The accountant & his refusal to perform a belt service. “It’s a fraud” | Page 4 | FerrariChat
Discussion in '348/355' started by EFerrari34, Feb 3, 2023.
  1. Rifledriver
    37,288
    A few errors here. There is no device in any modern valve train I am aware of that prevents a valve from hitting a piston. It is easily achieved by a combination of reducing valve lift or increasing the size of the valve pocket in the piston. Both compromise performance but easy to do. Lots of cars are designed that way partially out of fear during servicing some moron will install a belt incorrectly on an overhead cam engine and bend a bunch of valves. But it is also done because so any do not do routine maintenance but adhere to the idea if it is still running it must be OK.
    Valves dont "Drop" when a belt breaks. Commonly said but doesn't happen. They go out of phase with the pistons, hit each other and bend valves. In the old motors (Ferrari ended it in 82 on V8s and 84 on V12s) with sodium filled valves that due to their construction already being structurally compromised could break the heads off. That was a mess. There are some other motors that can break valves off as well due to garbage parts . Dropping a valve is a failure of a valve, or a retainer allowing the head or the entire valve fall into the cylinder (we used to see those from time to time) not one that is caused by crashing into a piston from a valve drive failure A heart attack is a heart attack. Getting a bullet shot through the heart or a steering wheel rammed into it is very different .
  2. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    Dropping a valve is an old term that used to apply to what would happen when you would over rev an engine, like when missing a shift. Typically in push rod engines (in my day). The over rev would cause the valves to float because the valve springs weren't strong enough to follow the cam profile as fast and the cam rotated when closing. Then the piston would come up and wack the "floating" valve forcing the valve stem out of the retainer and the valve keepers (or locks) would fly out allowing the valve to drop into the cylinder. The rest was history.
    Texas Forever likes this.
  3. Rifledriver
    37,288
    Yes, that too. I was thinking of some of the early light weight retainers breaking.
  4. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,547
    Jeff
    Interesting comments by Ian Tyrrell at 12.35
    IvanRico and squid like this.
  5. tres55
    tres55 F1 Rookie
    3,572
    Canada
    You can probably "safely" push it to 10 year intervals but NO belt changes is just plain stupid.
  6. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    What do you mean by “safely”
  7. tres55
    tres55 F1 Rookie
    3,572
    Canada
    As in it probably won't blow up, but you're really gambling since the repercussions are far worse than just replacing the damn thing.
    I think most guys here do them every 5-7 years...I'm sure there's a handful that have waited closer to 10.
    5 is my limit.
  8. 19633500GT
    19633500GT F1 World Champ
    13,181
    Blueberry
    Muffin-Tops
    like this? Old school history here
  9. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Or,
    What the account from the original post COULD have done was…….done the engine out service/s himself. He could have still saved the money, would have learned loads, and even helped out other DIYers. ;) No engine grenade, no new/used engine, intervals at what ever he saw fit, and peace of mind that he could fix it himself. Plus, he could have used new after market designs like Hill’s bearings, Ferraripilot’s water pump (NLA), SFS silicone radiator hoses, etcetera.
    That’s the option I went for. :D
  10. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    763
    Vermont
    john truskowski
    Yes you are correct it does drive the oil pump, and it resides inside the engine. And in order to change it you must remove the transmission. The reason they did this, according to the chief engineer for the platform was to make the engine shorter. WTF?
  11. Rifledriver
    37,288
    Quite a price to pay but GM engineering has a long history of stupid ideas that made it to production.
    INTMD8 and WATSON like this.
  12. Rifledriver
    37,288
    19633500GT likes this.
  13. 19633500GT
    13,181
    Blueberry
    Muffin-Tops
    Car received a “new” OEM block in the day so it was likely just cast aside as a door stop.
  14. WATSON
    23,926
    WI
    Stay tuned.... ;) Pictures soon!
  15. WATSON
    23,926
    WI
    It's funny because it is true.....
    INTMD8 likes this.
  16. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  17. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    100 years ago they could build an inline six that drove the oil pump without a belt.
    Today, it's belt driven "to make the engine shorter" when clearly could be a chain or gear to gear within the same dimensional restraints.
    No, it didn't make the engine shorter, it's a result of pure stupidity.
  18. Aeroflop
    Aeroflop Karting
    Mar 1, 2022
    67
    Finland
    Eero Ahonen
    Maybe they just forgot to mention life. As in "It makes the engine life shorter".
  19. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    Lmao, nailed it ^ :D
  20. Rifledriver
    37,288
    Well it did cost less.
    INTMD8 likes this.
  21. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  22. Texas Forever
    Texas Forever Eight Time F1 World Champ
    BANNED Rossa Subscribed
    Apr 28, 2003
    85,600
    Texas!
    They go out of phase… I’ll have to ponder that one.
  23. Texas Forever
    Apr 28, 2003
    85,600
    Texas!
    Go ahead blame it on the accountants. We’ll see what happens to to your bill!
    ernie likes this.
