean not working or in pieces?
  3. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,183
    Brisbane, Australia
    Gezim
    So in this weeks episode, we examine and repair the dreaded slow down light.
    These are controlled by the ECU, which gets a signal from the cat converter thermocoupler control module. Jodi's started to flash the slow down light. I knew what it was, and didnt worry about it, as I knew the CATS werent overheating. BUT, one day, the light light started flashing, then stayed on solid, then one bank shut down. So, I tried to find some information, but there is **** all available, so that left me with just working out the system. Pretty basic really so I won't prattle on too long about it. The Motronic ECU that controls the slow down light looks for a varying 5v signal from the Cat control module. The higher the voltage, the hotter the thermocouple probe is getting. Generally you will see about 2.4v at the thermocouple probe. The Engine ECU will start the light flashing once the output voltage from the cat control module (CCM) reaches 3.6v the light will start to flash. At 3.8v the light will come on and stay on solid, and at 4v, the engine will cut out the effected bank and leave you running on 6 cyls. I tested the thermocouplers and found one to be shorted. Replaced both of them from Eurospares and bingo. BUT, as I was checking the CCM's, I noticed that when I pushed on the thermocoupler connector on the passenger side, the output voltage would go up to 5v. So I have a stuffed CCM as well. Replaced it with a second hand one I sourced to MJ to confirm, and all good. For any of you with these systems, I have found a place in New Zealand that manufactures new units, with better electronics and hardware. They are called Technistrada. Much cheaper and better than the factory units.
    knocker likes this.
  4. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
    So, translating that, you got the widget, monkeyed with it a bit, then had to fiddle with it, and now it works. Oh, and you can save yourself a lot of trouble and get a wudget from NZ
  5. simon klein
    simon klein Two Time F1 World Champ
    Feb 25, 2009
    28,802
    North Qld
    simon klein
    ..........all of which graduated from the thingamajig,doohickey and whatsitsname.
  6. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,183
    Brisbane, Australia
    Gezim
    Well, I WAS going to go into the N x 120 sec algorithm Ferrari uses for it, which I managed to find in the workshop manual, and how the voltages correlate with this, but I figured you balloon heads would need the Benny Hill music in the background to understand it!
    kerrari and FazzerPorscheman like this.
  7. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,183
    Brisbane, Australia
    Gezim
    Cue the Benny Hill music.....
  8. Horse
    Horse Three Time F1 World Champ
    Dec 1, 2005
    34,782
    Brisvegas
    Jon
    Couldn’t you just slow down?
    Derrrr
  9. Horse
    Dec 1, 2005
    34,782
    Brisvegas
    Jon
    Poor Moretti
  10. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
    Our cars don't have slow down lights :D
  11. kerrari
    kerrari Two Time F1 World Champ
    23,497
    Coolum Beach AUSTRALIA
    Karen H.
    Talking about Jodie’s car:p
    FazzerPorscheman likes this.
  12. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,183
    Brisbane, Australia
    Gezim
    So, today was engine service, gearbox service, rear wheel hubs/bearings removed and re-packed and of course something electrical. The ABS light stayed on once I’d refitted the RHR hub assy. I figured it was the wheel speed sensor, so I checked it and it was open circuit. Checked the LHR and it approx. 1.1k ohm. Quickly found a Bosch wheel speed sensor which looked pretty close, and these are NLA. A slight modification to make it fit. The sensor is the correct thing diameter but has a raised lip at the base which needs to be filed down. It took about 2 mins. It fits perfectly but requires a 1mm fibre washer to get the required 1mm gap from the tome wheel. Changed the harness plug to a waterproof deutsch plug and it was good to go. I guess this sensor will suit more than the 456 so here is a pic of the part no.
  13. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,183
    Brisbane, Australia
    Gezim
    Bosch part no.
    0 265 006 228
    It’s resistance is 1.7k ohm. The frequency obviously isn’t an issue, but I thought the amplitude may have been. These old systems are pretty rudimentary and it made no difference. It works perfectly.
  14. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,183
    Brisbane, Australia
    Gezim
    Oh, and I balanced the throttles. It’s surprising the difference it made.
  15. Horse
    Dec 1, 2005
    34,782
    Brisvegas
    Jon
    So, if you forget packing your luggage, you’re right to go!
    Gizzi likes this.
  16. FazzerPorscheman
    FazzerPorscheman F1 World Champ
    Jul 28, 2010
    14,986
    Piz Gloria
    EnzoFerdinand
    "I've got my car keys, wallet and torch. Luggage still in the room, I'm good to go."
    Gizzi likes this.
  17. Ferraridoc
    Jun 20, 2012
    16,169
    Gold Coast, Aust.
    Patrick
    You realise that the other three sensors will now fail - one every 3-4 weeks or so
  18. PAP 348
    PAP 348 Nine Time F1 World Champ
    Dec 10, 2005
    99,342
    Mount Isa, Australia
    Pap
    Nice fix mate! Thanks for sharing. :)
  19. jmillard308
    jmillard308 F1 Veteran
    May 29, 2003
    6,576
    Perth West Oz
    John Millard
    Why are you still awake?
  20. moretti
    moretti Five Time F1 World Champ
    Nov 1, 2003
    58,408
    Australia
    Nobody ever does that ... .it's an urban myth
  21. PAP 348
    Dec 10, 2005
    99,342
    Pap
    Can't sleep. Still awake.
  22. Horse
    Dec 1, 2005
    34,782
    Brisvegas
    Jon
    Fixeded.
